Old 06-03-2018, 10:29 AM   #1
Langille
Default 240 Moving Rear Axle Ahead - Torque Rods / Trailing Arms
Been trying to find info for a couple of days without much luck. Car is parked waiting on parts / advice so any help would be MUCH appreciated.
Lowered my 240 last month, put on custom wheel spacers that were measured to fit, but the tires are rubbing just a bit on the back of the rear fenders. The ideal thing would be to move the rear wheels ahead.
I found this thread that does seem to suggest that shortening the torque rods does bring the rear wheels ahead, but I'm just looking for a definiitive answer before I take the plunge and order torque rods tomorrow: https://forums.tbforums.com/showthread.php?t=195465
Questions: Show everyone how much you know!
1) Can adjustable torque rods move the rear wheels ahead? I understand that the action of these is to rotate the rear axle assembly into alignment, but I wouldn't expect the centre of that rotation axis to be exactly the wheel centre. Hoping that shorter torque rods = wheels move ahead, even if it's only a little bit. Please school me on this.
2) With shortened trailing arms is there any need to modify the driveshaft or is there enough play in it to handle trailing arms that have been shortened 10-20mm?
Thanks in advance!
Langille is offline   Reply With Quote
Old 06-03-2018, 11:32 AM   #2
TurboDenny
Why am I here?
Shortening the torque rods alone with affect the pinion angle quite a bit. To do it right you will need to shorten the trailing arms as well.
Depending on how much you're lowered, you will need to shorten the driveshaft as well. Mine was bottomed out in the slip yoke with stock trailing arms, although it was lowered quite a bit.
Instagram: @itstotesdenny
Old 06-03-2018, 05:07 PM   #3
Langille
Thanks for the reply but I am much more interested in moving the wheels ahead than correcting the pinion angle. Does adjusting the torque rods do both?
Thanks!
Old 06-03-2018, 10:18 PM   #4
TurboDenny
Why am I here?
Thanks!
Yes, if you shorten the trailing arms you need to shorten the torque rods as well.
Old 06-03-2018, 10:21 PM   #5
Langille
Ok, and if I don't shorten the trailing arms, the torque rods only rotate the axle and won't give any additional clearance without trailing arm mods?
Old 06-03-2018, 10:38 PM   #6
TurboDenny
Why am I here?
It will move the axle forward, but it will also put the pinion angle way out of spec.
Old 06-03-2018, 11:50 PM   #7
apachechef
Burnt Sierra Madre
ideal?
lot of work versus correct spacers or massaging fenders.
worth it?
Dammit, Lummert.
Old 06-04-2018, 12:19 AM   #8
Even Volvo recommends trimming the inner fender lip when running the factory 20mm spacers in the rear.
Old 06-04-2018, 12:38 AM   #9
quillc
yv1a.com
quillc's Avatar
Just roll the fender lip. Works fine and stops the rubbing.
Chris
www.yv1a.com
Old 06-04-2018, 08:29 AM   #10
soclosenotnear
Weird. Why did Volvo offer 20mm spacers? Were they an adapter style spacer?
Old 06-04-2018, 12:11 PM   #11
They were offered to even out the track width since 240's are narrower in the rear, increase clearance from the inner wheel well for wider wheels/tires and there's supposedly an increase in cornering G's as well.
http://people.physics.anu.edu.au/~am...pacer_info.htm
The kit came with 2 spacers and 10 longer studs.
Old 06-06-2018, 11:53 AM   #12
benski
Post
Leave it to the pro's to have this handy tidbit of info stashed away, but accessible!
To the OP; I see a 5lb sledge an a fender dolly in your future. Make sure all of your rear suspension bushings are in good shape before you start this adventure, or you will be chasing your tail forever..
Old 06-06-2018, 12:08 PM   #13
Chuck W
Chuck W's Avatar
You will probably need to adjust the length of your panhard bar as well, seeing as you've lowered the car.
'80 264GLE - (B21FT-MS'ed/M46)
'97 854 T5 (Eventually to be 5spd)
'77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
