Old 01-20-2017, 12:32 PM   #26
Mr. Blewregaurd
Mr. Blewregaurd's Avatar
War paint on
"It's only temporary if it doesn't work."- Red Green
'85 244 N/A Auto-x money pit
'68 220 Arts and crafts project
'04 Ranger DD/Mobile home
Mr. Blewregaurd is offline   Reply With Quote
Old 01-20-2017, 12:32 PM   #27
Mr. Blewregaurd
Double
Old 01-20-2017, 01:46 PM   #28
InTheWhite
InTheWhite's Avatar
Realy nice looking car you got there!
Old 01-23-2017, 05:57 AM   #29
Estoque
Estoque's Avatar
Nice car you've got there! Came across it on Instagram and gave you a Follow!
Keep up the good work!
Compensate bad aerodynamics with BST - Volvo 245 B230FT Turbo
Estoque is offline   Reply With Quote
Old 01-23-2017, 10:51 AM   #30
Mr. Blewregaurd
Thanks! Thats kinda my company feed, so you'll see a bit more day to day stuff from around my shop too.
SO on to this weekends activities. Woke up and went to coffee, and the car started cutting out past part throttle. so I came down to the shop real quick and found a dead pre pump. Pulled it and found it already had the bigger pump but someone put the old torn accordion hose back on. Changed that out as well as some new rubber lines to the main pump and a new fuel filter. Also swapped in a sligthly less leaky saginaw pump while I wait for STS to make another run of PS brackets.
Took the car out to run a local drive called the peak to peak, a 70 ish mile loop of some of the best driving roads in colorado. Trail by fire, 0 cell reception for the majority of the drive. This car continues to surprise me. It has far surpassed any expectations I had for it.
In reading through the small novel that comes with the JRZ dampers, there is a sentence in the section talking about the dampening adjustment. It says " there are 32 different clicks to choose from, and each individual click will result in a noticeably different ride quality." Yeah right I say. So I start by cranking It down 4 clicks thinking that's about what it would take to get a slightly different ride. WRONG. It was like driving a totally different car. They really are something else. Photo for the interest
Spent half the day on sunday working on the paint. Picked up a DA polisher from Harbor Freight and went to town.
Not bad for having no idea what I'm doing
Old 01-23-2017, 12:02 PM   #31
Marvelous3
Who engineered this?
Marvelous3's Avatar
Damn! That thing is clean!
Marvelous3 is online now   Reply With Quote
Old 01-29-2017, 11:43 PM   #32
Mr. Blewregaurd
Well, I blew up my engine yesterday.
Went out for a drive with some friends, made it about 5 miles in, got a huge cloud of blue smoke and a stall. 0 cranking compression. [facepalm] Hitched a ride back to town to get the shop truck and trailer to drag it back to the shop.
Ran a comp test, got 25 psi across the board with 95% leakage past the rings on all cylinders. Lots of glitter in the oil. Best theory I've got right now is that I either got the wrong rings, or I didn't set the ring end gap and it ran too tight until the walls were completely trashed. I sat there and stared at it a while deciding what the hell to do with it and just decided I was gonna swap in a 120k 93 940 bottom end I had along with a super low miles m46 I had been saving.
Mid battle
Worked straight through until 4 am and got it running again. When **** goes wrong like this I just have to fix it as fast as I can or i'll go insane. Anyways, Its running A LOT better than it ever did. Something was just never right in that motor. Ill post some failure pictures tomorrow
Old 02-21-2017, 10:06 PM   #33
Mr. Blewregaurd
Car has been humming along great. Picked up a strut bar and master cylinder brace along with some new wheel studs from Ben. Can't believe the difference that master cylinder brace makes in pedal feel.
They run a little grass roots time attack series here at pikes peak race way that I will be competing in. First race was this last Sunday. Getting my numbers ready. Had to do a Volvo font
Some action. One thing that became clear after seeing these is that I need a catch can...
Official results. I'm pleased, considering this was my first time ever on a track. This series is classed by power to weight and tire size. B class is no more than 12 lbs/HP, and no larger than 2 sizes bigger than factory tires. Considering in at 19lbs/hp if i'm being generous with my HP estimation, and only one size bigger than a factory tire, I think im off to a fine start
Old 02-22-2017, 05:19 AM   #34
Ginger Ninja
Ginger Ninja's Avatar
This has been popping up in my Instagram feed recently too. Looks great. I like the focus on handling over power.
