Old 05-21-2018, 05:36 PM   #1
cmarquise
Default Clearing a flooded motor
My engine (1982 B21f kjet) was running really rich for a couple of weeks due to a few vacuum leaks from when I took apart some components. The engine flooded a few times and I've fouled a couple of sets of plugs. I think I have everything sealed up now, Is there a procedure for clearing a flooded motor that works for these cars? I hope the next set of plus I buy are my last.
cmarquise is offline   Reply With Quote
Old 05-21-2018, 05:46 PM   #2
iLoveTurdPeople
Take plugs out and crank it. Smart to disable to spark so no boom boom. Remember you can’t really compress a liquid so cranking with plug in on a severely flooded motor can bend rods. Unlikely but possible.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
iLoveTurdPeople is offline   Reply With Quote
Old 05-21-2018, 05:46 PM   #3
manually trigger the starter and floor it. Or disable the fuel system and crank the starter with the key while flooring it. Pulling the plugs will only help on either method.
Old 05-21-2018, 06:08 PM   #4
dbarton
Bored Member
dbarton's Avatar
If you think it was flooded by a lot, leave the oil fill open a while to help let fuel evap out of the sump. Check dipstick and smell for fuel.
Dave B.
Old 05-21-2018, 06:09 PM   #5
cmarquise
so the last time I tried to do it I pulled the fuses for the main and in-tank pump and cranked the engine, but did not touch the accelerator. So if I leave the plugs in, pull both pump fuses, crank the engine and floor it will that work? Do I have to do it for a set amount of time. I don't want to kill my starter, but I want to make sure it's clear.
Old 05-21-2018, 06:35 PM   #6
cmarquise
Dbarton! I just installed your wiring harnesses into my car as a part of this project. Excellent product, by the way.
Old 05-21-2018, 07:08 PM   #7
Clear flood on modern cars you floor the gas pedal and press the bake pedal and crank and it disables fuel and clears it out.
Change your oil once you get it running.
Old 05-21-2018, 08:07 PM   #8
TestPoint
TestPoint's Avatar
Clear flooding on our 30 year old cars is to remove the plugs, verify that injectors are not leaking or actually spraying fuel and spin the starter for a lot of time. Then check the crank case oil to see if it smells of gasoline.
I had a stuck K-jet fuel distributor that pumped the engine full to hydro lock. Maybe that should be a petro lock.
Ford V8 Conversion Manual -
Old 05-21-2018, 08:10 PM   #9
cmarquise
I've seen the flooring it method in some videos, but didn't think that would work on my 82 kjet. I think I'm going to follow a combination of all of the advice. Oil definitely has some fuel odor so I'm going to open the oil fill and try to let some evaporate. Then I will pull the fuses on the fuel pumps, crank the starter and floor it several times to try to clear the engine. Then I'm going to change the plugs and oil and hopefully be good to go. Thanks everyone.
Old 05-21-2018, 08:13 PM   #10
cmarquise
Ok, just saw that last post (i already checked injectors to make sure they weren't leaking and the plate is moving correctly), so my approach is going to be to pull the plugs, crank the motor and then I will change oil and plugs and hope I'm good to go.
Old 05-21-2018, 09:15 PM   #11
iLoveTurdPeople
Idk why people mention clear flood mode like it actually exists on our 240s. It does NOT. Pull all 4 plugs, disable fuel and spark, crank for 10 seconds, reinstall plugs, enable fuel and spark, start car and abort tbricks thread.
Old 05-21-2018, 10:34 PM   #12
A tough rowing ho
If you're brave
You should probably change the oil, it doesn't take much gas to ruin it.
Old 05-22-2018, 07:50 AM   #13
photoman327
photoman327's Avatar
Dave B.
thanks! have not been on you site in a while. MY first thought was Volvo has lost their freaking mind and I waited to late. at the time I did not have a car worth of Barton badging.
Old 05-22-2018, 11:07 AM   #14
dbarton
Bored Member
dbarton's Avatar
100% correct, but not on the worthyness. Any cared for project Volvo qualifies in my book.
Old 05-22-2018, 02:40 PM   #15
quillc
yv1a.com
quillc's Avatar
Had the same thing happen on a B21FT.
Change the oil.
remove the plugs and pull the fuel pump fuse.
Crank for a bit to clear the cylinders.
I then also blew compressed air in the cylinders till I didn't smell gas.
Put in new plugs.
I then cranked it till the oil pressure came up to normal.
Wind it up and enjoy.
I then changed the oil at 500 miles.
Chris
www.yv1a.com
