Old 05-18-2018, 07:31 PM   #1
EivlEvo
Default Fine with stock CBV, Stalls with HKS VTA
Squad.
93 245+T 15G 15psi TLAO IPD cam 577cc/min injectors and 012 AMM.
From my other thread on the surging and injectors. I've sorted it. Bad AMM. I also chased down a handful of small vac leaks.
The latest issue was that (I had swapped an HKS SSQV onto the 15g) and the car would idle and drive completely fine, but when I would clutch in or cut throttle to idle (brakes or no brakes so not check valve) the car would not be able to catch itself, and it would stall.
I swapped the stock CBV back on, and everything seems fine.
Swapped HKS back on this time with the thinnest film of gasket sealer on the torque solutions adapter o ring and boost leak tested. No leaks. Rev it up... stalls.
The HKS isn't leaking and appears real with serial #s and all the authenticness I could find info for... what's up?
Does LH need to learn more or...?
Old 05-18-2018, 07:38 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
Pictures of the HKS? there are lots of good fakes out there, I have a fake on my manual wagon that has been working just fine.
Old 05-18-2018, 07:49 PM   #3
LeedomtoFreedom
LeedomtoFreedom's Avatar
I had issues like yours and I found that the IAC couldn't catch the idle quick enough... sometimes it would, sometimes it wouldn't.
Not implying this is your problem, but if you went through the basics, and it's still not working, try disconnecting the iac and see if it helps.
81 264 - Driveway ornament
90 245 - becoming 16v
LeedomtoFreedom is online now   Reply With Quote
Old 05-18-2018, 11:55 PM   #4
EivlEvo
I swapped in a new IACV from my last problem to see what was what. But that's really what it seems is going on. I've tried it with both IACVs (both work, both do the same thing) also TPS'.
Mike I'll snap you some pics... that said, the valve isn't leaking that I'm able to detect in any capacity. Everything I've seen including the packaging AND the included parts seem to indicate it's genuine. But also... would it matter if it isn't leaking?
I really just think the VTA is messing with the car? Maybe I should let it learn on my recirc and THEN swap to the HKS?
Old 05-19-2018, 01:54 AM   #5
centason
Knipex=welfare queen
centason's Avatar
VTA will leave a really rich moment after if blows off. Might want to see if it goes away if you recirc it. My MKIII Supra did that too. Had to tune it to get it right. Does the SSQV still use different color inserts to change the pitch of the blow off? I had the gold insert.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 05-19-2018, 06:51 AM   #6
doucheNozzle
doucheNozzle's Avatar
Why is the stock CBV not sufficient?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 05-19-2018, 08:50 AM   #7
thelostartof
unbalanced chemical
Because the hks has a fun sound. And some of us have issues.
Old 05-19-2018, 12:13 PM   #8
EivlEvo
I actually don't know if they still have the diff colors. I know you can remove the "whistly bits" and you can def swap in a nozzle to recirc it.
TLAO has an entire other thread with the raging debate about the VTA on stock LH. His assessment is that the recirc and the VTA are both giving the same rich moment. Based on my AFRs, I'd agree with this assessment. Maybe I'll just run the stocker while LH dials itself in and then swap over to the HKS...
Pretty much this. I'm a man-child.
I always wanted to be part of the fast and furious crowd, but the car I had at the time with the budget I worked with wouldn't allow it. My Evo is too respectable to roll an HKS, plus... it makes REALLY good noises anyhow. The Volvo is so regular in traffic that I don't even think anyone notices the side exhaust. The HKS is a real neck snapper and the looks of disgust/confusion/bewilderment give me the chuckles.
But I can completely agree that it's stupid.
Old 05-20-2018, 08:53 PM   #9
EivlEvo
As the LH is learning this problem seems to be sorting itself out actually. We'll see how it ends up... and I'll still grab those snaps.
Old 05-27-2018, 10:51 PM   #10
EivlEvo
Pics.
It stalls if I clutch in normally. If I wait until it's below about 1500rpm and clutch in, it can catch itself.
Old 05-28-2018, 06:20 AM   #11
doucheNozzle
Pics don’t work
Old 05-28-2018, 07:09 AM   #12
soclosenotnear
Originally Posted by doucheNozzle View Post
Pics don’t work
Seen to be fine for me
Old 05-29-2018, 03:25 PM   #13
Lord_Athlon
Just damn
A CBV/Bypass will not cause a rich spike.
You can technically get a 2.4 car to not stall out using a bov, but that doesnt mean that LH works fine with it. It means you can get away with it on there, but it will still rich spike because there is missing metered air that the ECU has already calculated fuel for.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 06-04-2018, 07:51 PM   #14
EivlEvo
Squadriceps.
I seem to have solved this issue along with my other issue in maint where my car just all of the sudden went full pig rich (10.0 AFRs).
It was a clogged O2 sensor.
Car works a treat now.
Here's the "good" side.
