Old 06-01-2018, 01:31 PM   #1
brickborg
brickborg's Avatar
Default 1985 760- The Jurbo Saga
I'm starting this thread to chronicle the goings-on with my turd of a 1985 760 Turbo that my wife has affectionately christened the "Jurbo" (that's pronounced YUR-bo, get it right). The plans are to get the car back to a real stage zero, then add a few go-less-slow parts. My long term goal is about 250hp.
I purchased the car in November 2017 after running across the world's most detailed Craigslist ad- complete with exactly zero pictures and no mention of condition or maintenance at all. What it did mention, however, was the mileage at a hair under 78k original. Called the phone number in the ad, set up an appointment, and travel to the address the seller gave me- a podunk repair shop in the south suburbs of Minneapolis. My expectations were extraordinarily low. The car fired right up, but had idling problems. It died immediately on the test drive the first time I tried to get it to boost, and lots of the interior trim was in the trunk. It died occasionally while moving, apropos of nothing. It was going to need everything rubber replaced from being driven less than 500 miles in the last decade. Bummer. The good news is that the stack of work orders that came with it was thicker than my forearm, it had spent most of it's life garaged in Colorado, and the mileage was verified to really be 78k. Party on. This is what it looked like when my wife and I picked it up-
Neat. At this point, the plan was to park the car in my garage stall at our apartment until I could find a work space for it, then pick away at the things I knew it needed until was reliable enough to be my DD. This did not happen.
Shortly after this purchase, my wife's '98 Accord (RIP to the only rust free Accord in MN) was stolen from our parking lot and totaled. She couldn't drive my MINI, and needed to get to work. "What about the Volvo?" she asked. We had the requisite discussions about the car being old and pissy, and that almost none of the maintenance or repairs that needed doing had yet been done. The Jurbo was then pressed into service as a way to get her to work and back. Turns out, she loves the damn thing warts and all.
Since she was now driving it, I figured I should fire up the parts cannon and get to work. The lack of idle was traced to a flaky IAC- popped it open and was greeted with this-
Mmmm... toasty. Right then- off to ebay for a replacement. Now it idled! Woo.
Where did all the brake fluid go?
Oh yeah. That's not good.
Throw a bunch of money at IPD, aaaaaaaaaaaaaaaand...
Installed the new MC and bled the brakes-
Cool. Now it's significantly less of a deathtrap.
Despite itself, it did start and run for her every day, even when we had a high temp of -2F in February. Once it was warmed up, it ran and drove pretty well. It looks damn good too, which helps.
During these few months, it would still have intermittent running issues and returned an average of 11mpg. Even for a 7er, that's kinda garbage. It was also even slower than a 760 Turbo is normally. After consulting the oracle (read- TB's Maintenance forum), it was suggested that I check the engine timing. I had a timing belt invoice from three months prior in the aforementioned giant stack of records, so I figured it was worth checking. Turns out Podunk McGee's Auto Emporium had timed the motor two teeth off, and the car had been running that way this whole time. In a Minnesota winter. I was blown away. So then, new timing and accessory belts in hand, we did the needful (as well as a bunch of deferred maintenance):
At the same time, we undid all of the bodges the previous shop had made to get it to run with the timing so far out. The car was back on the road- holy hell I had forgotten how much fun boost is. My mojo was restored as the sun set over this beautiful slab of Swedishness.
The Jurbo behaved itself quite well during our house purchase and my wife continued to use it as a daily driver until May of this year when she went out to the car to go to work and was greeted by a car that refused to run. If you grabbed the harness that runs under the intake manifold and jiggle it, it would start and run just fine. Boo.
At this point, I decided that it was going to get parked and gone through completely- the wiring elsewhere in the engine bay was looking very crispy and the vacuum lines were all old enough to remember the Reagan administration, so into the garage it went. Here it is, looking quite sorry for itself.
