Old 05-06-2018, 05:43 AM   #1
maxitoman007
Question Clutch Slip Or Wheel Spin ?
car Is an 87 740 turbo. Running an eBay turbo with eBay header, brown tops, eBay intercooler, external wastegate, etc.
Running 21 psi currently
Was pulling in fourth to merge onto the highway and hit boost at 3k. Rpms shot up fast as boost hit but no pull. Didnít smell clutch but didnít feel the car hook either. My car is loud so I probably wouldnít have heard it if the tires were screeching. Didnít get a chance to see if the speedo shot up with the tach (would indicate wheel spin). Clutch never seems to slip while out of boost and even while doing lower speeds in higher gears (high load) the clutch doesnít slip. Is it common to break the wheels loose when boost hits at 20psi+? Diff isnít welded either.
maxitoman007 is offline   Reply With Quote
Old 05-06-2018, 07:16 AM   #2
nordmaschine
forced instruction
nordmaschine's Avatar
One wheel burnout on crappy tires. Try to recreate and see what happens, our crystall ball servers are currrently down.
Jetronic is romantic.
Whiteblocks
Old 05-06-2018, 10:03 AM   #3
LloydDobler
LloydDobler's Avatar
In my experience if you slip the clutch it gets pretty stinky pretty quickly. Might need to get out of the car and check immediately after though. It can clear up pretty fast as well.
'66 122 - Collectible project
Old 05-06-2018, 01:19 PM   #4
JerryJS8
der Junge
JerryJS8's Avatar
That's going in my signature!!!!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 05-06-2018, 03:08 PM   #5
Happy Mew Year!!!
Stock clutch slippage, I had it in 3rd at 15psi, it's only going to get worse, sorry.
Old 05-06-2018, 07:31 PM   #6
maxitoman007
Well I'm still getting 2 different opinions here. On one hand, it is still the stock clutch and could very well be slipping, but on the other, I have never once smelt the often described has pungent smell of burning clutch...
Old 05-06-2018, 09:57 PM   #7
2manyturbos
Cone clutch in the overdrive slipping. These are good for about 225 HP, then, they slip.
Old 05-06-2018, 09:59 PM   #8
esmth
dirty swede
esmth's Avatar
I still run an NA clutch and it's pretty obvious when it slips, noise wise. Is the turbo clutch any different? Using the m47 dog dish flywheel & clutch kit
Old 05-06-2018, 10:35 PM   #9
maxitoman007
oh, would that affect all gears? I never tested it in OD
Old 05-06-2018, 10:40 PM   #10
2manyturbos
Yes. They will slip in all gears.
Old 05-06-2018, 10:49 PM   #11
JohnLane
As soon as the clutch doesn't slip it has a broken mainshaft or third gear.
Old 05-07-2018, 07:39 AM   #12
Dadssleeper
Dadssleeper's Avatar
I exceeded the stock clutch at 12-15 psi , Not sure how you can be at 21 and not know its slipping. Mine was very obvious , I stomped on the throttle the rpms shot up and the car didn't go with it. My speedometer stayed the same. I never smelt burning clutch because I didn't burn it I just slipped it. I am sure if I would have held my foot into it I could have burned it but there was no reason to I knew what the issue was.
http://forums.turbobricks.com/showth...ight=clutchnet
I was headed over to the thread above to update it this morning.
Old 05-07-2018, 06:16 PM   #13
Trevor57
Trevor57's Avatar
it's easier to slip clutch in higher gears. My car makes 450 whp, and I am on stock steelies with junkyard 195/70/14, and stock diff. I do not spin tires in 4th.
14 Mazda 5 6spd / 86 245 24hol racer / 92 245 / 86 245 lsx ( http://forums.turbobricks.com/showthread.php?t=321150 )
If you start threads, and do not reply to those threads with a resolution, you are a human analog of photobucket.
Trevor57 is offline   Reply With Quote
Old 05-07-2018, 06:34 PM   #14
maxitoman007
Damn... was hoping it wasn't the clutch. Now the debate begins... clutchnet upgraded clutch or T5. Found a Camaro V8 T5 for sale here in Canada for only 300 canadian dollars, don't know if I have the funds to cover all the adapter plates and other things etc though. Not to mention I'm in a 740 so shifter placement... (although I heard the Camaro box moves it back and has the same input shaft or something as the M46? On the T5 all you need to know thread. Some clarification would be nice). What do you guys think?
Damn I wish you could change thread titles...
Old 05-08-2018, 10:04 AM   #15
maxitoman007
Decided to go for the clutch. Went with a clutch net yellow PP and a stock Volvo disc (I think itís a stock one, part # 1377326) has 4 large springs and then 3 smaller green springs on one side. It is Volvo brand just not sure if itís meant for turbo or NA.
Old 05-08-2018, 11:39 AM   #16
LeedomtoFreedom
LeedomtoFreedom's Avatar
Yeesh clutchnet yellow...
Should have done yourself a favor and upgraded the tranny because my crystal ball server is seeing broken teeth in the near future...
81 264 - Driveway ornament
90 245 - becoming 16v
Old 05-08-2018, 12:27 PM   #17
maxitoman007
Don't have the funds to do a t5 right now and the i got a good deal on the PP and disc from sbabbs. Now the real question is run the stock disc or get a 6 puck...
Old 05-08-2018, 02:46 PM   #18
LeedomtoFreedom
You'll probably break the tranny if you want to run a 6 puck. I'm not sure of the claims on the yellow pp (probably all over the place) and what the clamping force is, but if it holds a little more than stock, than that's what you want.
Any more than that and you're getting into dangerous territory, risking breaking your transmission, and then you're left without a running car. I don't think a 6 puck is necessary but I got burned with the red pp from clutchnet so maybe it'll make up for the false claims.
Also a 6 puck is not going to drive nicely. My half n half (not the milk) clutch disc from southbend (240mm) is much snappier than a fully organic disc, not the worst, but a full ceramic 6 puck is probably an on/off switch, especially since it's only a 215mm clutch. I can't imagine what it would be like. Someone in the threads about clutches says that those clutch setups are like a 1960s dump truck.
Old 05-08-2018, 06:18 PM   #19
maxitoman007
its a 228mm but I see where you're coming from. I'm also wondering what kind of clutch disc I'm actually getting from this guy... it has "volvo" printed on it and 4 big springs but then on one side there's an extra 3 small green springs, any ideas? tried looking up the part no and got very little results.
EDIT: After some extensive research, I've determined that the disc is what comes stock in a D24 turbo. Good news? idk.
Old 06-04-2018, 12:26 PM   #20
maxitoman007
Installed the new clutch setup.
Just updated in this thread:
http://forums.turbobricks.com/showth...75#post5806975