'88 245
'88 245 turbo
Ginger Ninja is offline   Reply With Quote
Old 02-22-2017, 06:48 AM   #35
Tom Wiley
This thing is dope. Big fan of the style. Keep it up.
Tom Wiley is offline   Reply With Quote
Old 02-22-2017, 09:14 AM   #36
JW240
All idiot, no savant
JW240's Avatar
Really like this! Lovely done.
Old 02-22-2017, 10:03 AM   #37
Matt
ICY HOT STUNTA
Matt's Avatar
boiiii.
this rules. i love n/a builds way more than turbo ones, tbh.
just need to put the front fender wheel opening on the rear quarter and a lil bit wider wheels and tires and it'd be perfect, imo. well, that and a flathood and grille to go with those headlights ;)
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 03-15-2017, 10:38 AM   #38
Mr. Blewregaurd
Decided to shorten and box my trailing arms. Not a really good step by step on here anywhere, so here's how I did It.
Started by cutting 19mm out of the front section of the arm. Decided on this spot because it is fairly straight. I based all my measurements on measuring from mounting hole to mounting hole. So I made my self up a jig out of some 2x4, clamped them and used a drill press to drill holes at the desired new length.
Once I had it tacked, I text fitted in the car
Next up was welding them up with the box plates.
Finished product. Had to use a factory bushing to have it ready for a race on the weekend, as my powerflex units didnt show up in time
Before and after
Had the second time attack race for the year. This one had two cars racing each other on mirror image tracks at the same time. Was super fun. Took my pal Will with me to give me some driving lessons.
Finding the limits
After the first couple runs, we pulled the rear sway bar in an attempt to get the rear end to stay planted. Helped a lot, and we started getting a lot faster
Car still needs some tweaking, but Im very happy with it. We won the majority of our races, and the ones we didn't were due to mistakes. Can't wait to get some more seat time
Old 03-15-2017, 11:12 PM   #39
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Very cool
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 03-16-2017, 07:14 AM   #40
toms_elleck
toms_elleck's Avatar
Hell yeah! Cool car.
-Thomas
toms_elleck is offline   Reply With Quote
Old 03-16-2017, 10:50 AM   #41
SquareD
An Anomaly
SquareD's Avatar
I really like this build. It's simple and yet you've obviously put some considerable time and money into it. Definitely a well sorted na build.
Old 04-28-2017, 05:01 PM   #42
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Originally Posted by Mr. Blewregaurd View Post
Bumping, I like to look at this car a lot.
My hub adapter and column plastic line up the same (meaning not at all) So I take pics of the wheel hiding the gap
I like the size of your Nardi, and may be on ebay right now looking for one just like it.
1980 242 Turbo
2004 V70R
Old 05-04-2017, 03:13 AM   #43
LloydDobler
LloydDobler's Avatar
Way cool man, I like it!
'66 122 - Collectible project
Old 06-07-2017, 09:51 PM   #44
FTY
Car looks planted
What spring rates are you running?
FTY is offline   Reply With Quote
Old 04-18-2018, 10:20 AM   #45
Mr. Blewregaurd
Back from the dead.
Been working on the car some getting ready for race season. Got a second hand homer brake kit recently, and some new fifteen52 wheels to match. New RE71R tires, and a trutrac. One development I discovered is that you can use the mustang master cylinder with Ben's strut brace by using the 240 res. spaced up with some 4x11mm o-rings as the 240 res. goes too deep into the mustang seals.
Yes I bought porsche stickers. sue me
Old 04-18-2018, 10:23 AM   #46
Uncleknucklez
bruspeed
Back from the dead.
YES, all of this is YES
Sell me the steel wheels!
Old 04-18-2018, 10:32 AM   #47
Mr. Blewregaurd
They are in the scrap pile unfortunately. They were horribly bent
Old 04-18-2018, 10:37 AM   #48
Homer
OEMplus++
Homer's Avatar
Yea buddy
-Jacob:
2006 A4 - Comfy DD
Old 04-19-2018, 05:52 PM   #49
Can play the blues
Love seeing some update to this. Such a fun car. Enjoy!
Old 04-19-2018, 10:47 PM   #50
The Full Banana
not yet good enough
The Full Banana's Avatar
This is a cool car. I’m a fan of what you have going on here.
Awesome insight with the reservoir oring spacing. I just borrowed that idea. The mustang reservoir in my car has always seeped brake fluid out the cap and eventually ruined the brake booster finish.
-Tom 1980 242 T5
The Full Banana is online now   Reply With Quote