Started taking things apart:
The offending bit of wiring harness. There is an invoice for the "repair" of a coolant temp sensor and a new wire run to the ECU. What they really did was perhaps a bit less than that. Lazy bastards. At least I have a whole new harness from Mr. Barton now.
While I was waiting for a few parts (read: when I should have been working on cleaning up the engine bay), I decided to give it it's first polish and coat of wax since god knows when. This is how it sits today:
I love this stupid thing.
TL:DR- guy buys old 760, car is pissy from sitting and shoddy work, guy does a few things to make it run a bit better, wiring harness stops play.
1985 760 Jurbo- 80k miles, finally running, driving, and boosting correctly.
2000 Honda CRV- Åsnan
2014 MINI Clubman- A fragile German-designed, Peugeot-powered, British-built monstrosity. Excels primarily in going around corners on three wheels.
brickborg is offline   Reply With Quote
Old 06-01-2018, 01:40 PM   #2
nedc
Very nice save. I don't mind putting $$ and effort into old Volvos if they at least look good cosmetically...and this on does. Mind telling us how much you had to pay for such a low mileage example?
nedc is offline   Reply With Quote
Old 06-01-2018, 01:42 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
Cool project! I like that color blue.
You ever watch “Mighty Car Mods” on YouTube? The gentleman working in the engine bay looks a lot like “Turbo Yoda” on that show.
-Mike
1998 V70 T5
|Feedback|
Old 06-01-2018, 03:08 PM   #4
brickborg
brickborg's Avatar
Thanks! I'd never seen a car in the 215 color code before, I was definitely smitten.
Also, I do watch an uncomfortable amount of MCM and that particular bald doofus is me- I appreciate the flattery!
Old 06-01-2018, 03:09 PM   #5
brickborg
brickborg's Avatar
I feel the same way. I don't mind at all- it was listed for $3200; I drove it away for $2k after limping it back to the seller's shop. Not bad if I do say so myself.
Old 06-01-2018, 03:15 PM   #6
kampman
dunning-krugersquirt
That cleaned up really nicely - great color!
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
kampman is offline   Reply With Quote
Old 06-01-2018, 04:22 PM   #7
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
x2! Very sharp. Sounds like you are fixing all the neglect as well. Keep up the good work!
#79WDP
2010 Porsche Cayenne S - DD
2010 Cadillac Escalade ESV - Wifeys ride - 194k stock
2006 Cadillac DTS - Sons ride - 193k stock mint
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 06-01-2018, 05:07 PM   #8
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
That color rips, and lol at "Jurbo"
1980 242 Turbo
2004 V70R
Old 06-01-2018, 08:28 PM   #9
darksider415
K-Jet or Bust
darksider415's Avatar
My very first Volvo was an almost identical 740 Jurbo on Sirius wheels with an M46. Admittedly, my paint was a bit toastier, because Southern car, and you don't have the little pinstriped quarter windows or the black waterfall grille, but...
Also, I can't tell what color your interior is, because mine was the blue pinstripe... But, it brings back fond memories of an awesome car. <3
Member: TBCCS
'80 Volvo 242GT
'94 Buick Roadmaster Estate
Originally Posted by zdriver123 View Post
You have to remember, TB members are experts on everything, except keeping Volvo's running.
Originally Posted by centason
This place is like a brothel. Men, women, tits, vag, dicks, fish, and mikep. What else could anyone ask for?
She has a weird 262C fetish thing going on
darksider415 is offline   Reply With Quote
Old 06-01-2018, 09:21 PM   #10
soclosenotnear
Love the '84/'85 "jurbo" 760's. Great looking car.
soclosenotnear is online now   Reply With Quote
Old 06-07-2018, 06:43 AM   #11
DET17
Reformed SAABaholic
Very sweet color and wonderful condition for it's advanced age. I believe these <100k RWD Bricks are truly becoming scarce, so consider yourself "lucky".
Any plans to modify, or will yours remain a stocker? I too (soon will) drive a 4D sedan as the daily.
