Old 05-16-2018, 01:43 PM   #1
tintintin
Default Glue for M46 shifter knob?
It's come loose again. What is the preferred glue for attaching the M46 shifter knob?
Old 05-16-2018, 01:56 PM   #2
XxJenoxX
Skin Suit
XxJenoxX's Avatar
I'd go with a screw...easier to remove if you ever need to replace it. If you don't stick it in the front, it shouldn't be visible.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
Originally Posted by XxJenoxX View Post
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 05-16-2018, 02:55 PM   #3
Buy one that isn't wogged out.
Old 05-16-2018, 03:13 PM   #4
I've always just opened up the top of the shift lever a bit with a pair of pliers. Never had a shift knob fall off after that.
Old 05-16-2018, 03:59 PM   #5
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Or this. I haven't pulled the knob off my M47 yet, and I had that problem ALL the damn time on my 242. Threw it at the back window on more than one occasion.
Old 05-16-2018, 05:48 PM   #6
Happy Mew Year!!!
I drilled and pinned mine back in the day, T5 screws on, highly recommended
Old 05-16-2018, 07:14 PM   #7
Jack
Banned
Jack's Avatar
Two wraps of electrical tape on the shaft and shove the knob on there, finally stop sucking the knob off the shifter
Old 05-16-2018, 10:16 PM   #8
dbarton
Bored Member
dbarton's Avatar
Here's how I cured mine:
http://www.240turbo.com/volvo240mods.html#shiftknobfix
Dave B
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, iPd Springs/Sways, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD retrofitted, 3.91 diff with G80.
Volvo seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Dave's Volvo Page: www.davebarton.com
Old 05-17-2018, 04:24 AM   #9
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Another way of doing it:
1975-80 knob with pattern cap. Requires modification of terminal ends, and, to engage/disengage the overdrive, you flick the switch from out to in and back, if you decide to continue using the relay setup. Otherwise, just convert to the early relay-free setup and no double flick of the switch. This knob is darn near impossible to get off without using a wrench inserted between the knob and the reverse lockout. Both my 242 and my 245 have it.
Otherwise, replace the sponge with a firm example, or, if the car's a sedan, use a wagon wiper stalk's rear washer button for the OD button, and then do whatever you want for a shift knob. If it's a wagon, then use a late model rear demist switch as your OD switch. Mount it where the Bertone had its dome light switch, that way you don't have to reach over to your dash switches to operate the overdrive.
-J
Old 10-28-2018, 04:52 PM   #10
tintintin
The hard plastic inner collar was cracked apart. Tried mending it with an electric plastic welder (glorified soldering iron with a fan?) but it quickly cracked apart again.
New (used but in good shape) shifter knob solved the problem.
More difficult was getting the OD button terminals lined up and connected sufficiently to keep the OD functioning over time.
