Old 10-29-2015, 06:03 PM   #201
HUB
Needs more cowbell
HUB's Avatar
Default Wilwood Big Brake (Front) Conversion
Got some weekend fun ahead of me ��
Thanks,
HUB is offline   Reply With Quote
Old 10-30-2015, 05:35 AM   #202
THolandsli
Nice brakes. Is this bolt-on? Front or rear?
- 11" XC60 D3 AWD
- 12" V70 D2
- 67 Amazon T5 project <-- Follow the link
Instagram: projectamazonturbo
THolandsli is offline   Reply With Quote
Old 10-30-2015, 08:07 AM   #203
HUB
Needs more cowbell
HUB's Avatar
This is bolt on for the front.
Old 10-30-2015, 10:52 AM   #204
blackadder
Those brakes looks so nice. Was it custommade or can I buy it from somewhere?
blackadder is offline   Reply With Quote
Old 10-30-2015, 11:17 AM   #205
HUB
Needs more cowbell
HUB's Avatar
Brackets are made to order (group buy).
Old 10-30-2015, 01:18 PM   #206
cwdodson88
Be sure to use safety wire on the bolts for the rotor to hat... and dont be alarmed if you have to have your rotors turned. What pads did you decide on?
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-30-2015, 07:08 PM   #207
AndrewNance
Amateur hour!
AndrewNance's Avatar
My rotors had to be turned. Kind of frustrating but whatevs. Also don't be alarmed if the guy at autozone has no idea what he's looking at. Like a two piece rotor is some revolutionary piece of equipment.
'71 142
'80 245
Feedback
Old 10-30-2015, 07:37 PM   #208
cwdodson88
^ OMG! The guy at schmucks was like "uhh, how much can I take off?" Lucily the manger had done some brembo 2 piece before and took them back.
Old 10-30-2015, 10:10 PM   #209
HUB
Needs more cowbell
HUB's Avatar
Yep. Got one torgue to spec with thread locker. Will safety wire it per Wilwood's diagram. Went with 150-8854K pads. Didn't see a need to go with the others... yet...
http://www.wilwood.com/BrakePads/Bra...emno=150-8854K
Old 10-30-2015, 10:11 PM   #210
HUB
Needs more cowbell
HUB's Avatar
Default P1800 Tunnel
This arrived tonight. Stole the idea from Andrew Nance. Lol.
Will test fit the rear end tomorrow. If all goes well, will paint it and maybe install.
Thanks,
Old 10-31-2015, 08:50 PM   #211
HUB
Needs more cowbell
HUB's Avatar
Default Wilwood Big Brake (Front) Conversion- Rear End- Fuel Line
Well made some progress tonight. Hope to get some more done tomorrow.
Safety wired the bolts holding the rotor and hat together. This was my first time doing it and was a lot of fun. Will have to adjust a few, but you get the idea.
Painted the rear calipers with something new today... Wasn't a fan. O well, can always just powder coat them.
Started painting the rear end tonight. Will get the cover powder coated. Will finish it up tomorrow.
Did a mock up tonight of the -6 fuel line. Will change out the fittings to the tank to minimize connections and get a better angle. I'm concerned with it sticking out to far (seen below) and the rear might make contact. Will play around with it more tomorrow.
Thanks,
Old 10-31-2015, 09:01 PM   #212
HUB
Needs more cowbell
HUB's Avatar
I also tried to install the poly bushing for the rear tonight, but wasn't sucessful. It appears the new poly bushings OD are about 4mm larger than the openings for the rear arms. Reach out to IPD to see if this is accurate.
Old 11-01-2015, 03:51 PM   #213
HUB
Needs more cowbell
HUB's Avatar
Default Wilwood Big Brake (Front) Conversion and Rear End
Finished painting the rear. Will have to wait on other parts before putting it together.
Powder coated the original caliper brackets today too.
Thanks,
Old 11-09-2015, 12:31 PM   #214
cwdodson88
looking good! I cant wait to see where this goes!
Old 11-09-2015, 12:58 PM   #215
HUB
Needs more cowbell
HUB's Avatar
Thank you. Still waiting on the front HUBs. Will order springs for the rear Friday. Need to get the rear trailing arms fixed. My goal is to be able to get her on the ground in the next 2 weeks.
Old 11-13-2015, 10:36 PM   #216
HUB
Needs more cowbell
HUB's Avatar
Worked on the front hubs and brakes.
Thanks,
Old 11-13-2015, 11:38 PM   #217
fortbrick
fortbrick's Avatar
Looking good! That brake setup makes me want to figure something out for my wagon soon.
Old 11-14-2015, 06:45 PM   #218
HUB
Needs more cowbell
HUB's Avatar
Default Rear End Bushings Installed and Tie Rods Installed
Installed the bushings tonight and put on the tie rods (will adjust later).
Thanks,
Old 11-15-2015, 05:35 PM   #219
HUB
Needs more cowbell
HUB's Avatar
Well I got the end links in and few other things in for the rear. Need to drop the tank to put in a new fitting for the new fuel line (-6). Will replace the sending unit and repaint it when I have it out. Hopefully I don't find any surprises when I'm in there.
Took out the seats today (planning on putting in new ones/ different ones). Also will need the room to modify the tunnel. Discovered some surface rust under the seats. Doesn't seem to have gone all the way through and isn't very pitted, so will clean it and paint it.
Thanks,
Old 11-15-2015, 10:33 PM   #220
cwdodson88
Thats all coming along nicely! Thanks for the pics, do you have any of the back rest lower stays?
Old 11-16-2015, 08:38 PM   #221
Old Iron
I Roll
Old Iron's Avatar
Thats an understatement, looks great!
Turbobricked
Old 11-16-2015, 09:27 PM   #222
HUB
Needs more cowbell
HUB's Avatar
Thanks for the support everyone!
Old 11-16-2015, 09:29 PM   #223
HUB
Needs more cowbell
HUB's Avatar
No, but I can get more pics for you this week. I left the car emptied out in case you needed more.
Old 11-18-2015, 08:29 PM   #224
HUB
Needs more cowbell
HUB's Avatar
Default Reassembling Read End
Started putting the rear end back together tonight.
Don't like that the new bearings sit out further. Will need to investigate.
Thanks,
Old 11-18-2015, 09:14 PM   #225
evolvo67
evolvo67's Avatar
That's definitely a problem. The lip seals need to press in there also. Must be wrong bearing or their not all the way seated.
