Old 05-22-2018, 08:18 PM   #1
Lando
Arthur Digby Sellers
Lando's Avatar
Default Fuel rail leaking
Fuel rail is leaking at one of the (what looks like) silver soldered joints. Anyone try to repair these with silver solder? No 240s in the junk yards near me right now.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 05-22-2018, 08:24 PM   #2
centason
Knipex=welfare queen
centason's Avatar
I would braze it.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 05-22-2018, 08:24 PM   #3
Hotdoggin
Hotdoggin's Avatar
I have tried. It worked for a while. If you need one, I can probably dig one up. What year?
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 05-22-2018, 08:57 PM   #4
Lando
Lando's Avatar
It's an 86, but I installed the late style with the schrader valve. Where was yours leaking from? Mine appears to be leaking from where the front padeye (for mounting to the intake) is soldered to the rail. I'm going to take it out and confirm it is leaking from that spot by pressurizing it to 50psi with a bike pump in a bucket full of water.
Old 05-22-2018, 09:04 PM   #5
Lando
Lando's Avatar
Originally Posted by centason View Post
I would braze it.
Hottest I've got it map gas, what rod would you recommend at those temps?
Old 05-22-2018, 09:11 PM   #6
EivlEvo
I have a spare fuel rail if you want...?
Old 05-22-2018, 09:20 PM   #7
culberro
culberro's Avatar
Silver solder.
Old 05-23-2018, 09:27 PM   #8
Lando
Lando's Avatar
For sure leaking from the solder joint. Pumped it up to 45 psi and used some soapy water:
That joint isn’t even designed to seal, it’s just to hold the padeye, not sure how it’s even leaking from there.
Old 05-23-2018, 09:43 PM   #9
white855T
I had the same issue before. Fuel rail cracked in the same place. I ended up just replacing it as I didn't want to bother repairing it.
Buyer/Seller Feedback
Old 05-24-2018, 02:23 AM   #10
Lando
Lando's Avatar
It's not leaking now. A few drops of 12.5% HCl and some silver solder did the trick.
I think the cause of failure is one of the mounting bolts worked its way loose. Perhaps the vibration caused the joint to crack.
Old 05-24-2018, 12:32 PM   #11
2manyturbos
Cool.
