Old 05-16-2018, 03:25 AM   #1
maxitoman007
Question Will this clutch setup hold 300hp?
Ok so my M46 in my 87 740 wagon pushing 20 psi through an eBay turbo is slipping in 3rd.
I found a good deal on some clutch parts on here (thanks sbabbs) and I now have a brand new clutch disc and PP ready to go in. My question now is if it will hold my power well while still providing a bit of insurance for the M46.
The setup is a clutchnet yellow pressure plate, and an OEM Volvo clutch disc. But hereís the catch, the disc is designed for a d24 diesel Volvo... Donít know if thatís good or bad news. Only difference I can find between the stock 740 clutch discs and my new diesel stock clutch disc is an extra smaller set of springs on the diesel disc. Aside from there being the 4 main springs on the disc just like there is on the stock 740 discs, there is also a set of green smaller springs in a triangle arrangement...
Please enlighten me on if this is a good setup for my car. Talked to a guy in Sweden who says that there they always run upgraded PPs with stock discs to prevent grenading M46s. He says some are holding around 400hp....
What do you guys think?
maxitoman007 is offline   Reply With Quote
Old 05-16-2018, 07:02 AM   #2
Happy Mew Year!!!
I want to see the m46 that held 400hp.
Old 05-16-2018, 12:42 PM   #3
GTJordan
Been here for too long
GTJordan's Avatar
Put it in and try...
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 05-16-2018, 12:54 PM   #4
EivlEvo
Isn't the clutchnet stuff all just paint anyway? Also... if you make the PP super stiff, get ready to kiss your clutch cable goodbye if it hasn't snapped yet.
Furthermore, this doesn't really leave you anyplace to go from here when you blow up your transmission.
Old 05-16-2018, 01:19 PM   #5
Hah, I remember when I put a Clutchnet clutch into my FT'ed M47 wagon. It lasted about 5 months, 2 1/2 of which were spent waiting out winter in the garage.
And by 'it' I mean the M47. It eventually ate third gear. Not a bad shift, just pedal down on a cool morning, hit 17 psi, boom. Probably around 230 - 240 HP.
Old 05-16-2018, 02:12 PM   #6
sbabbs
sbabbs's Avatar
Yeah I already told him I grenaded 5 m46's in one year and he should upgrade his trans and go with billet steel flywheel but sheet costs money. I lost about 5k when the cast iron dog dish flywheel went on my old cheapo junkyard 12.61 ride, took the whole car and the getrag trans.
I also told him to break in the new clutch for 500 miles at least, lets see what happens..
Old 05-16-2018, 02:35 PM   #7
maxitoman007
Alright i guess all I can do is put it in and see... gonna be hard to stay out of boost for 500 miles but I'll try.
Old 05-16-2018, 02:40 PM   #8
Start saving up for a T5 swap.
Heck, start getting the parts. If you're really making 300 hp, that is.
Old 05-16-2018, 03:40 PM   #9
sbabbs
sbabbs's Avatar
Turn your boost down to say 5lbs then...
Also if your clutch slips at 20lbs, and works fine at 18, leave it at 18... Save up for better stuff.
Old 05-16-2018, 04:55 PM   #10
EivlEvo
There is no way you're going to stay out of boost for 500 miles.
Just keep in mind where your legs are and where all those spinny bits are.
Old 05-16-2018, 08:15 PM   #11
Can play the blues
The extra small spring section in the center of the disk helps with vibration and smoothness. The intercooled 240 turbos used the same disk type whereas the 740 turbos with the M46 did not. Probably helps a cable clutch operate smoother.
Old 06-04-2018, 12:24 PM   #12
maxitoman007
Well, new clutch setup is installed and I don't really know what to think. I've never felt a "new" clutch before so I have no clue if I'm experiencing any red flags. So far I've only driven the car about 10 km but here's what I've noticed so far:
- Engagement point is much lower (maybe an inch off the ground it starts to engage)
- Engagement is smooth and gradual, I can already start and shift smoother than before although this concerns me as I wanted more "grip" (I'm not experiencing the on/off switch type feeling most people describe with new clutches)
- Pedal pressure feels similar to before to spite the new PP
- haven't hit boost yet or anything to test the actual grabbing power but, no slipping so far.
Old 06-04-2018, 12:30 PM   #13
Stiggy Pop
Stiggy Pop's Avatar
My previous setup was a clutch net 'red spec' pressure plate on a flat flywheel. It was not actually painted red but there's no way in hell it was stock or anywhere near, it was so heavy it started bending the clutch fork and pedal box.
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 06-04-2018, 12:39 PM   #14
maxitoman007
Makes me wonder why my clutchnet yellow doesn't feel any stiffer. Maybe its just me?
Old 06-04-2018, 03:36 PM   #15
955IsAlive
Save the tranny and traction limit the rear end to 250 HP :D
955IsAlive is offline   Reply With Quote
Old 06-05-2018, 06:41 AM   #16
DET17
Reformed SAABaholic
PAIN is the best teacher...... followed closely by financial pain. Some only learn this way.
