Old 09-18-2009, 09:48 PM   #1
yama
Default 240 3" stainless over the axle exhaust
Almost done building a full 3 inch stainless exhaust for my 240. It ended up being over the axle because my resonator ended up pointing that way. I like the look better as it is more stealthy and looks cleaner but making all the extra bends was a bear. I used a 8" flex pipe, Vibrant metallic core cat, Vibrant ultra quiet resonator and MRBP 3" in dual 2.5" out muffler along with 2 vband clamps. Need to pull down the 3 sections and finish welding all the seams and trim the dual outputs. Still a couple a of days before I get to hear it. I will take a few pictures of the sections when there off the car.
yama is offline   Reply With Quote
Old 09-18-2009, 10:19 PM   #2
DanielRogers
very nice!
93 940T - 20G / IPD springs / Bilstein's / K-cam / 3" / upper strut brace / chips
Originally Posted by adrianpike View Post
i will shoot you through the internet.
DanielRogers is offline   Reply With Quote
Old 09-18-2009, 10:32 PM   #3
DrvSfly
Bored Clown
DrvSfly's Avatar
Ja!
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 09-18-2009, 10:33 PM   #4
zlr101
That looks really good its not my car and i want to hear it. The whole underside of that thing is clean.
zlr101 is offline   Reply With Quote
Old 09-19-2009, 11:03 AM   #5
smokeyfan1000
Guest
I like the dual exit pipes from muffler. Cool.
Old 09-19-2009, 09:31 PM   #6
yama
Pulled off the downpipe today and finished seaming all the joints. Also reinforced the front mount which is made from an NA bellhousing bracket with some 3/8 stainless rod. The bracket has some high temperature barbque paint on it. Tomorrow I hope to finish welding up the resonator and over the axle pipe. That's my old downpipe in the back. yuk!!
Old 09-19-2009, 09:44 PM   #7
aussyvolvo
Will stalk for money
aussyvolvo's Avatar
weres your project thread, I wana see more!
she wanted me to spend all my time with her, that meant no tbricks and no gym...... so I got fat, and she found someone else...... skinnier.......... so naturally I'm back on tbricks to spread the badly spelt word :P
aussyvolvo is offline   Reply With Quote
Old 09-19-2009, 09:47 PM   #8
Homer
OEMplus++
Homer's Avatar
PM sent
-Jacob:
2006 A4 - Comfy DD
Old 09-20-2009, 02:18 PM   #9
fisky52688
broken down 240
fisky52688's Avatar
Looks awesome. this is pretty sweet and nice work with the pipe before the cat to tuck it up in the space. I need to hear this
1987 244. Will be B23 powered one day.
fisky52688 is offline   Reply With Quote
Old 09-20-2009, 04:33 PM   #10
badvlvo
Bad for Babies
badvlvo's Avatar
Looks pretty good so far.
Died at age 35
Old 09-20-2009, 05:10 PM   #11
The Aspirator
It's a girl!
The Aspirator's Avatar
I love the bend up before the cat, I'm sure that helps with ground clearance! I'd love to see a side shot of the clearance when it's all done. Great work dude.
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 09-20-2009, 08:33 PM   #12
yama
Today I finished welding the seams on the resonator section. The resonator mount is cut from a stock NA resonator. Not shown in the picture but I also cut the not needed corner off the mount and painted it with high temperature barbque paint as its not stainless. My original plan was to make the resonator section and axle section one piece. It wasn't possible to drop the pipe in one piece(bummer) so I had to add an additional vband on the resonator output. Finished welding all the seams on the over the axle pipe but still need to refit the pipe and cut the last V section again due to the added vband. Going over the axle uses 2 extra bends so I had to make 2 of them out of V sections. This is the first time I welded stainless and I was surprised to see that my tank of tri-mix is almost empty with running almost 2lbs of 308L wire. I don't normally like to take a hammer to the sheet metal but adding an additional 1" of clearance for the exhaust was to tempting. I did nice to it after by giving it a fresh shot of undercoating.
