Old 10-09-2014, 03:49 PM   #1
BryantTF242
BryantTF242's Avatar
Default Torque rod and trailing arms
Ok so I have short strut coilovers and adjustable spring perches on my 242.
My real wheels now sit closer to the rear of the arch rather than centered (obviously).
I bought adjustable torque rods to better my driveshaft angle, but that will require rotating the rear axle further rearwards! So I don't really want to do that!
MY QUESTION:
Has anyone successfully made adjustable trailing arms? So I can rotate the bottom of the axle forwards?
I know kaplhenke makes some but I don't want to change my entire rear suspension setup!
has anyone maybe cut off the front eye of the trailing arm and welded in a rod with threaded insert and made them that way? Similar to the operation of the adjustable torque rods?
Let me know your thought and/or experiences!
Much appreciated.
1982 242 Turbo - The Fun One, K-Jet, 3in Turbo Back, RSI Coilovers, BBS LM Reps, Awesome.
http://forums.turbobricks.com/showthread.php?t=280461
1990 240 Wagon
BryantTF242 is offline   Reply With Quote
Old 10-09-2014, 05:05 PM   #2
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
The axle doesnt move back or forth while lowering but left and right... What you need is a adj panhard.. Adj.Torque rods are used to align the driveshaft..
Old 10-09-2014, 05:07 PM   #3
BryantTF242
i understand that. i have an adjustable panhard bar and the rear end is totally centered. i know the adjustable torque rods are to adjust the driveshaft angle, but id like to bring the rear end assembly forward a hair.
Old 10-09-2014, 05:11 PM   #4
centason
Knipex=welfare queen
centason's Avatar
IPD torque rods are cheap enough. Pre built, no headaches. I'm sure you could shorten the trailing arms. Someone may have a trick to center the wheels.
Member: TBCCS
"People will believe a big lie sooner than a little one, and if you repeat it frequently enough, people will sooner or later believe it." -Walter Langer
Old 10-09-2014, 05:24 PM   #5
BryantTF242
basically i want to take this
chop it to this
and put this on the end
anyone done this????
Old 10-09-2014, 05:30 PM   #6
Alex Buchka
8 cylinders
Alex Buchka's Avatar
I shortened the trailing arms on my car about .750". I just chopped them off and welded them back together, it was very simple. I would be weary of doing what you're describing in those photos. The trailing arm on a 242 is loaded in bending and doing that to a turnbuckle or otherwise threaded component is bad juju. Not saying it won't work, it's just poor practice.
Old 10-09-2014, 05:34 PM   #7
BryantTF242
http://www.kaplhenke.com/collections...-trailing-arms
they use a threaded end???
i need something like this without the suspension conversion issue. lol
Old 10-09-2014, 05:35 PM   #8
BryantTF242
and id hate to chop them and weld and be like cr@p its too far in or not enough.
Old 10-09-2014, 08:41 PM   #9
Alex Buchka
8 cylinders
Old 10-09-2014, 09:04 PM   #10
benski
Post
I'd be wary of it too.
Old 10-09-2014, 09:33 PM   #11
Originally Posted by Alex Buchka View Post
Like I said:
agree'd
Its not ideal but the bending loads it sees are very minimal so as long as the hardware is sized appropriately theres no issue.
The new aluminum ones will have slug based adjustment
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-09-2014, 10:34 PM   #12
BryantTF242
Originally Posted by blkaplan View Post
agree'd
would you ever be up to the idea of making adjustable trailing arms with stock spring/shock mounting?
that would be awesome
Old 10-09-2014, 10:36 PM   #13
no, way too much effort to still have crappy shock mounting geometry.
Old 10-10-2014, 04:21 AM   #14
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
aaaahh now i get what you want
In the last bilsport or speedhunter realted volvo article was a guy who centered his axle.. maybe shoot him a question over the pond ?
Old 10-10-2014, 06:25 AM   #15
mopar318
mopar318's Avatar
The torque arms will move your axle forward slightly. If getting adjustables just buy some swedge tube and rod ends, or buy them from kaplhenke racing.
Thought about cutting my arms and welding shorter as well, but never got to it this year.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 10-12-2014, 07:52 PM   #16
leadpoisoning
leadpoisoning's Avatar
I built some adjustable trailing arms but have yet to install them.
leadpoisoning is offline   Reply With Quote
Old 10-13-2014, 03:29 AM   #17
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Nice design
Old 10-13-2014, 05:48 PM   #18
BryantTF242
This is EXACTLY what i was thinking of. let me know how it works
what materials where used?
Old 10-13-2014, 05:58 PM   #19
badvlvo
Bad for Babies
badvlvo's Avatar
Actually he needs both.
The rear links are not equal length so the axle moves in an arc under compression, side to side, and fore/aft. I'm not going to use big words to describe this movement.
agree'd
And when will we see these new aluminum units?
Died at age 35
Old 10-13-2014, 08:05 PM   #20
leadpoisoning
Nice design
Thanks man.
Old 10-13-2014, 08:07 PM   #21
leadpoisoning
3/16" mild steel plate, 1.5"x .120" wall DOM tubing, and these http://www.ebay.com/itm/171226301234...%3AMEBIDX%3AIT
I'll have to machine some sleeves for them to fit on the car properly but the same could probably be done with smaller rod ends if you don't have access to a lathe.
Old 10-13-2014, 08:08 PM   #22
volvowagoon
Unslammed. Cry about it.
volvowagoon's Avatar
I want on my car today
1986 Buick Grand National - My toy
3800 Series II engine on a run stand - My project
2010 Volvo C30 T5 - daily and for sale
Old 10-14-2014, 11:08 AM   #23
sometime this winter most likely
Old 10-22-2014, 11:28 AM   #24
benski
Post
We'll await further developments!
Old 10-22-2014, 11:46 AM   #25
naterhater
naterhater's Avatar
Another option would be to make this^^ Then weld pieces of plate to the ends you just cut, weld a large bolt to the plate on the small end, drill a whole in the plate on the big piece and weld a large nut to it. Depending on how confident you are in your welds. Then use another nut as a locking nut so it isnt twisting all over the place while you drive. this way you could use the stock bushings if you desire
"It's probably fine!"
"If you find yourself doing it a second time, do it right this time"
'93 940 Turbo thread:
http://forums.turbobricks.com/showthread.php?t=288116
naterhater is offline   Reply With Quote
