Old 12-27-2016, 08:26 PM   #101
quillc
yv1a.com
quillc's Avatar
That's an idea. I'll have to find some.
https://www.amazon.com/HELLA-0034278...words=hella+h4
https://www.amazon.com/HELLA-0031770...words=hella+h1
https://www.amazon.com/Headlight-Rig...s=LED+h4&psc=1
https://www.amazon.com/CougarMotor-H...eywords=LED+H1
Chris
www.yv1a.com
Old 12-27-2016, 09:14 PM   #102
t8fanning
8v are still cool, right?
t8fanning's Avatar
That makes my life easy. Are the low and high beams not the same size? The h4 reflectors above are 190x132mm and the h1 reflectors are 164x103mm.
1982 242 Turbo.
Old 12-27-2016, 09:36 PM   #103
M.H. Yount
M.H. Yount's Avatar
The euro 4x6 Hellas on separate relays ( http://www.danielsternlighting.com/t...ys/relays.html ) and with higher wattage bulbs work really well.
Old 12-29-2016, 03:16 PM   #104
quillc
yv1a.com
quillc's Avatar
sorry sent you the wrong link: https://www.amazon.com/Rectangular-E...ds=hella+Ecode
Old 01-11-2017, 12:43 PM   #105
t8fanning
t8fanning's Avatar
I picked up a MS3 Pro last night. I've maxed out the microsquirt outputs and still want a few more features. I was also never totally happy with batch fire and wasted spark. It'll be nice to have full sequential ignition and injection as well as knock sensing capabilities.
I've made an excel sheet with the pinout and what I plan to do with each pin. Some of the stuff is for future use, but I'll put them in the harness now. If anyone cares to look at it, feedback would be nice to see if I'm forgetting something.
https://www.dropbox.com/s/25eie74cbn...ring.xlsx?dl=0
Old 01-11-2017, 02:04 PM   #106
cosbySweater
cosbySweater's Avatar
nice choice. is that the newest box? i just did a ms3 pro setup on a lt5 and it works great
Old 01-11-2017, 02:09 PM   #107
t8fanning
t8fanning's Avatar
I don't know how new it is. It's definitely not the one they just released. I got it for a deal from a DIYAutotune distributor in Egypt who had a surplus, so I don't know much about it. I need to test it before my PayPal protection is over.
Old 01-11-2017, 02:34 PM   #108
cosbySweater
how much you pick it up for?
Old 01-11-2017, 02:35 PM   #109
t8fanning
t8fanning's Avatar
$850
Old 01-11-2017, 02:49 PM   #110
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
yeah power that thing up. what'd you end up paying for it (if you don't mind..)
never mind on the price. had the reply typed up and got side tracked lol
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 01-11-2017, 02:52 PM   #111
t8fanning
t8fanning's Avatar
Ha. Yeah, not much cheaper, but enough to make me pull the trigger. I'll probably power it up later this week.
Old 01-11-2017, 09:57 PM   #112
bobxyz
bobxyz's Avatar
Ohhh, Ahhh, that's nice! Having a MegaSquirt with knock sensing, long term fuel trim, and a check engine light would be great. Anyone know how well these 3 extra features actually work?
Old 01-17-2017, 08:04 PM   #113
t8fanning
t8fanning's Avatar
It works!
Old 01-18-2017, 07:55 PM   #114
t8fanning
t8fanning's Avatar
I made a 48 tooth tone ring for my Truetrac for eventual digital dash speedo and traction control information. The axle is getting rebuilt this Friday hopefully for installation this weekend.
I've attached the dxf and Solidworks model I made to waterjet it because I don't think they should sold for as much as they are and I like open source stuff. The intrepid user should be able to make their own or have a shop cut it out for them. To get a nice interference fit I rolled it a couple times in the sheet metal roller. It should be ok without rolling if you heat it up a little and cool the differential. For what it's worth, I pushed my tone ring on by hand with no heat and can pick up the whole differential by it, so when it's fully installed no welding to the diff will be required.
Old 01-19-2017, 03:56 PM   #115
Gnomestur
Gnomestur's Avatar
more....must have more! also a link to your friends audio build if he has one!
Gnomestur is offline   Reply With Quote
Old 01-30-2017, 01:32 AM   #116
t8fanning
t8fanning's Avatar
After parts getting delayed a week due to bad weather in Portland, I finally got my axle back and installed. A local Jeep guy who has rebuilt upwards of 100 Dana 30s did the work for me. It was his first Volvo axle. He said the pinion nut is the same as some Toyota axle and one of the wheel bearing retainers is the same as some Ford. Other than those two things, everything else is the same as a Jeep. I was a little nervous about the tone ring interfering with the pinon because it's an early 1031 axle, but my fears were unfounded. The tone ring fits fine and I decided to tack it on just to be safe. I also didn't need to space the sensor at all. I haven't checked the signal, so I don't know if it's close enough, but it doesn't hit the ring. I'll see what it looks like when I wire up MS3 Pro.
I'm really happy with it. It's a night and day difference when compared to the open diff. I still don't have any traction though, especially when I launch. I need some bigger/better tires.
Old 02-20-2017, 12:27 PM   #117
Lord_Athlon
Just damn
updates
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 03-10-2017, 03:14 AM   #118
Gnomestur
Gnomestur's Avatar
get it dialed in yet?
Old 03-16-2017, 11:25 AM   #119
t8fanning
t8fanning's Avatar
I haven't messed with the car at all lately, just driving it every day with no problems while I've been slowly collecting wiring parts. I finally have enough of those parts to start rewiring.
I made a box for ms3Pro and my fuse/relay box:
It just fits behind the kick panel:
Last night I took the intake manifold off and removed all the microsquirt wiring. I want to clean up the stock wiring a bit and remove what I'm not using. What's the best way to get some wires out of the stock firewall pass through without messing up too much wire sheath?
Also, does anyone know what each of these go to? I know one is for checking dwell and one is for activating the starter, but I don't know the rest. Worst case I just check through the greenbook.
Old 03-27-2017, 12:10 AM   #120
Gnomestur
Gnomestur's Avatar
Where do you go to dyno?
Old 03-27-2017, 12:14 AM   #121
t8fanning
t8fanning's Avatar
I haven't gone to a dyno yet. There are a couple local shops though that I could try out.
I'm neck deep in wiring ms3. I'll have a real update soon. Hopefully I'll be done in a week or so.
Old 03-27-2017, 12:44 AM   #122
Gnomestur
Gnomestur's Avatar
What do you think you'll put down?
Old 03-27-2017, 12:45 AM   #123
t8fanning
t8fanning's Avatar
Goal is 400 whp on E85. I think it'll be pretty attainable
Old 04-06-2017, 04:46 PM   #124
t8fanning
t8fanning's Avatar
I've made a bit of progress lately, but it's been much slower than I'd like.
The engine side of the harness is almost done, just need a ground ring terminal:
I also picked up some new wheels:
They're 17x8 and 17x9. I'm thinking of using 225/45r17 and 245/40r17 for my tires.
I'm hoping to finish up the interior wiring and get it running again this weekend.
Old 04-06-2017, 05:44 PM   #125
Quin
ಠ_ಠ
looking forward to seeing the car on those wheels.