Old 06-12-2018, 04:39 PM   #12
DEK2688
RTFM
DEK2688's Avatar
I too had an '85 Smurf-blood coloured 740T, many fond memories of that car. I sold it to a guy in BC's interior in the late 90's, and found it 10 years later in a junkyard - pinstripe interior still intact.
I think the Smurf blue and Emerald green are both the rarest body colours for a 7-series - they were around until '85.
Yes, I had installed an '86 eggcrate, Galaxies, and all sorts of stuff - like the e-codes which I re-snagged.
[IMG][/IMG]
Good luck with your project!!
The immutable law of multiplicative idiocy:
Idiocy is multiplicative. Two half-wits do not equal a full-witted person; they equal a quarter-witted person. Stupidity does not build upon stupidity to create genius. It breeds like a bucket full of coked out hamsters.
DEK2688 is offline   Reply With Quote
Old 06-14-2018, 11:00 AM   #13
brickborg
brickborg's Avatar
I do feel lucky- everything is covered in a layer of dirt from disuse, but cleans up so nicely.
My plan is eventually to make a reliable 250-275 horsepower, with ~300lb/ft. I'm trying to answer the question no one asked- what if Volvo had made a more performance oriented sedan in the 80's? I figure aiming for something that could outrun a 944 Turbo or 500SEL (the two benchmarks I have) would be fun. I'm trying to keep it as period correct as I can, cause I'm a dweeb that likes this stuff.
Old 06-14-2018, 11:16 AM   #14
SquareD
An Anomaly
SquareD's Avatar
Nice find, what a great color. Looks like a great basis for a project.
Old 06-14-2018, 02:09 PM   #15
brickborg
brickborg's Avatar
Man, sad to see it on blocks but that thing is gorgeous. I dig the body color surround on the eggrate- was that factory or a DEK special?
Old 06-14-2018, 02:40 PM   #16
Matt86
Matt86's Avatar
Wow....I normally don't give a **** about 700 series but that thing is NICE! A step in the right direction, preserving it instead of ruining it.
2007 V70 2.4
1989 245 DL
Matt86 is offline   Reply With Quote
Old 06-15-2018, 10:44 AM   #17
DEK2688
RTFM
DEK2688's Avatar
That was a DEK special, back in the heady days when Volvo still sold body-colored rattle can kits. I had a chuckle when I recalled that I had painted the surround 28 years ago.
Your 760 Jurbo will be a much finer example than that 740 could have ever been - its nice to see one preserved as a stocker and not hacked at.
Old 06-18-2018, 03:19 PM   #18
JW240
All idiot, no savant
JW240's Avatar
Lookin good, nice save man! A well maintained non hacked 700 series is nice. Some tasteful mods won't hurt it though!
I'd invest in some fluid film and fresh underbody coating?
Old 06-19-2018, 02:09 PM   #19
brickborg
brickborg's Avatar
Thanks for the kind words. Funny you should mention undercoating- I'm currently looking into what it will take to keep it from turning to dust in winter. The undercoating on the car is currently all there, it's just also very crispy. I'm thinking 3M Rubberized Undercoating will be a good option, but I haven't really found much for fluid film/cavity wax that people like over the long term. If anyone has any recommendations, I'm all ears.
Old 06-19-2018, 04:34 PM   #20
brickborg
brickborg's Avatar
A small update to keep the next post from being too much of a novel. Got the engine bay cleaned up, new spark plugs and wires in, and finished replacing the top end seals that needed it after the scrubdown (valve cover/front cam seal/distributor seal).
Before:
After 3 rounds of ZEP purple degreaser concentrate:
Not perfect, but at least we can see red again.
Also finished pulling the old wiring harness out of the engine bay- found this gem of a "repair" on the oil pressure sender.
I'm no scientist, but I'm pretty sure that copper is supposed to stay inside the insulation. I initially thought it was the stock wiring failing (which we already knew about), so for ****s and giggles I followed the wire path from the sender around the front of the motor and found that someone had spliced in a new section at some point.
