Old 12-13-2013, 06:56 PM   #201
Matt
ICY HOT STUNTA
Matt's Avatar
who gives a **** when its that badass
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 12-13-2013, 07:46 PM   #202
Rectilinear
Longitudinally Mounted
Rectilinear's Avatar
Truly. I know it affected the mileage but I don't worry about measuring it with the exception of this simple formula:
It's better than the mileage my 242 gets.
Originally Posted by A Random CL Ad
A Volvo 240 does not have a slow zero to sixty time. Nor a fast one. It reaches sixty precisely when it means to.
Rectilinear is offline   Reply With Quote
Old 12-14-2013, 07:44 PM   #203
Funkee
Funkee's Avatar
Yeah thats true, but I was wondering would it be more efficient due to the bigger wheels or would it be less cause of the extra power needed to get it at speed.
Old 12-16-2013, 08:02 PM   #204
imlolin
Very good thought. With the 235/75's I got 300mi to the tank. With the 30's I get much worse. They're new so they're heavier and bigger. The LM7 will take care of it.
Jorsh
imlolin is offline   Reply With Quote
Old 12-16-2013, 08:03 PM   #205
imlolin
Has anyone put an 8.8 in their 7/9 series on here? I know you've got to shorten one side with a 240 but I'm not sure with my car. Lead me to threads.
Old 12-17-2013, 12:13 PM   #206
Rectilinear
When I first lifted my wagon, I installed 30x9.5 and then stepped down to 235/75's. Both of those tires killed my performance and mileage since I still had the aw71 in it. Once I installed the M46, my performance and mileage increased greatly, and it only got better when I stepped down into 225/75's.
Old 01-20-2014, 02:04 AM   #207
imlolin
I just barely missed the light. LM7 progress is slow. I've got a lot to get still but I'm apparently getting around 22mpg with the b230 after figuring out the distance I travel due to the tires.
Old 01-20-2014, 02:07 AM   #208
Jerd
Jerd's Avatar
Rad dude. Looking good.
Old 01-27-2014, 08:02 PM   #209
stevecole33
I really like the car and am trying to do something similar. I just got my 235/75-15's on my 740 sedan, just all terrains though. So you have not corrected your speedo?
stevecole33 is offline   Reply With Quote
Old 02-09-2014, 02:45 PM   #210
Eesha
Really nice cars here
Looking forward to lift mine a few inches..
But has anybody put a awd into a 240/740/940? Would be awesome if there is some kind of build thread or something on the net..
Eesha is offline   Reply With Quote
Old 02-25-2014, 02:58 PM   #211
Rectilinear
Has anyone decided what the best rear shock absorber is for the lifted 740? I have tried some sad aftermarket shocks for a 245 and again some used Dodge Durango shocks and neither have been much help at keeping the rear end stable. My max extension should be about 20.75" so the stock shock is about 2 inches too short. It seems as though Volvo used the only shocks with the 12 mm sleeve but I have swapped out the sleeves in the other ones as well so that's no biggie. I'm ready for something new now so what have you guys proven to work and work well?
Thanks!
\\edit\ Might have answered my own question here. I spent a couple of hours scouring the Monroe specification chart and may have a winner. To avoid false information, I plan to order and install the shocks first before posting part numbers. Kinda cool what the 'other' shocks fit, though....
Old 02-26-2014, 06:12 PM   #212
Eesha
Yeah, would be kind if you could post a short report about your experience with the shocks, springs ect
Old 03-04-2014, 01:08 PM   #213
Rectilinear
Well, I may never get the opportunity to find out if these new shocks would work or not. I have become bored with the lifted wagon though I am not sure how. I have an extra set of strut tubes at home and I may decide to go low again for a while to respark my interest in it. I still have a set of cut springs for it that I had on it before the lift, but I would need to source a set of wheels and tires for it, preferably in a 17".
So, I will pass the torch for now and allow my research to be put to use on someone else's lifted 740.
After researching, I find that the rear shocks from a Volkswagen Vanagon should bolt right on to the 740, but you will need spacers for the lower connection at the trailing arm and a single spacer at the top to make up for the shorter sleeve in the VW shocks. The Vanagon only weighs roughly 300lbs more than the 745s o the rate should be damn close. And the shocksa are listed to be just over 2" longer than the 740 shocks are. If you raised your 740 higher than 2", you can opt for the shocks from the 4WD version of the Vanagon and they will give you added length.
I wish you luck and please do not hold me responsible for any issues or damage/injury from taking my advice. This is an experimental shock for a modified car.
