Old 10-29-2017, 03:09 PM   #201
MrBrown
You like popsicles?
MrBrown's Avatar
Man. Just read through your thread. You have had more issues than I could bare and you still just keep persevering like a boss. But then it dies again... Damn.
How you keep blowing head gaskets is unbelievable. First step I would do is get that lower belt cover and set that crank in the correct position and can timing. Right now you’re blind times. Could be causing more issues than you like. Even the idle/stalling coming to a stop.
Where are we standing now? Details.
GhettoFab build thrizzie
Old 10-29-2017, 03:10 PM   #202
MrBrown
You like popsicles?
MrBrown's Avatar
PM me your address. I’ll send you some orange body injectors on me. I have dozens.
Old 10-29-2017, 03:29 PM   #203
Cwazywazy
Cwazywazy's Avatar
Actually, the first time I replaced my headgasket I diagnosed it wrong. The second time it was definitely blown. I think I got the timing to -10 at idle, but I'm not sure I got it right. I managed to mostly eliminate the issue with it stalling when coming to a stop, but obviously it's back now that it only has 3 cylinders. Luckily, I have my other 240 and a family backup car (RAV4) so this car constantly breaking down isn't that much of an issue. I just gotta get around to rebuilding the engine that originally came with this car. And get a WB.
I will take you up on those injectors. PM incoming.
I don't know what I have
Cwazywazy is online now   Reply With Quote
Old 10-29-2017, 04:31 PM   #204
okoye
okoye's Avatar
What FPR are you using? stock 240 one?
okoye is online now   Reply With Quote
Old 10-29-2017, 08:14 PM   #205
Cwazywazy
Cwazywazy's Avatar
I assume whoever did the +t wasn't dumb enough to use the stock one. But said previous owner also left the original Chrysler box and unplugged the knock sensor...
I should stop assuming things. I was planning on buying a WB about now since I just bought an Ostrich from another user. I did have one, but it wouldn't work right and had to return it.
Old 10-30-2017, 05:08 AM   #206
okoye
okoye's Avatar
My advice is to take the fuel pressure regulator off and check that it is indeed a 3 bar. I never assume people do things right unless I'm watching or doing it myself. pull the 3 bolts and take the fpr off and check the part numbers. Some will say 3bar or 2.5 bar others will just have part numbers stamped in. Use that to figure out which one you have on there.
Old 11-03-2017, 03:08 PM   #207
Cwazywazy
Cwazywazy's Avatar
All bearing surfaces and bores look fine to me, which I'm very happy about. Gave it a few coats of engine paint. Hopefully, if I work fast, I can do this before it gets really cold. Obviously this time I'll be replacing the injectors and getting a WB.
I also had to replace my carrier bearing recently, made a nice racket when it let go.
Old 11-03-2017, 10:56 PM   #208
kampman
dunning-krugersquirt
That second bearing from the left doesn't look so healthy...?
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
kampman is offline   Reply With Quote
Old 11-04-2017, 12:07 AM   #209
Cwazywazy
Cwazywazy's Avatar
Oh, forgot to mention that. Crank jounal seems fine, can't feel anything with my fingernail. Must've been a piece of aluminum or something soft.
Old 11-07-2017, 10:22 PM   #210
Cwazywazy
Cwazywazy's Avatar
Oops. Was measuring ring gaps and I noticed a couple cracks in the #2 piston ringlands. The remaining two pistons are fine. Now I gotta order another one...
Weirdly, I only had low compression on the #4 cylinder. (Piston on the right.)
Old 11-07-2017, 11:18 PM   #211
MrBrown
You like popsicles?
MrBrown's Avatar
Dang son. That’s crazy.
Wife keeps forgetting to ship your injectors. They are sitting there. I’ll try and get them out tomorrow.
Old 11-07-2017, 11:19 PM   #212
matt b
Are you getting your crank polished ? I wouldn't trust a fingernail test to confirm that a crank is not damaged from that bearing.
Old 11-09-2017, 05:18 PM   #213
Cwazywazy
Cwazywazy's Avatar
New piston doesn't fit. It's about 1mm out of round at the bottom of the skirt.
EDIT: I'm an idiot. Bought an oversize piston.
Old 11-09-2017, 05:43 PM   #214
Now's your chance to drop some B230ft pistons in there.
Old 11-09-2017, 06:03 PM   #215
Cwazywazy
Cwazywazy's Avatar
But lower compression means more slow?
And less blow uppy, I suppose.. I would just grab a couple from the engine currently in the car, but it has a ton of piston slap so I dunno.
There's a turbo 7 series at the junkyard I plan on grabbing the T3 from tomorrow. No shaft play. Dunno why it's there though, no crash damage.
Old 11-09-2017, 06:48 PM   #216
No lower compression means moar boosties and much fasts.
Old 11-09-2017, 07:25 PM   #217
Cwazywazy
Cwazywazy's Avatar
I like the sound of that. I'll give you $14.99 for a set.
Old 11-09-2017, 07:29 PM   #218
Pluck them out of that 740 in your JY, or run up the road to FCP scrotum and lay your money down.
Old 11-09-2017, 11:01 PM   #219
MrBrown
You like popsicles?
MrBrown's Avatar
Old 11-10-2017, 12:06 AM   #220
Cwazywazy
Cwazywazy's Avatar
I'm tempted to just take the whole engine, only $80 more than 4 pistons. But I'm skeptical because the car has no accident damage so who knows..
Old 11-10-2017, 12:26 AM   #221
Engine oil look good?
Poopy transmission / metal in the pan?
Rusted out / blown out interior?
They're getting pretty rough by now when they land in the yards...
Any paperwork in the car that might provide a clue as to the downfall ?
Old 11-10-2017, 12:58 AM   #222
Cwazywazy
Cwazywazy's Avatar
I'll have to do some investigation. This isn't a very good yard, they just plop the cars on the dirt without wheels.
Old 11-10-2017, 10:12 PM   #223
Cwazywazy
Cwazywazy's Avatar
Decent haul today. No turbo, couldn't get the bottom exhaust nut, couldn't find a sawzall, and I wasn't about to wait for the guy in the loader to pick the car out of the corner of the yard just for the turbo. Still though, I got a 960 fan, turbo FPR, 5 Virgos, etc. And I saw this mint 940, someone should buy it.
Old 11-10-2017, 11:54 PM   #224
Stiggy Pop
Stiggy Pop's Avatar
Which yard?
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 11-11-2017, 12:25 AM   #225
Cwazywazy
Cwazywazy's Avatar
Originally Posted by Stiggy Pop View Post
Which yard?
Sam's u pull it, way up in Worcester. I was up there buying the Virgos anyway.
