Old 01-02-2017, 09:08 AM   #26
sjulier
Originally Posted by planetman View Post
I made some calls a couple of weeks ago and I was told new aftermarket 240 ABS master cylinders maybe available sometime later this year.
Apparently, the manufacturer only makes 1 batch a year and they must have underestimated demand.
I suggest in the interim having the old brake master cylinder rebuilt by a bonded reputable rebuilder like Volvo was doing. When done properly, a rebuilt brake master can last as long as the original and in some cases longer than crappy new ones.
Normally I don't like using rebuilt brake masters mostly because of the time delay as most of my customers use their cars everyday, but sometimes you don't have a choice.
For some reason, repair kits aren't available from anybody and Volvo never sold them either.
The only rebuilt MBC I've found is O'Reillys listed above. Could you list other rebuilders please.
Sam
sjulier is offline   Reply With Quote
Old 01-02-2017, 01:40 PM   #27
muppetman342
Having too much fun
muppetman342's Avatar
[QUOTE=lummert;5531431]
Originally Posted by sjulier View Post
88 765 is ABS. I removed the Mercedes Benz style master cylinder and adapter and then rotated the brake booster 90 degrees resulting in the mounting studs being horizontal instead of vertical. The Ford master cylinder then fit the brake booster. Master cylinder outlet lines still connect to the ABS unit. The ABS on this car is disabled but all the brake plumbing is still intact.
Is the ABS disabled because of the MC change or was there another issue?
muppetman342 is offline   Reply With Quote
Old 01-02-2017, 02:30 PM   #28
lummert
lummert's Avatar
[QUOTE=muppetman342;5531744]
Front ABS sensors aren't installed. I replaced the front struts with hubs years ago with parts from a 92 960. 88 760 tone rings had 96 teeth and the 960 tone rings have 48 teeth. The ABS will not activate without the front sensors. The ABS light comes on, but no big deal.
Old 01-03-2017, 03:09 AM   #29
planetman
planetman's Avatar
I would use either Apple Hydraulics in New York or White Post in Virginia, but they both have good reputations AFAIK.
One of those was the place I found that could rebuild the funky front and rear calipers on the South African made right hand drive 1963 Lancia Flavia Zagato we once worked on.
FYI, you will most likely have to send in your old BMC to get it rebuilt.
Sam
Eric
Torrance, CA 90502
Old 01-03-2017, 09:17 AM   #30
sjulier
I called White Post. First thing he asked: "is it ABS?" He cannot rebuild ABS MBCs.
Sam
Old 01-03-2017, 10:25 AM   #31
sjulier
Summit Racing is another source for rebuilt MBC:
https://m.summitracing.com/parts/aaz-11-2661
Sam
Old 10-05-2017, 09:37 PM   #32
Marauder03
They are available again, I ordered from the Summit link in the previous post and received/installed it today.
2002 S60 - wife's DD
1992 245 Mystery Machine - my DD
2003 supercharged Mercury Marauder Big Blue
1998 S70 T5 - totaled 10/2014
1989 244 Ugly Betty - crushed 10/2015
1986 245 The Punisher - crushed 5/2011
1987 744 Little Blue - totaled 11/2009
2005 S80 - sold
1998 V70XC - sold
Marauder03 is offline   Reply With Quote
Old 05-10-2018, 08:26 PM   #33
klr142
Turbo, what?
klr142's Avatar
Did it work for you^? We got one and it's bad.
Old 05-10-2018, 08:44 PM   #34
sjulier
I installed the O'Reillys BrakeBest reman master cylinder Sept 2016, 20,900 miles ago. No problems at all.
https://www.oreillyauto.com/detail/b...=11-2661&pos=1
Old 05-18-2018, 05:13 PM   #35
klr142
Turbo, what?
klr142's Avatar
We returned the bad one to RockAuto and got another to replace it(same thing, A1 Cardone rebuilt in China). It's better! Pedal feel is still not great, but it's good enough to run with....
Old 05-21-2018, 09:54 AM   #36
freevolvos
freevolvos's Avatar
what's so different about them ? i would think the seals are shared with something else, what's the bore diameter ? could the seals out of a non abs m.c. be swapped into the abs m.c.? I'm guessing if there the same bore it could be done. I remember when you always rebuilt what you had and never bought new, lol even having to bore then and have a s.s. sleeve pressed in
Old 05-21-2018, 09:41 PM   #37
master cyl reinforcement bracket.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
