Old 11-18-2010, 06:30 PM   #101
Homer
OEMplus++
Homer's Avatar
Originally Posted by Sir Psycho View Post
Cut 960 pan?
Da
-Jacob:
2006 A4 - Comfy DD
Old 11-18-2010, 07:00 PM   #102
callousedxfingers
callousedxfingers's Avatar
Originally Posted by Homer View Post
Da
So is it being shorted to fit the 5 cyl? Aside from what I assume to be more volume, what are the advantages to using a 960 pan? I don't think I have heard of this till now.
callousedxfingers is offline   Reply With Quote
Old 11-18-2010, 07:03 PM   #103
Cameron
ドクターマリオ
Cameron's Avatar
Originally Posted by callousedxfingers View Post
...what are the advantages to using a 960 pan? I don't think I have heard of this till now.
Needed to clear the cross member when not mounted in it's "normal" transverse position. i.e. in a 240.
Cameron is offline   Reply With Quote
Old 11-18-2010, 07:31 PM   #104
Homer
OEMplus++
Homer's Avatar
Yep!
Old 11-18-2010, 07:37 PM   #105
Dammit
+8cm
Slightly more elegant solution than bfh utilisation to establish clearance.
Great project, I am looking forward to reading about each development whenever I log on.
Dammit is offline   Reply With Quote
Old 11-18-2010, 07:56 PM   #106
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
A BFH would not do it. You'd need to completely different crossmember. It's not like it's "kinda close" with the fwd pan...
-Kenny
Old 11-18-2010, 08:30 PM   #107
callousedxfingers
Oh okay, that's pretty sensible as opposed to weakening the cross member.
Old 11-18-2010, 08:34 PM   #108
Captain Bondo
oh okay, that's pretty sensible as opposed to removing the cross member and steering rack and using pieces of string tied to the wheels to steer the car.
ftfy.
Old 11-18-2010, 08:47 PM   #109
callousedxfingers
Bahahaha.
Old 11-18-2010, 09:22 PM   #110
Alex Buchka
8 cylinders
Alex Buchka's Avatar
The halves got gooped back up
This part came out ok. The section not visible, not so much
Had some real trouble with this top corner. There was a massive pocket of slag right at the cut which made welding it pretty difficult. Had to boil the crap out and file it off the top about 50 million times before the metal was clean enough to join up ok. Net effect was there was very little material left so I was forced to burn some more filler on there to build it back up.
Old 11-18-2010, 09:31 PM   #111
volvogeek
Is there any issue with taking a 5-cyl pan and cutting it so that it is 'thinner' in the required areas? The 6-cyl cut pan is probably easier but in the absence of a 6-cyl pan can a 5-cyl pan be modded to fit?
volvogeek is offline   Reply With Quote
Old 11-18-2010, 10:24 PM   #112
Captain Bondo
You would have to "notch" it because the oil filter mount would need to remain unchanged, and you'd need to make some manner of custom pickup. At that point the motor would be a real bitch to install.
Alex, I tend to clean cast parts quite a bit more than that. Hitting it with a flap disc until the material is shiny with no trace of the rough casting finish makes life easier.
Old 11-18-2010, 10:46 PM   #113
Homer
OEMplus++
Homer's Avatar
Giggle.
Another solution would be a dry sump, but that's so far off the scale of logic for this project right now.
(Yes I did attempt to make this project sound logical)
Old 11-19-2010, 03:45 AM   #114
Dammit
+8cm
Originally Posted by captain bondo View Post
a bfh would not do it. You'd need to completely different crossmember. It's not like it's "kinda close" with the fwd pan...
rbfh?
Old 11-19-2010, 04:36 AM   #115
Alex Buchka
8 cylinders
I always forget how disproportionate a shortened 960 pan looks. The sump is absolutely enormous in relation to the total length
The pics make it look dirtier than it is. The pan welded surprisingly well everywhere except that one top corner that was just horrendous. Must have been a casting defect right there. The job was exacerbated by the fact that the die grinder broke and I had to file everything by hand.
One corner of the pan rail only lifted about .25mm after welding so I shouldn't have to machine off that much to bring it back to flat.
Old 11-19-2010, 11:39 AM   #116
Homer
OEMplus++
Homer's Avatar
In real units 0.00984251969 in
I've found a place to get the tooling done for the airbox in exchange for help laying up a carbon steering wheel.
Old 11-19-2010, 01:58 PM   #117
Homer
OEMplus++
Homer's Avatar
Turbo arrived.
Nothing can be easy, can it?
The guy left the snap ring out of the comp housing. Up side? This thing is practically new.
Old 11-19-2010, 02:33 PM   #118
nice scrap metal
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-19-2010, 02:44 PM   #119
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
thats horrible
Old 11-19-2010, 02:46 PM   #120
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Old 11-19-2010, 02:47 PM   #121
Homer
OEMplus++
Homer's Avatar
Shipping damage. Ugh.
Old 11-19-2010, 11:12 PM   #122
the poi
Meh
the poi's Avatar
its broken
Old 11-19-2010, 11:30 PM   #123
towerymt
the real Towery
towerymt's Avatar
Send it back. Or sell it to Brett.
Old 11-19-2010, 11:33 PM   #124
Homer
OEMplus++
Homer's Avatar
The likelyhood of me getting a refund is low. We'll see. I'd rather throw 40$ for a new comp wheel at it.
Old 11-19-2010, 11:35 PM   #125
DavoS40
DavoS40's Avatar
Major bummer...
1983 245DL, 2011 WRX, 1978 SR500
DavoS40 is offline   Reply With Quote
