Old 05-18-2017, 06:21 PM   #201
Tfrasca
Tfrasca's Avatar
Originally Posted by slammed145 View Post
Dude! Whoa!
BTW, you can buy different length cheapie steel velocity stacks from aftermarket aircooled VW catalog companies like CIP1 or JBugs. CB Performance sells really nice die cast aluminum ones too. But what you did is way more awesome!
Damn, I wish I'd seen CB Performance before... I needed aluminum stacks, so they could be welded in. Some of the CB ones look like they'd have worked. Oh well, at least I learned a new thing!
Tfrasca is online now   Reply With Quote
Old 05-29-2017, 10:49 AM   #202
Tfrasca
Tfrasca's Avatar
So, I got all my manifold parts fit up yesterday, and brought it all to Noah's to have him tack it together. The good news: it fits in the car. Clears the booster by over an inch, doesn't hit the heater valve, and with some minor adjustments, it will definitely work.
I have to trim the front face of the plenum back 20mm to give me more room for throttle body/IC pipes. I'll also slightly re-do the upper radiator hose to help in that area.
When I was "designing" it, I got too concerned about clearance on the booster side, and the plenum ended up too close to the #1 injector plug. (Injectors mounted in Kjet holders, means the plugs have to face the manifold, not the head.) To remedy this, I ordered some phenolic spacers.
Here are the STS machining Kjet plugs that I drilled out for EFI injectors:
Old 05-29-2017, 12:37 PM   #203
HUB
Needs more cowbell
HUB's Avatar
You making an extra manifold for me? Wink wink.
Looks amazing!
Thanks,
HUB is offline   Reply With Quote
Old 05-29-2017, 03:53 PM   #204
JPS
you make it look so clean! good job. what powergoals you shooting with that m41 gearbox?
JPS is offline   Reply With Quote
Old 05-29-2017, 03:57 PM   #205
Tfrasca
Tfrasca's Avatar
Thanks! I do like a clean engine bay, so that's been a motivating factor.
I have no delusions that the M41 will hold up for long. I have an 8 psi wastegate actuator on it now, and I'm hoping to keep it at or below 200 hp until I can get around to the transmission. I didn't want to tackle the transmission and the rest of the engine stuff all at once, and this gives me some time to decide between T5 or Getrag 265.
Once the transmission is up to par, I'll crank up the boost and hope for ~250 hp/tq.
Old 05-30-2017, 09:35 PM   #206
VQ
Not such a PRVert Anymore
VQ's Avatar
Nice build! Done thought out and without being pretentious!
I'm also a big fan of these wheels, seems they fit better under a 122!
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 05-31-2017, 04:30 AM   #207
12david34
damn , this is a really nice build!!
K-Jet über alles.
12david34 is offline   Reply With Quote
Old 06-07-2017, 06:58 PM   #208
Tfrasca
Tfrasca's Avatar
Oh my god.
Old 06-07-2017, 07:23 PM   #209
AndrewNance
Amateur hour!
AndrewNance's Avatar
'71 142
'80 245
Feedback
Old 06-07-2017, 07:25 PM   #210
Tfrasca
Tfrasca's Avatar
Originally Posted by AndrewNance View Post
Me too! I have a lot of observations and feelings about this car now, but all I can muster is "oh my god"...
Old 06-07-2017, 07:31 PM   #211
cwdodson88
Sweet! Taking it to ipd?
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-07-2017, 08:16 PM   #212
Coupid
Coupid's Avatar
Originally Posted by Tfrasca View Post
Oh my god.
congrats! would love to hear some driving impressions when you have recovered lol
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 06-07-2017, 08:28 PM   #213
toms_elleck
toms_elleck's Avatar
WHOA! Congrats! Looking forward to Canepa!
-Thomas
toms_elleck is offline   Reply With Quote
Old 06-07-2017, 09:03 PM   #214
sksmith
sksmith's Avatar
Good to see you finished this, and great fab skills also!
Old 06-07-2017, 10:38 PM   #215
Tfrasca
Tfrasca's Avatar
I wish. I would need a solid month of daily driving/shaking it down before I'd attempt that drive.
So far I've just been breaking in the engine by doing pulls/decel from 30-50ish. At first I had the wastegate hooked up and a jerry rigged throttle cable that made the car an on/off switch. That didn't work, so I unhooked the wastegate and have since sorted out the throttle cable to make it driveable. From what I can tell so far, it feels MUCH faster at about 1 psi than the old B18.
This car has a 4.30:1 axle, so it will break the tires loose at one psi without really trying. Quite a different car, and I haven't even gotten into the boost yet!
Thanks! Hopefully I can get it cleaned up a bit. I forgot how gross a car can get when it sits for 7 months and you don't pay attention to anything but the engine bay.
Thank you. I wouldn't call it finished quite yet, but this is a huge step. And honestly, there's no way I'd have made it this far without Noah doing the TIG stuff. I'll post some photos of the intake manifold later, he did an amazing job on that.
Old 06-08-2017, 04:10 AM   #216
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Congrats on getting the beast running.
Yeah, I may be driving the '92 down to iPd, since I will have even less time after doing the swap on my 242 (doing this Sunday and Monday), so it likely won't be ready for the trip down on Friday.
-J
Old 06-08-2017, 09:06 AM   #217
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I saw the instagram story, and got butterflies, this a great build, I still vote you break it in driving to IPD.
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 06-08-2017, 11:22 AM   #218
cwdodson88
I'm finishing my 8.8/t5 install this week and driving it to ipd, where's your sense of adventure!
Old 06-08-2017, 11:58 AM   #219
Uncleknucklez
bruspeed
Ha! I have 250 miles on my B230ft/T5 swap in my '80 242, and last night I tore it all apart again to install a new clutch/PP combo, that won't even arrive until Monday! Should be fun.
Old 06-08-2017, 01:06 PM   #220
Tfrasca
Tfrasca's Avatar
I'm not normally one to shy away from ill advised road trips, but this would be a real roll of the dice. Currently in this car are the first transmission, turbo, and engine that I've ever rebuilt, a rear end with way too much gear lash, and a host of other issues that I had deliberately forgotten about while doing the swap.
That said, I'm pretty excited to shake it down and sort out all these issues... within a 200 mile radius.
Old 06-08-2017, 03:04 PM   #221
John242Ti
John242Ti's Avatar
^Either ride up with Pat, or use your daily...
Anyway, nice work.
-J
Old 06-09-2017, 04:42 AM   #222
HUB
Needs more cowbell
HUB's Avatar
Good for you. Lets see the finishing shot of the engine bay!
Old 06-09-2017, 09:27 AM   #223
vintagewrench
vintagewrench's Avatar
WAY-TO-GO enjoy all of your hard work and good luck w/it!
Old 06-09-2017, 09:43 AM   #224
Tfrasca
Tfrasca's Avatar
Thanks, guys. The engine bay is not quite finished, as I had to redo the IC to throttle pipe, so there's a unpolished steel (gasp!) one in there now. The idle motor also is not hooked up because of that, so cold starts are pretty annoying. I'll post some 'finished' pictures in a couple days.
Old 06-09-2017, 01:30 PM   #225
JPS
yeah its running! sweet.
I also don't have the idle motor fitted (plugged the holes), but cold start are no problem at all. when i cold start the car it fire's right away, and idles at 600rpm. when the engine is hot the idle is at 800.
is your brake booster in a good condition? i have had 4 140s and 1 of them had a good working booster, all the other where shot.
