Old 05-25-2018, 01:17 PM   #26
Pro Sneaker Peddler
200hp cheap? Slap that hoe with a 125 shot.
Or a 13c
Old 05-25-2018, 01:19 PM   #27
Jack
Banned
Jack's Avatar
I have a W cam for cheap
Old 05-25-2018, 01:28 PM   #28
cwdodson88
What’s that, a Saturday morning and some shopping on summit racing. Sounds cheap, easy and possibly reliable if you have a good engine to start with. Add in a retard box and spray away.
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-25-2018, 01:36 PM   #29
JohnMc
JohnMc's Avatar
I don't have a Σ cam, but it would be oh-so-sweet if I could find one.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-25-2018, 02:31 PM   #30
Jack
Banned
Jack's Avatar
Old 05-25-2018, 02:32 PM   #31
Cwazywazy
Cwazywazy's Avatar
Originally Posted by cwdodson88 View Post
Whatís that, a Saturday morning and some shopping on summit racing. Sounds cheap, easy and possibly reliable if you have a good engine to start with. Add in a retard box and spray away.
Nah, just take the intake off and aim the bottle at the throttle body.
I don't know what I have
Old 05-25-2018, 02:33 PM   #32
Old 05-25-2018, 02:35 PM   #33
Jack
Banned
Jack's Avatar
remove everything out of car, dip your body panels in acid long enough to not burn through
Old 05-25-2018, 02:41 PM   #34
89_740Turbo
89_740Turbo's Avatar
Originally Posted by Cwazywazy View Post
MBC and maybe bigger injectors is all you need. You can go up to 12psi pretty safely on a totally stock setup. If you have LH2.4 there are chips. If you have 3.1 I think you're gonna want to convert to 2.4. Don't forget the EZK box.
12psi on a stock td04-12c turbo? Seems pretty high to me
Old 05-25-2018, 04:12 PM   #35
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
It’s fine
And it’s a 13c
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 05-25-2018, 04:22 PM   #36
89_740Turbo
Originally Posted by PromiseRing View Post
It’s fine
And it’s a 13c
Huh. I'm running a 12c right now, will be upgrading to a 15g at some point, but I didn't know 12psi was ok. TIL.
edit: 12b not 12c sorry
Old 05-25-2018, 07:55 PM   #37
Mbeas96
Mbeas96's Avatar
12b? And I ran 12psi on my 13c with no problem, 16t is just a wee bit funner
I hear any higher than 12 is out of its efficiency range
Old 05-25-2018, 09:30 PM   #38
PromiseRing
Never heard of a 12c. Maybe a 12b? 12 psi is fine. Maybe itís close to pushing hot air but I guarantee itís faster than 7 psi lol
Old 05-26-2018, 04:16 PM   #39
esmth
dirty swede
esmth's Avatar
Originally Posted by StreetForged View Post
I welded my differential less than a week after I got the car. Not too worried about the auto detonating, then I'll have no excuse to go through with AW71 which I intended to do anyway. Just hoping the auto will hold up long enough for me to accumulate a bit of extra spending money.
I also really appreciate the gesture MSGGrunt, I'm on the Mass border so I could definitely make a trip down there if that's the best option.
I'm also on the mass boarder! Another yard to check is brandy brow. I last went 3 weeks ago and they had no rwd stuff rn but they occasionally have them
Old 05-26-2018, 04:58 PM   #40
JanP
JanP's Avatar
Or he should run stock turbo power through an aw70 and tell us how long it lasts. Iíd be curious.
F+T, 15G @ 14psi = 100miles to kill an AW70
-92 240 Wagon
JanP is offline   Reply With Quote
Old 05-26-2018, 08:48 PM   #41
PromiseRing
Hey thatís not bad that will get you to the JY and back!
Old 05-26-2018, 09:37 PM   #42
Broke4speed
Broke4speed's Avatar
Oh how I miss the days when drifting used to be more about car control and suspension and less about 'angle mods', pulling the handbrake on a RWD car to 'initiate', and too-much-power on bald burner tires.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 05-26-2018, 10:05 PM   #43
Happy Mew Year!!!
I used to drift my mom's Datsun 810 Maxima when I was 16 (1983) until I looped it into a mailbox with my younger sister and her boyfriend in the back seat. 2.4l I-6+ 4spd manual. Now I want the car to stick at autocross because it's faster and takes more skill, any mutton head can get the rear tires to spin with a decently powered rwd.
Old 05-27-2018, 11:04 AM   #44
89_740Turbo
Meant the 12b, yea.
I have to figure out how I can add higher boost. I just bought sbabbs chipped ECU for fueling and acceleration, a new manual boost controller and a electronic boost gauge.
I honestly don't feel confident doing it myself because I really feel like ill **** it up somehow. I'm gunna watch a bunch of youtube videos before I do it
Old 05-27-2018, 01:40 PM   #45
Can play the blues
Put the boost gauge in first.
Old 06-06-2018, 05:22 AM   #46
89_740Turbo
Bumping this thread back to the top because I found something pretty interesting. Per this thread - http://forums.turbobricks.com/showthread.php?t=226620 - I went to BSR's website and found this - https://en.bsr.se/tuning-kits/t/778/...40-t-1989-1998 - Its apparently a chipped ECU that provides a +60HP gain (with appropriate modifications of course).
I tried to find threads where people used it but couldn't find anything. Could be worth a shot?
Old 06-06-2018, 08:26 AM   #47
Happy Mew Year!!!
I made 215 hp 230ftlbs of torque to the wheels with stock lh2.2, China Bay 20g ($300),reman brown top injectors ($200) and 3" exhaust (~$100- made it myself.)
Old 06-06-2018, 10:20 AM   #48
PromiseRing
Donít throw your money at stuff that weíve never seen people use. I highly doubt thereís any safe drop in Ďchipí to make 220hp with stock everything. Bigger turbo, more fuel, free exhaust, more boost, better intercooler etc. itís a simple magic recipe that works for essentially any turbo car.
Old 06-06-2018, 03:46 PM   #49
89_740Turbo
I wasnt going to buy it, just a curious recommendation. As far as me, i'm doing all the upgrades you mentioned
