t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
How have people had success setting these up? I will use the 940 Volvo fan relay. I'd like to use built in fan control for the low speed setting to allow for easy idle up, and set a programmable output for the high speed. However, in fan control there is only a fan on temp and a fan off temp. I can't set a high limit to stop the fan control output to allow me to switch to my temperature controlled programmable output. I know I shouldn't ground both high and low relay pins at the same time. Any ideas how to work around this?
