Old 06-07-2018, 10:02 PM   #1
MisterBLC
Default Nathaninwa Intake/Rail w/ ID1000 Injectors
Guys,
Working on upgrading my injectors to ID1000s on my 740T, with a Nathaninwa Intake/Manifold. The ID1000s are 60mm long versions with the purple adapter to get the length right. The trouble is, the purple adapter has no groove in it for the clip to attach them to the fuel rail and I am nervous about just letting them float in the rail/manifold. Anyone else ever run ID1000s and had a similar issue? Is it OK to just let them float in there?
Thanks,
Brian
MisterBLC is offline   Reply With Quote
Old 06-08-2018, 02:47 AM   #2
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yikes... no clip is no good.. 4,5-5 bar of pressure wants to pop them off.. The fuelpressure will at least make them wander in the bore and war the sealing at last..
Old 06-08-2018, 07:38 AM   #3
Stiggy Pop
Stiggy Pop's Avatar
Yes I ran this setup for a while with no clips. I did not have a problem necessarily but did find that the injectors were being pushed down far enough into the injector bungs to create a boost leak around the bottom o-ring. I bought a different companies adapter hats with clip grooves, i think the link is buried in my build thread somewhere
'79 242
943 pickup
Old 06-08-2018, 08:11 AM   #4
Broke4speed
Broke4speed's Avatar
My adapters have no clips, but I'm also using a stock intake. Never had an issue.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 06-08-2018, 09:59 AM   #5
Stiggy Pop
Stiggy Pop's Avatar
I didn't on the stock manifold either, but the NIW intake does not have a tapered bore that prevents the injector from being pushed down far enough so it breaches the seal of the o-ring.
Not having any luck finding the top hats that I bought. Here is a picture of the injector pushed down by fuel pressure vs held up in the clips:
Old 06-08-2018, 10:58 AM   #6
GTJordan
Been here for too long
GTJordan's Avatar
If you find where you got those clipped adapters, can you update this thread? I remember reading your post about the moving injectors. I have ID1000's in my NIW manifold, and noticed the same movement.
Jordan
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 06-08-2018, 11:02 AM   #7
Stiggy Pop
Stiggy Pop's Avatar
I found in my thread where I referenced Tom/Banana sending me the link but can't find it, maybe he still has it?
Old 06-08-2018, 12:26 PM   #8
sbabbs
sbabbs's Avatar
I had the same problem with stock intake, I found the clip adapters with clips on both ends of the adapters from Australia...
https://www.efihardware.com/products...ht-Premium-Kit
http://forums.turbobricks.com/showth...=sbabbs&page=2
Old 06-08-2018, 01:13 PM   #9
cwdodson88
Chuck them in a drill press and carefully file a keeper groove. It’s like 1mm wide and .5-1mm deep. A hacksaw blade was the right width for me.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-11-2018, 01:50 PM   #10
MisterBLC
Thanks for the info guys, I think I found a US supplier for an adapter cap that will also do the trick at like $8 per cap...once I get them in the mail I will let you know how well they work!
Old 06-24-2018, 11:03 AM   #11
MisterBLC
Ok, after a USPS snafu, I got these and installed them. Bought them from the link below and they work great...seals all lined up perfect. Why the stock ID1000 caps don't have the appropriate groove is beyond me, company said "Its usually not a problem...". Having the injectors attached to the rail appropriately definitely makes me feel better.
https://www.southbayfuelinjectors.co...-ring-1-2-inch
Brian
Old 06-24-2018, 04:34 PM   #12
GTJordan
GTJordan's Avatar
Brian
Thank you!
Jordan