I don't particularly care for this routing considering how close it comes to the drive pulleys and how susceptible that area is to leaks,and it bore out here- the whole length of the repair was oil soaked, crumbling, pinched in the edges of the hangers etc. I'll figure out soon if I want to keep the stock routing, but at this point I doubt it.
Also, I cleaned and fed the leather-
The driver's seat might need a more intensive conditioning, but the hides are now softer and look pretty nice after the cleaning.
At that point I fell down the rabbit hole of small engine repair when our 25 year old B&S mower decided it would mow no more, so garage time has been devoted to that.
I hope to put the Jurbo back together this week and get back to enjoying the thing while it's still nice out, barring any further interruptions from our household machines.
Old 06-19-2018, 07:37 PM   #21
soclosenotnear
Whoa, the engine and the interior ended up very clean. Nice car, once again.
Old 06-23-2018, 07:24 AM   #22
JW240
JW240's Avatar
Maybe here some useful info. https://www.oldtimer-markt.de/rostschutztest
Its in German but one of the better tests. You can easily see per product what it does. Teil 1 2 3 on the bottom of the page leads you to the 1st 2nd 3rd tests, each a few years later down the road.
Bear in mind that relatively fresh sheet metal has different needs for the wax/grease to stick than a rusted piece of sheet metal in a real old crusty car, like in the test. I'm using either Fluid Film or Mike Sanders.
Can you get some kind of paint-oil? I used "Owatrol" oil, smells line seed based, to freshen up old under body coating before smearing new stuff on it a few days later. Probably similar oils can be found for treating wood paneling and stuff on ships.
Old 06-23-2018, 11:16 PM   #23
brickborg
brickborg's Avatar
That article is incredibly helpful, lots of good information in there. I think I'll probably go with the Mike Sanders as well, if I can find a US distributor near me. That's a really good idea re: freshening the undercoating as well. I'll see what I can scrounge up.
Old 07-08-2019, 03:57 PM   #24
brickborg
brickborg's Avatar
So it's been almost a year, and I'd like to say the car has been great. It will be someday, but it's still sitting in my garage.
In the interim, I finally got the old wiring harness out and the new one in. This was a good day-
However the car still refused to drive until it was up to temp. More sacrifices to the Old Gods of Volvo diagnosis would be needed. Later that week, I came home to my garage door looking like this:
And my toolbox looking like this:
Hrmm. This stopped play for a while, since I couldn't really do much without even a basic metric socket set. I was mostly disappointed that they took my old Craftsman impact- it was a gift from my dad when I first started working on cars, and I'm a sentimental bastard.
My toolbox now has a cage around it made of 2x1/8" steel bar. Not enough to be theft proof, but delaying enough to allow my alarm to go off before they abscond with my tools again.
Onwards then. Once I got over the theft, I made a vacuum testing tool out of a plumbing cap, an HVAC smoke generator, and an old bike tube-
This immediately showed what the cold running problem had been the whole time- crap exhaust manifold gaskets. It took about 5 seconds to find the leaks when smoke started pouring out of the manifold to head sealing surface. I popped off the turbo and manifold, and was greeted by this:
Not doing much sealing then. I cleaned up the flanges, and installed a YoshiFab fitting for the turbo's drain. I also purchased a Kinugawa feed line for the stock T3. I don't want to battle with the hard lines again, because I am lazy.
Cleaned up the turbo and hit it with some cast-iron stove polish. This was recommended to me by a few guys on RetroRides, and they seem to have good results with it. We'll see how it holds up. I'm not expecting much, but it's pretty.
I also fabbed up a crappy bracket for my shiny new cupholder armrest.
So now after all that, I need to make a couple changes to my turbo drain hose, and we should be good to enjoy the car for a while. Here's hoping.
Old 07-10-2019, 05:22 PM   #25
Vol242vo
Vol242vo's Avatar
Sorry to hear about the impact stolen, I can’t stand the sh!t...you’re doing really nice work here.
Derek - 1980 242
