volvorod85
- Feb 21, 2003
- Sunny Socal
So 95 850t, code 413, EGR temp sensor performance blah blah. I've verified the valve works, holds vacuum and nearly stalls the motor, the solonoid seems to be working as if I hold it at a steady rpm the vacuum comes up for a sec. I've verified the wiring back to the ecu with a dvom from the EGR temp sensor, swapped our the vacuum solonoid and replaced the temp sensor anyway. Still code 413
Now I wouldn't think the tube or valve is clogged cause it will stall the motor when opened at idle, but is it possible enough crap is in the tube or valve to scew the temp sensor readings? Thoughts?
This code has been there for a yeear haha and now we're selling the car so I gotta fix it