Old 09-21-2009, 01:03 PM   #13
yama
Some pictures of this mornings progress. Labor of love grinding out ridges. Trimming tips with a 14" dry cut saw. Not related but a bottom shot of turbo feed/drain with remote oil filter adapter. Bottom shot of downpipe installed.
Old 09-21-2009, 01:53 PM   #14
boosted12a
weapon of mass detonation
boosted12a's Avatar
looks great! a bit to clean under there tho. no active rust prevention either.
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 09-21-2009, 05:02 PM   #15
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
You started out ok on the downpipe, but the rest...
You shouldn't just cut the pipe on a miter like that. Cut perpendicular to the bends.
I'd be tempted to re-do the overaxle section personally, that ain't gonna flow well...
-Kenny
Old 09-21-2009, 05:58 PM   #16
fisky52688
broken down 240
fisky52688's Avatar
its 3" how can it not flow well? im guessing there is like no back pressure in this system
Old 09-21-2009, 06:03 PM   #17
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
I think Bondo was refering to the sharp transitions
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
Old 09-21-2009, 06:09 PM   #18
fisky52688
broken down 240
fisky52688's Avatar
I bet that because the inside of it is so smooth since its polished, that there is very little friction on the inside surface of the pipe. There are no 90 degree bends, the sharpest bend I see looks like 45 excluding the DP
Old 09-21-2009, 07:10 PM   #19
boosted12a
boosted12a's Avatar
no radius, only angles, bondito hasa good point indeed!
Old 09-21-2009, 09:10 PM   #20
Captain Bondo
Originally Posted by fisky52688 View Post
im guessing
Yeah, no ****.
Old 09-21-2009, 09:44 PM   #21
yama
Dude! In an ideal world you are right. Mandrel bends are the best and wish that I had more on hand. I started off intending to do an under the axle and had 6 3" 90's. That S bend before the cat that tucks the exhaust up 3" cost me a 90 and over the axle an additional 2 leaving me 3 short. Its not like I could run to AZ and pick up some 16 gauge 304 SS 90 bends so I improvised with what I had. The 90 I made with 3 V sections has an effective diameter 27/8". (I just mic'd it) So in all I have approximately 8" of pipe with a reduced of diameter of 27/8". I would have a hard time believing that is going to effect flow very much. I'm replacing a 2" crushed bent exhaust with this. Maybe some day I'll clean it up a bit with mandrel bends but for know I'm perfectly satisfied. Yes under axle will flow best but I can say that I like the way over the axle tucks up neat and I'm glad I did it that way. Its my resonator that pointed me up. The over the axle pipe isn't completed and I have already removed the sharp vsection on the end. I'm not a professional exhaust fabricator and this is my first one.
Old 09-21-2009, 11:30 PM   #22
Canuck
Frozen Garage Hell
Canuck's Avatar
Someone's got the shakes...
Old 09-22-2009, 01:17 AM   #23
2fast242gt
Do you have a cobalt?
wtf are those mild steel welds? and your peranmeters are way way off.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-22-2009, 08:11 AM   #24
yama
stainless. I know there not pretty. Stainless doesn't transfer heat very well and you need to use a fast wire speed and lay the beads down fairly fast. You stay on one spot very long and you have a huge bead. This was my first stainless job and I got better towards the end. If I sit down and support one hand take my time and do short pulses I can make the welds look better. I may just get a TIG. I don't know what peranmeters mean or WTF your talking about.
Old 09-22-2009, 10:27 AM   #25
Canuck
Frozen Garage Hell
Canuck's Avatar
He's talking about your wire feed and amp settings. I would question the logic - yes stainless transfers heat less effectively than mild steel, but this actually means that burn through is less likely. I would slow down the wire feed and heat and see what happens.
Cool project by the way.
