Old 06-07-2018, 08:48 PM   #1
Lando
Arthur Digby Sellers
Lando's Avatar
Default Fuel economy transmission swap
I have a pedal cluster, clutch cable and cross member from a manual 240 for a manual swap on my 86 245, but I don’t know what trans I want to swap to. I have a bone stock B230F, that I don’t plan on modifying, I just want a manual transmission to improve my highway fuel economy because I know the AW70 is the main contributor to my 24mpg at best. I commute in freeways where the traffic is going 80+ mph.
What is the latest and greatest swap that people are using considering that I don’t need it to tolerate a whole lot of horsepower? I do not want an M46/47. I’d prefer a hydraulic clutch, but I’m not set on that. The T5 isn’t really calling my name either, but the WC variant does have some nice ratios for decent MPG at 80+ mph. I remember readying about some crazies entertaining the idea of a 6 speed Nissan tranny, but had trouble finding the thread.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is offline   Reply With Quote
Old 06-07-2018, 09:08 PM   #2
JohnLane
Convert to 10 year old Corolla for 35mpg, less noise, better reliability, more likely hood of survival in a big accident ect.
For those of us with a thing for Volvos.... M-46 if it is healthy will do just fine at stock power level.
Seriously... If fuel economy is changing your lifestyle.... Work harder or smarter!
Old 06-07-2018, 09:18 PM   #3
John V, outside agitator
Banned
I have a pedal cluster, clutch cable and cross member from a manual 240 for a manual swap on my 86 245, but I donít know what trans I want to swap to. I have a bone stock B230F, that I donít plan on modifying, I just want a manual transmission to improve my highway fuel economy because I know the AW70 is the main contributor to my 24mpg at best. I commute in freeways where the traffic is going 80+ mph.
What is the latest and greatest swap that people are using considering that I donít need it to tolerate a whole lot of horsepower? I do not want an M46/47. Iíd prefer a hydraulic clutch, but Iím not set on that. The T5 isnít really calling my name either, but the WC variant does have some nice ratios for decent MPG at 80+ mph. I remember readying about some crazies entertaining the idea of a 6 speed Nissan tranny, but had trouble finding the thread.
Careful...I heart all to fawk the T5--the one with the tallest 1st but I also reccomend much shorter axle ratios...
See its an interplay...1st thru 4th fun, and then when you have the insane overdrive of .63 or .72 AND a 4.3/4.37 or even a 4.88--then 5th is allright--on the flat and level>
4.88 back x .63 is 3.07 overall and that's pretty tall..Fine for a turbo car.
But that 5th and a 3.7 is 2.33 and that is nutso tall..So tall you'd be fighting wind resistance at 80+ and being below reasonable torque...so that would probably cost you Em Pea Gees.
As crazy as it sounds increasing the POP per pop --efficiency---all other things being equal--is the key to happiness.
My daily has a M47 and here everybody hates them --just like in the Mare_koooor world everybody "hates" the stock Type 9...Me? I say ""Hmmmmm not too bad for a daily/road car.."
Only problem with both is a) getting a good one or b) getting the parts to run thru the box spiffing it up before install..and getting them for reasonable cost... c) getting good info in the climate of "they're sh!t" which is the reflexive response..
Make manual trans grate again!
Old 06-07-2018, 09:26 PM   #4
Lando
Lando's Avatar
Itís not changing my life style. My AW70 is shifting hard and I want a third pedal. I would also like to maximize my fuel economy. Thanks!
Old 06-07-2018, 09:28 PM   #5
Lando
Lando's Avatar
Those are my concerns with the M46/47. I don’t want to go to a ton of trouble to put a worn out transmission that I can't find parts for in my car. I also hate the electric overdrive.
Old 06-07-2018, 09:38 PM   #6
Cwazywazy
Cwazywazy's Avatar
Will an M46 OD unit bolt to an M47?
I don't know what I have
Old 06-07-2018, 09:40 PM   #7
JohnLane
Nope
Old 06-07-2018, 09:42 PM   #8
Cwazywazy
Cwazywazy's Avatar
Nope
What if you use a lot of glue?
Old 06-07-2018, 09:44 PM   #9
Lando
Lando's Avatar
It'll glue on, it just won't bolt on.
Old 06-08-2018, 01:10 AM   #10
Banned
Those are my concerns with the M46/47. I donít want to go to a ton of trouble to put a worn out transmission that I can't find parts for in my car. I also hate the electric overdrive.
Yeah those Lay Cock things are a horrible joke...dry humor, harumph!
The M47 in my wagon isn't bad...there very well may be parts..Truth is I haven'rt looked too hard..I did ask whassis their names down in Socal---the guys that are real sharp on old stuff..
Hiperauto?? He said as far as he knows things are available..
Like the main 4 bearings, and synchro rings..
That said I have found the best MPG improvement via more torque..
If one POP! moves you this much X distance...and a stronger POP!!! moves you 1.15X distance then to move X on the torque-ier it takes less open throttle..
Only have dozens of V4s and 900s I've built where I'm doing n.a. comp at 10.8 to 11.2....they got better mpg on cross country trips..
Of course that means head off and making chips, but it is the best thing I've seen
(and is a good portion why modern engines get better milage is so many are much higher compression---they get even better if they weren't hauling an average of 1000-1100lbs more than a comparable niche car was 30 years ago..)
