Old 06-03-2012, 03:45 PM   #176
Pro Sneaker Peddler
That would actually be pretty cool. If we can get enough in, they could be a viable alternative to the T-5 or 265.
Old 06-03-2012, 03:50 PM   #177
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i will stretch out my feelers towards a couple of M90 ;)
Old 06-03-2012, 04:06 PM   #178
Lando
Arthur Digby Sellers
Lando's Avatar
If I didnt have so much on my plate already, I'd be very interested in buying an M90 from you.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 06-03-2012, 06:05 PM   #179
Texas240
Prius Owner
Texas240's Avatar
ive had two black tensioners do the same thing as yours did. Im on my forth one
93 245 LS Engine Swap Project
Old 06-03-2012, 06:11 PM   #180
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
w00t ?!
i c i have to get the number asap to support you guys with quality parts ;)
Old 06-03-2012, 06:13 PM   #181
Texas240
Prius Owner
Texas240's Avatar
w00t ?!
I was too cheap to the buy the gates one so I bought the cheap black one
Old 06-06-2012, 04:19 AM   #182
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
google: "038 109 243 D" -> Febi Bilstein
Btw... i something like hate my car right now... Powersteering doesnt work... LH2.4 doenst work...
Arrrre... it doesnt want to idle with Lambda feedback on.. starts to stall -> dead with lambda off its sits according to weather, temp and engine load on lambda 1,06 - 0,96... so we found a quite good map for it.. (while driving its .80-.85 acc. to rpm ;))
but turning on lambda (ign switched of and plugged out fuse or LH will make odd things) it instantly failboats...
Old 06-06-2012, 08:12 AM   #183
HansW
HansW's Avatar
M90 stuff --shipping is the problem, I never found a reasonable way to ge them into US. There used to be a member from UK who managed to ship them for a reasonable rate, --
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 06-06-2012, 08:15 AM   #184
egads
n00b
egads's Avatar
Tea chests are apparently the key, Paddler Ed should have more info on sending these from the UK.
One does not simply sig any old thing.
egads is offline   Reply With Quote
Old 06-08-2012, 03:05 AM   #185
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
YEAH !! I'm happy now !
its runs with Lambdafeedack.. L1 on every given RPM..
i changed to my old 937ECU and oh wonder... it works... my 977 seems to be damaged :( it worked 4000km with no probs before the swap so i never thinked of it being defective.. argh...
on monday we are going to find a nice setup and then we will do a chip and go for ignition Maybe 2 more weeks and im ready to drive it
Old 06-08-2012, 11:31 AM   #186
Sander
Good news everyone!
Sander's Avatar
Nice, don't forget to make some videos :p Do you plan on using a stand alone ems somewhere in the future, instead of LH2.4?
Old 06-08-2012, 11:44 AM   #187
fige
KING OF TBOT
fige's Avatar
geile drecksschwarte
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 07-10-2012, 03:19 AM   #188
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
mhhhkay drove some KMs on the weekend after we had our last notebookdrive on last tuesday..
ECU tune to drive is done.. it has 0,7bar of boost which is far too much for the ignition angle from the factory 219 goldiebox.. you can hear the motor running knocky past 4500rpm..
But.. amazing so far... the turbo is producing a quite infernal sound :D and the bov is twittering like a boss...
I had one moment of total adrenalin when some parts fell off the engine and got meshedup in the wheelhouse.. it sounded like the motor was gone So.. my copperbolt got a lil bit dry on its tip in that moment.. Instant stop... check for motor.. runs.. OK?! Dafuq was that?! My buddy went to the place where it happened and i looked for the new V70 Calipers but nothing.. it turned out that it was just a fawking enginemount for hanging it with a crane... somehow i disassembled it and forgot it anywhere near thar steering...
Oh.. Steering btw.. the power part of it... doesnt work..
Otherwise the ignitions still runs stock 219 it runs a bit boggy here and there also it stalls when lift off the throttle from above 2500 rpm.. played around with the throttle itself.. when i adjust it to proper "falling in idle from anywhere" i had no cutoff cause the poti was bypassed then. I now have it adjusted to something like a compromise... Also as saif the ECU tune is a preliminary one...
Turbo kicks at around 3100rpm in your back... so i think its choosen wisely ;) But the dealers said its a 0,3bar actuator... so.. why this MoFo goes up to 0.7.. seems to be a lil small and i have to grind it bigg0r.. also the wasteflapper cant open rly good cause it hits the wall really soon.. i grinded some meat for it to open more but still not enough... chinaturbs.. argh...
100kms to go then i have to retighten the headbolts from KL-Racing.. Maybe i'll also get some new hydros...
And i dont know if its something about the 960TB but i have a superstrange whistling while accellerating... sounds like swirls in the intake.. will do a vid of that...
V70 brake does its job like a champ btw
Ja.. aber sowas von die Geile Drecksschwarte ;)
Old 07-10-2012, 06:58 AM   #189
Wolda
Some time ago I also experienced a strange whistling sound when accelerating, it turned out to be one of the exhaust gaskets which was blown. Probably did not tighten the nuts enough as one was missing. So get your 13mm spanner and check
Wolda is offline   Reply With Quote
Old 07-10-2012, 07:19 AM   #190
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hi,
no it definately comes from anywhere the intake/brakebooster...
More from the throttle than anything else... i'll see and report
Old 07-14-2012, 04:42 AM   #191
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
theres the video...
http://www.youtube.com/watch?v=qpUYrLKL_i8
i dont know what it is... everything is sealed around the TB... tb itself looks good..
Old 07-14-2012, 07:23 AM   #192
Sander
Good news everyone!
Sander's Avatar
Check if you didn't forget to connect a vacuum line somewhere to the manifold. Sounds like it sucks in air through a small hole somewhere.
Old 07-14-2012, 08:53 AM   #193
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
mine whistles as well, but only above a certain rpm.
Megasquirt Tuning!
Old 07-14-2012, 01:18 PM   #194
Roy 940
+1...
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 07-15-2012, 04:40 PM   #195
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
guys... ;)
thats the first i looked at
Old 07-15-2012, 04:53 PM   #196
towz-T
EL hipo explosive
towz-T's Avatar
go for the sound, plug 1 ear,
Take a hose that fits your other ear and go look for the sound. Pretty shure the sound come from the same place as the problem :d
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 07-22-2012, 03:02 PM   #197
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
dunno what it is... we will see...
in the meantime i have another one... is this normal?!
my oilcooler AN 10 fittings are loose but they do seal... i dont understand how this worx..?!! just a little bit wet but no drops on it...
Old 07-23-2012, 11:02 AM   #198
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
no one ? :(
Old 07-23-2012, 05:06 PM   #199
Roy 940
Are you sure this fitting don't have any O-ring or gasket?
Old 07-23-2012, 05:19 PM   #200
JW240
All idiot, no savant
JW240's Avatar
it looks like those are swivel hose ends. like these: http://www.jegs.com/p/Earls/Earls-AN...49376/10002/-1
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
