Old 10-17-2015, 05:21 PM   #26
amerbritcan
Hnnnnnng
amerbritcan's Avatar
I've seen thermostats fail like that, but not on a Volvo. Best wishes for your mom. I can't wait to see what else gets pink treatment.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 10-17-2015, 06:06 PM   #27
RasAdam_JAHMEN
RasAdam_JAHMEN's Avatar
Yeah, must have been a cheap brand. Thanks! I got a couple things left to paint...haha
Build Thread
RasAdam_JAHMEN is offline   Reply With Quote
Old 10-22-2015, 01:32 AM   #28
RasAdam_JAHMEN
So its a little off topic, but its the reason why i haven't made progress. I found a nice 1990 740 turbo wagon in the neighborhood and made an offer and got it cheap.
It was sitting for 4 known years but jumped and started right up. Barely chugged home, but I'm surprised it even ran.
Replaced/Cleaned it all up and it runs like a champ! I can finally ditch the Ford Explorer DD.
Old 10-22-2015, 11:31 PM   #29
turbotankshane
^Damn!
Wish I could say that's the worst I've seen
Old 10-23-2015, 11:07 PM   #30
RasAdam_JAHMEN
Woowww, haha.
Old 10-23-2015, 11:13 PM   #31
Hotdoggin
Hotdoggin's Avatar
hahaha I saw your blue 240 on craigslist... What'd you end up paying for the 740?
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 10-23-2015, 11:16 PM   #32
RasAdam_JAHMEN
I had a little time before school to paint my valve cover.
Ive been spending a LOT of time at school carving a wood block and finally finished and got it printed. Should have some more free time coming up now that thats over haha.
Its 8ft wide by 4ft tall...huuuge.
For a size reference, they had to use a steam roller as press a to print it. Kinda cool its a Volvo haha.
It actually might make a really awesome headliner!
All thats left is to prep/paint the bay, put the engine together, and drop it in. Then i can be on the road again!
Old 10-23-2015, 11:20 PM   #33
RasAdam_JAHMEN
Hahaha, niceee. Its actually my brothers, i got him to buy it for his first car haha. Got the 740 for $650. The most expensive Volvo the family has hahaha.
Old 10-27-2015, 02:04 AM   #34
RasAdam_JAHMEN
Made some more progress tonight. Timing cover and backing plate were too dirty to put the rest together.
Finally coming together...
Old 10-27-2015, 10:33 PM   #35
RasAdam_JAHMEN
I had school all day today and its been raining since i got home so i haven't done any work today, but something awesome came in the mail today...
The first ever (according to my knowledge and research) LH 3.1 Turbo Chip! Thanks turbotankshane! The motivation is reeeal
Old 10-28-2015, 11:03 PM   #36
Pappy325
Sweet I want to paint mine deep purple.
Pappy325 is offline   Reply With Quote
Old 10-29-2015, 12:48 AM   #37
Mylesofsmyles
That's a transmission cooler you have there.
Old 10-29-2015, 01:30 AM   #38
RasAdam_JAHMEN
Yeahhh, i found that out haha. Im still gonna try to use it as an oil cooler.
Midnight purple would look kinda cool. Not sure where you would find that color high temp paint though.
Anyone install one of the round-toothed blue Gates Racing timing belts? Mine seems like the distance between the teeth on the belt are closer together then the teeth on the camshaft gear.
*edit* I found out why the belt won't fit...i assumed the round toothed belt would fit on the square toothed gears but turns out (who woulda thought) it won't haha.
Old 11-01-2015, 02:59 AM   #39
RasAdam_JAHMEN
Got the timing belt on and the intake manifold clean and bolted down.
Ive also been prepping the bay for paint but don't have pictures. My goal is to be on the road by November 14th. Gotta put in work!
Old 11-02-2015, 11:00 AM   #40
RasAdam_JAHMEN
After a long fight with the exhaust manifold studs, i put in some fresh ones and mounted the manifold and turbo.
I also got the oil feed line on and mocked up the return line. Gotta do the rear main seal and the crankshaft cover gasket before i can put the oil pan on.
Old 11-03-2015, 09:22 PM   #41
RasAdam_JAHMEN
I was thinking about an easy way to stiffen up my engine mount/s and a friend came over with his old 240(sx) homemade hockey puck mount. Its two hockey pucks back to back with a hole drilled through the middle and a bolt running through them. Turns out they're the exact same size as the original passenger side (US) mount only not made out of jello. The bolt he used had a standard nut but it turns out the locking nut from the old mount fit it as well so I'm using that one.
Ive also been working pretty hard to remove my fingerprints...
No power sander or sanding blocks around...figured id just stick it out. Almost done, then bondo time and some more sanding. (everything that looks like rust...IS rust)
I had a question and maybe someone on here knows a way. The top by the cowl has rusted these little holes through and i was trying to come up with a simple way to cover em up and smooth em out without knowing how to weld. I used a JB weld and thin metal sheet method to patch holes on an aluminum boat hull that i was thinking might work her but it most likely won't be too smooth.
Getting close...little over a week left...
Old 11-04-2015, 11:52 AM   #42
TempleUWS6
TempleUWS6's Avatar
Maybe some fiberglass bondo?
'90 245 DD
'79 242DL
'02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5
'76 BMW R75/6
TempleUWS6 is offline   Reply With Quote
Old 11-04-2015, 12:38 PM   #43
mbolton1990
mbolton1990's Avatar
You need a extra 240 Classic Multi-X wheel?
'93 245 Classic #902/1600
'85 190D 5-Speed
mbolton1990 is offline   Reply With Quote
Old 11-04-2015, 12:46 PM   #44
740atl
educator monkey
740atl's Avatar
Looks like a fun project. Love the pink paint.
Old 11-04-2015, 06:19 PM   #45
RasAdam_JAHMEN
Thats kinda what i was thinking, but not with bondo (since I've never worked with bondo before and wasn't sure if that would work). I used fiberglass cloth and epoxy resin on a spot on my hood when i got the car but it didn't feel strong enough. I ended up using this strong mesh cloth i pulled outta some concrete board and "gluing" it in with the bondo. Feels strong and it should look decent with some sanding and paint.
Before sanding...
mbolton1990: Im actually missing two of those multi-x wheels but I'm not too worried, they're really small haha. Thanks though!
740atl: It really has been! Probably not worth the time and money to most people, but I'm learning for the next one haha. Thanks, I'm liking the pink more and more. I'll admit, I was definitely skeptical at first haha.
Old 11-04-2015, 08:05 PM   #46
Old Iron
I Roll
Old Iron's Avatar
Engine looks incredible, love it!
Turbobricked
Old 11-04-2015, 11:01 PM   #47
RasAdam_JAHMEN
Thanks man, I'm trying haha
Old 11-08-2015, 12:39 AM   #48
RasAdam_JAHMEN
Well it's been a pretty productive weekend so far...
I painted the subframe and stuff with a "rust killing/preventing" paint
I finished sanding and masking the bay
Which led to this...
And then this...
Im pleased with how my first time spaying went. I definitely shoulda taken everything out though...not enough space for the gun in there.
I also started cleaning up the rest of the aluminum parts with this little guy
Almost ready to drop the engine back in. Just gotta dress it up real quick.
Old 11-09-2015, 01:23 AM   #49
Curt_pnw
Man, this is pretty cool. I dig the bay color. The pink is going to pop once you put the engine back in.
GARAGE | 85 245
Curt_pnw is offline   Reply With Quote
Old 11-09-2015, 01:26 AM   #50
RasAdam_JAHMEN
Thanks man! Yeah, the pink looks great with this color haha, I held up the coolant pipe next to it
