Old 04-11-2018, 09:00 PM   #2251
JCol91
Macaracachimba
JCol91's Avatar
Originally Posted by Homer View Post
More pictures pliz
JCol91 is offline   Reply With Quote
Old 04-17-2018, 10:28 PM   #2252
stick70
All the gauges
stick70's Avatar
stick70 is online now   Reply With Quote
Old 04-18-2018, 12:07 AM   #2253
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Those RFP1s look great, and an excellent choice of tire. Tire$ as much as the wheel$? What specs did you go with?
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is online now   Reply With Quote
Old 05-10-2018, 12:45 PM   #2254
CakeOD
Just put some BMW Style 5's on my wagon. The rears are rubbing a little bit when I hit bumps, so I'm going to have to roll or trim the inside fender lips, but I think it turned out pretty good. Next I need to get some lower profile tires instead of the balloons that came with these wheels.
https://imgur.com/rEJmiCS
https://imgur.com/rpKjFjO
https://imgur.com/M4iAGP0
1988 245 DL
CakeOD is offline   Reply With Quote
Old 05-18-2018, 02:50 AM   #2255
otokoto
Default epsilon
Originally Posted by brandonp View Post
Are you sure those Epsilons you have aren't 16x7? Here are mine:
do you have to modify anything on the Epsilon to fit on a Volvo 240?
otokoto is offline   Reply With Quote
Old 05-18-2018, 11:21 AM   #2256
Homer
OEMplus++
Homer's Avatar
Originally Posted by JCol91 View Post
More pictures pliz
This is all I have right now. Sorting out other issues and then I'll take some better photos.
Thanks! Yah nearly. $850 installed at Costco, $70 instant rebate on the set of 4.
245/40/17, Wheels are 17x9 ET 22 with 16mm adapters.
-Jacob:
2006 A4 - Comfy DD
Old 05-18-2018, 02:26 PM   #2257
propav8r
F*ck Edgar
propav8r's Avatar
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 06-01-2018, 05:35 AM   #2258
uberbrick
What adapter setup did you end up going for?
Originally Posted by SquareD View Post
Very Nice. I was curious because at the time I was researching wheels. I decided on these:
for my car. 17x7.5 et41 BMW BBS RC040s. Got my tires delivered last night, 225/45/17 Conti ExtremeContact DW's. Now I need to get the tires mounted and do a test fitting to determine my final adapter setup...
'81 Black 244 B210A swapped for B230F
'97 940 Silversand B230FK Sold
'81 Green 244 GL B210A Sold
My Feedback Thread:
http://forums.turbobricks.com/showthread.php?t=319802
Sellers / Buyers Feedback
uberbrick is offline   Reply With Quote
Old 06-01-2018, 06:54 AM   #2259
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
eh?
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 06-01-2018, 11:14 AM   #2260
SquareD
An Anomaly
SquareD's Avatar
28mm spacers up front and 35mm out back on my old RC-040s.
Old 06-02-2018, 01:58 AM   #2261
Jack
junkman
Jack's Avatar
eh?
Spinner hubcaps?
Old 06-13-2018, 07:44 AM   #2262
1978MY
Originally Posted by Jerd View Post
Wheel specs & adapters size?
1978MY is offline   Reply With Quote
Old 06-13-2018, 05:50 PM   #2263
SlowRide
SlowRide's Avatar
Spinner hubcaps?
Yusss
Old 08-06-2018, 05:06 PM   #2264
Ilvmetal
Default Make them fiT
Any shops in the NE or USA for that matter that can remove 1.5" from my ARE 9.5?
Want to narrow the fronts before they get powered coated and
the front looks ass backwards...
1973 142 Turbo 8V build
1988 740 16V money pit
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 08-06-2018, 10:51 PM   #2265
BR1CKHOUS3
I like the tuna here
BR1CKHOUS3's Avatar
Ilvmetal: Not an expert, but I would recommend googling reputable machine shops in your area. If you have the measurements already decided they may be willing to work with you
We don't do it for the glory.
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 08-08-2018, 04:21 PM   #2266
SquareD
An Anomaly
SquareD's Avatar
Not sure about machining, but if they're 2 or 3 piece you could rebarrel them.
Old 08-08-2018, 04:49 PM   #2267
Jack
junkman
Jack's Avatar
Just test fitting to see if I like them.
Tires are way too small
what do you think about the wheels?
Old 08-08-2018, 05:49 PM   #2268
PeaceEngineered
Sarcastic Optimist
^^^ Gold? Gold? Come on man, don't be so cliche...
Old 08-08-2018, 06:09 PM   #2269
Jack
junkman
Jack's Avatar
I didnt paint them
dont be jelly I have $8,000 wheels
Old 08-08-2018, 08:13 PM   #2270
Looks sharp other than the puny tires.
Old 08-09-2018, 09:29 PM   #2271
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Tires aren't too small, it just means the car is too high.
What size tires are those btw?
Wheels are good though.
daijoubanai is offline   Reply With Quote
Old 08-09-2018, 09:38 PM   #2272
Jack
junkman
Jack's Avatar
dude those are 195 50 r16
i roll on 205
Old 08-09-2018, 10:41 PM   #2273
rcstdad
drag radials...for all the hook
1981 242 LM7/T56 PTE 7275
1984 242 no LS, no turbo
(sold)1995 855 T5 NA Cams, MT, ARD Blue, White Injectors, full OBX, ARD 19t conversion, 285whp. Koni coilovers QA1 7"x550# & Hyperco 4"x25# helpers up front, Koni yellows & 10"x310# rears, rear sway bar, Kaplhenke Delrin bushings, CJ Yother baffled oil pan, slotted 302mm front, Porterfield pads, GT500 hood vent
"Therefore do no worry about tomorrow, for tomorrow will worry about its own things." Matthew 6:34
rcstdad is offline   Reply With Quote
Old 08-10-2018, 10:22 AM   #2274
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
That's hot
1980 242 Turbo
2004 V70R
Old 08-10-2018, 01:56 PM   #2275
LS_swapped
yess! more info on this set up?
LS_swapped is offline   Reply With Quote