KYB Part# KG5557 1980-1991 Volkswagen Vanagon
Old 03-09-2014, 02:11 PM   #214
imlolin
Hello all, I've picked up a 244 as my daily driver until the 740 is all ready to go. Here's a picture. It's a pile of crap. Looks even worse near a 2001 740i.
Old 03-11-2014, 12:29 PM   #215
Rectilinear
Default Slammed to Lifted to Slammed
Well this weekend I decided to get out in the garage and bring my wagon back down closer to the pavement. There were two different ways I could have gone:
1. Spend $75 for the Vanagon shocks and be happy with a lifted wagon.
2. Use the spare strut tubes in the garage and give it a different perspective.
I decided to go with option #2. Then I chopped two coils off of the stock springs all the way around. 3 hours later, I stole the AREs off the 242 and gave it a test drive, then I knew this was the right thing for me. The lifted wagon was a fantastic idea and I enjoyed driving it very much. But in this area I never really got it off road except for medians, my side yard or the occasional Prius. But my driving style leans more toward fast cornering and rapid lane changes. I will retain the lights and mudflaps for a while, maybe longer.
Sorry to jump ship on you guys, I just had to go my own way....
pics suck due to the horrible lighting last night
Old 03-11-2014, 01:54 PM   #216
92masonry
92masonry's Avatar
Damn, well that was fun to watch!
92masonry is offline   Reply With Quote
Old 03-11-2014, 01:56 PM   #217
Rectilinear
What can I say, I have a short attentio...
Old 04-27-2014, 09:42 PM   #218
1990_740turbo
JDM yellow fogs
1990_740turbo's Avatar
So vanagon shocks are the way to go? someone fill me in.
Originally Posted by Fraktion View Post
dude how do you NOT have a huge ****ing cone filter by now, get with the program
things to never mention on turbobricks: bags. stretched tires. nickelback
1990_740turbo is offline   Reply With Quote
Old 05-23-2014, 10:02 AM   #219
aStrauss
aStrauss's Avatar
This is the thread I have needed to come across. Funny to see the ikea mudflaps and white omegas. I am currently running the red cutting mats and a set of Novas, but the plan has always been white omegas. Great minds think alike. I am planning on running grabber at2's, so I was excited to see some advice on fitting those. Somebody needs to start a thread similar to NASIOC's "rally prepped" thread, where people can post pictures, and wheel/tire/suspension setups. Almost functions as a database of sorts
Lifted 1991 740 sedan
Showroom 1992 960 wagon
aStrauss is offline   Reply With Quote
Old 08-07-2014, 09:16 AM   #220
imlolin
Here's an update. I've got an MA5 out of a Solstice that's going into it. I'm building the LS like 55superbeetle/sloppy mechanics. It seems that's a pretty solid way to go. I'm shooting for 500whp to begin with, maybe a touch more. In the meantime I've been making the 240 better. I built a lift kit for the front out of 3/16 stainless and I tig welded it. I fixed all the gauges in it and just put some new tires on it. After the 740 is finished I'm going to turbo it.
Here's some welds.
I built a thru axle adapter since they're $60 and it's stupid easy to make out of scrap stainless.
The MA5. 34k miles on it. Hopefully it's as good as an R154.
240.
Old 08-07-2014, 09:49 AM   #221
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
This thread rocks !
if you lenthen the struts, do you put spacers to the bottom or do you use different dampers?
Old 08-07-2014, 09:50 AM   #222
imlolin
Originally Posted by MadDog_945 View Post
This thread rocks !
if you lenthen the struts, you put spacers to the bottom or do you use different dampers?
Spacers on the bottom. It will allow you to retain your full droop and bump travel. The only thing that limits you is the LCA's need to be an inch longer. I'm working on that.
Old 08-07-2014, 03:11 PM   #223
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ok... I believe 10mm would be enough...i want to drive 195/80/15... ?
Do i need adjustmentscthen on the lca?
Old 08-07-2014, 07:55 PM   #224
imlolin
you wouldn't need a lift for those. how much do you want to lift it? we've done like 50-75mm.
Old 08-08-2014, 03:44 AM   #225
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Unfortunately i need the raise.. in germany you have special regularyties on spinning parts close to other parts.. our MOT Testers check for clearance and i need a minimum of 5mm from the tyres profile to the springperch..
So with an unused Wrangler Grabber 195/80/15 i have 1,5-2mm left to the perch.. with 75/80 km/h it rubs cause the tyre is expanding..
I think those 215/75/15 would look absolutely more awesome but milage and this needed LCA-Mod makes it uneconomical to me..
I Dont do this for the looks, i do it because im moving into the forest 2015... i need more space between me and the treeroots :D
