Old 11-22-2012, 11:35 AM   #26
pinguin
Queen Bitch of MWC Thread
pinguin's Avatar
Wuth the 4 bar fpr, doesn't it run rich at off boost?
pinguin is offline   Reply With Quote
Old 11-22-2012, 07:09 PM   #27
rcdude
Damn that looks fun! How much boost?
15G
mbc
Needs mer boost~~
rcdude is offline   Reply With Quote
Old 11-22-2012, 07:33 PM   #28
Mad Adder
Mad Adder's Avatar
OP, how has this been running and putting up with the change?
1984 SVO Mustang
1983 Honda Shadow
I used to run the house, then I bought the lady a Yorkie.
Mad Adder is offline   Reply With Quote
Old 11-22-2012, 10:59 PM   #29
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
still runs fine. 25k miles on the regina +t setup now.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 11-23-2012, 11:08 AM   #30
Mad Adder
Mad Adder's Avatar
How much boost did you end up running and do you know what it is getting mpg wise?
Old 11-23-2012, 12:14 PM   #31
Ryan_R
Has anyone tried running yeller-tops with Regina?
Interesting to read in one of the Volvo Pocket Data booklets that the Regina in-tank pump output (pressure/volume) is right on par with the Bosch turbo get-up.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 11-23-2012, 12:18 PM   #32
500dollar744ti
mpg is poopy, like 18mpg avg, 22 hwy. you can't have your cake and eat it too though.
it runs 7psi boost. the first turbo i used ended up being junk, i swapped another 13c on there but wastegate arm was not adjustable, didn't care to mess with it, just left it at stock boost.
it's been reliable and still scoots around like a stock turbo car.
Old 11-24-2012, 02:00 AM   #33
Daisy_854
Daisy_854's Avatar
Wish my 940 wasn't a 2.4, boo. Boring
Well written thread though.
'00 V70XC AWD. SE. Daily
'99 V70 awd. Parts.
'95 850 Turbo wagon. Parts.
'94 850 n/a wagon. Parts.
Daisy_854 is offline   Reply With Quote
Old 11-24-2012, 02:04 AM   #34
Pro Sneaker Peddler
So much easier to turbo than a Regina car.
Old 11-24-2012, 09:33 AM   #35
Daisy_854
Daisy_854's Avatar
But the story behind it would be better. "I +T 'd the 940 wagon" no "I +T'd my Regina 940".
Old 11-24-2012, 11:34 AM   #36
Ryan_R
Story schmory.
I +B234F'd my Regina 740 wagon..... I'd much rather have +B234F'd a Bosch 740.
-Ryan
Old 11-24-2012, 03:38 PM   #37
740volvo
I installed a apexi VAFC and was able to run 440cc injector and running 15psi on a 70 trim turbo.
740volvo is offline   Reply With Quote
Old 11-24-2012, 05:15 PM   #38
Ryan_R
I've seen you mention this before on the forum. Have you done a write up on yours? I don't think I'm planning to "do it", just curious what signals you used, and how you send them back into the ECU.
Cheers!
-Ryan
Old 11-25-2012, 05:15 PM   #39
740volvo
The VAFC acts like a voltage clamp that doesn't let the ecu read any boost because it runs an a MAP sensor and it the ecu read any kind of boost it will wig out, and it also has two tunable maps.
Old 11-26-2012, 12:56 PM   #40
pinguin
pinguin's Avatar
How much does the ecu rely on TPS vs MAP for injector pulse width? Because if it's just basing the fuel on the MAP signal, it seems ike rigging a hobbs switch to turn on the cold start once you hit boost would be the way to go.
Old 11-26-2012, 01:02 PM   #41
Ryan_R
Regina is all MAP. The TPS is almost identical to the Bosch LH switch: closed, open, WOT.
-Ryan
Old 11-26-2012, 01:20 PM   #42
500dollar744ti
yeah, it's not really a TPS, it's just a couple of micro switches in a TPS housing.
Old 11-26-2012, 01:26 PM   #43
Ryan_R
Even though the Regina TPS is a different part, I think the fit and pin-out is identical to the Bosch.
Old 11-26-2012, 02:50 PM   #44
pinguin
pinguin's Avatar
-Ryan
So then why not just leave the FPR alone, Regina should be just fine with anything off boost regardless of throttle position then, and rig up a hobbs switch or two for fuel under boost via cold start injector(s)
I realize it'd be an ugly way to do it, but it should work, especially at low boost levels...
Or am I missing something?
Old 08-27-2013, 10:43 PM   #45
vivalavolvo
vivalavolvo's Avatar
Arise thread. Arise.
Could a proper MAP sensor be installed with a tune? From my under standing the MAP calibrates to 0 on start as a 5v signal. So the sensor it self will max out at 0 vacuum. Just a thought on an old thread.
1978 242DL - 1995 855 T5 ARD Green - 1992 Volvo 745
vivalavolvo is offline   Reply With Quote
Old 05-30-2018, 05:38 PM   #46
tolling
tolling's Avatar
Hello I live in Volvos homeland Sweden and I have workt with and own Volvo my hole life. It's Swedens most common car. For knowledge so had every 740 sold here in Sweden 91-92 Regina and even some late 90's. No 940 had Regina here.
//Janne (Sweden)
tolling is offline   Reply With Quote
Old 05-30-2018, 11:26 PM   #47
white855T
//Janne (Sweden)
Regina was used as early as 89 and went up to 94 on 940s. I've never seen a 95 regina but I bet there were some.
Buyer/Seller Feedback
Old 06-01-2018, 06:58 AM   #48
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 06-12-2018, 04:45 PM   #49
jvluntzel
I have been collecting parts for a while now and will be doing a Regina + T over the week of the 4th of July. I have multiple options I will be examining (larger injectors/FPR/cold start injector/piggyback) and I will be testing all and seeing what works best. I even have some GM maps sensors I will be trying out. Big thread coming soon
jvluntzel is offline   Reply With Quote
Old 06-14-2018, 06:14 PM   #50
poulrais
poulrais's Avatar
I still have this Regina dog dish flywheel if you go for a manual swap. Already resurfaced, never saw a clutch disc in its life!
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