The bummer of the problem of high speed cruise is that wind resistance goes up like cube-function
A real example..This car Opel Kadett GSI 1988..Opel XE motor (2,0 with 86 x 86mm bore and stroke) 16v head (from the same place all the Germans go since they can't make a good head--England..) stock 150 hp with cat... pretty good numbers for a 2,0 car in 88
Good clean aero shape
According to some fancy German test it took that car in stock for just 7.5hp to go down the road at steady 100 km/hr
But to reach top speed...(214 km/hr or about 132mph) it took all 150hp..
That's one steep curve and it has to be worse for a brick shaped car...
Old 06-08-2018, 01:34 AM   #11
^ That's not bad at all.
With 3:54's running at 6 or 7 pounds of vacuum I cross the 24mpg line at 67mph @ 2500 rpm.
Old 06-08-2018, 08:25 AM   #12
JohnMc
JohnMc's Avatar
Our beater backpacking road trip back up whatever '03 Jetta TDi got 48 mpg on a road trip through west Texas once, going 80 mph all day long, with the A/C blasting. The worst tankful MPG we've ever gotten from it was 38. In the winter, doing lots of city driving, short trips where sometimes it wouldn't even fully warm up before shutting down again.
Avoid the automatics in those, they don't last forever like the engine does. And apparently, we lucked into finding a somewhat rare car - the 2003 (last year of the older, simpler injection pump ALH engine) in 5 spd wagon form. Does it make a difference that the TDi wagons were made in Germany and not in Mexico? Who knows.
Very useful amount of space in the car, even if it isn't as big as a 4Runner or a 245. And while the car is not fast, it also isn't horribly slow. It's a... very relaxing and competent car to drive. It's just so good at what it does. Admirable in its German efficiency.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-08-2018, 02:00 PM   #13
vwblue1967
vwblue1967's Avatar
My 93 can get 23-24 MPG pretty often with the AW70 and my 85 with the M46 usually get 25-26...now that I replaced my coolant temp sensor, my last tank was 27.2mpg.
I was thinking about swapping in a lockup tans and an L cam just to see what the 93 could do being that it gets a lot of highway miles. Also looking at the time and cost of parts I wonder how many tanks of gas I'd have to run for it to make it financially worth it.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
Old 06-08-2018, 02:15 PM   #14
Happy Mew Year!!!
There's 6spd adapters in group buy, but not sure if enough torques to utilize it, you'd have to see how the ratios work with your 3rd member.
Old 06-08-2018, 03:16 PM   #15
283SD
Wagons with a standard trans came with a 3.31, rear this should help with your final drive ratio,but you need to change the whole axle housing
Old 06-08-2018, 04:02 PM   #16
lummert
lummert's Avatar
AW71L? Lock-up converter will lower the rpm's.
Old 06-08-2018, 04:36 PM   #17
Originally Posted by 283SD View Post
Wagons with a standard trans *83+* came with a 3.31, rear this should help with your final drive ratio,but you need to change the whole axle housing
The engineers usually combined the parts bin for maximum efficiency, that in combination with an AT would suck to drive and get worse MPGees.
Old 06-09-2018, 06:02 PM   #18
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Old 06-09-2018, 10:11 PM   #19
A Saab will do OK @ 80mph, fuel wise a 240 not so much so.
Old 06-09-2018, 10:34 PM   #20
sbabbs
sbabbs's Avatar
My best was 28mpg at 70 cruise control to seattle in 90 745 with turbo and m46 and 3.54 ratio T cam. Switched to A cam and now it's 25mpg.
Old 06-10-2018, 07:46 AM   #21
DET17
Reformed SAABaholic
My first SAAB 900S, NA with 5 speed would hit 32~33 at 70mph.... a little sleeker and better CD than the RWD bricks. My Turbo C900s would never touch that mileage even with the 5 speeds.
Sounds like the low $ solution for the OP is search for a lower mile M47, with the desert gear in back.... skinny tires "well inflated" to reduce rolling resistance.
This thread makes me wonder if anyone with MS conversions to these 4 bangers that upgraded to sequential fuel ever saw better MPG numbers? I can't believe batch fuel is ideal for economy.
MY GOD, we can't be having an efficiency thread in PERFORMANCE, can we?
Old 06-10-2018, 10:51 AM   #22
Happy Mew Year!!!
Why does everyone think batch fire is so bad? I think it gives the fuel a little more time to vaporize, but I'm no expert.
Old 06-10-2018, 04:08 PM   #23
Banned
They are 2 sides of the same coin...more efficiency = moar powrz= less fuel consumed per unit of distance..
Old 06-14-2018, 08:09 AM   #24
freevolvos
freevolvos's Avatar
i often thought about the m.p.g. thing myself.. i was wondering if there was a cam that made peak power at say roughly 4k after i put the tach on mine i was shocked to see how little i get above 3 k... In actually started doing it on purpose to get the m.a.f. to self clean.. so what would work advancing the stock cam a few degrees, getting a low rpm cam, shave the head to bring up the c.r. and maybe a tlao chip? i have a 89 engine I'm about to put in and maybe i should get there head done now? a little bowl work maybe?
Old 06-14-2018, 08:41 AM   #25
Dadssleeper
Dadssleeper's Avatar
One of the main reasons I strayed away from V8's is road trips. I put a 240 together with a B230ft and mated that to an M47 with 3:31 gears. I am running a stock turbo at the moment at max psi of 12. I pulled 28-30 MPG's , I was expecting a little less, but still way better then the 12 mpg's I am use to.
