Old 06-08-2018, 02:38 AM   #1
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Default 1041 or 1031 to truetrac
Hi,
i got a 1041 which needs a rebuild before doing another mile with it..
Is it more intelligent to swap in a 1031 when going TrueTrac to make some money out of the 1041?
I am really baffled with alle these 1041 rebuildthreads where it is mostly a 1031 in the end :D
Whats the difference between the bearings of those two is there an ultimatively 1041 thread? i havent found one..
For economy reasons it would be better for my moneybag to just rebuild the 1041 ;)
Old 06-08-2018, 04:01 AM   #2
Brotkasten
Brotkasten's Avatar
https://www.ebay-kleinanzeigen.de/s-...95661-223-4431
HAHAHA
91' 940 B230FB+T M90
Old 06-08-2018, 04:37 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ja.. und jetzt?
Old 06-08-2018, 05:02 AM   #4
JerryJS8
der Junge
JerryJS8's Avatar
Ich hätte auch was, aber 4.10 Übersetzung für nur 249,95€!
TruTrac Install Thread
http://forums.turbobricks.com/showthread.php?t=189043
Rear end stuff
http://www.240turbo.com/volvorearends.html
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 06-08-2018, 05:16 AM   #5
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
yeah.. i know all the truetrac threads.. what i need is a detailed howto for a complete 1041 rebuild..
Old 06-08-2018, 05:16 AM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
and a pre100kKM M90... :D
Old 06-08-2018, 07:12 AM   #7
DET17
Reformed SAABaholic
Somewhere I have a link to a 960 teardown & reassy. of the 1041. I will see if I can find it tonight and list the link. No pics, just OEM illustrations.
I put the PowerLOK LSD in my 940 1041, but didn't touch the pinion (used a 4.10 from a lower mile NA 9 series). WELL, it turned out to be an easy find:
http://www.volvotips.com/service-man...ir-manual.html
Old 06-08-2018, 08:58 AM   #8
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
the 1041 (locker, that's really the big difference) chunk tends to wear out the little gears on anything really fun. The trutrac shouldn't wear out like that, AND it's not a locker so it's probably a bit better to drive.
Taking a locker apart is fairly easy, there's not much to them, note the positioning of the counterweight and governor, and the count of frictions and steels on each side. Don't set your clearances too tight.
The side bearings on the carrier (carrier bearings) are the same 1031/1041.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 06-08-2018, 10:22 AM   #9
gsellstr
gsellstr's Avatar
I'm closing in on 100k on my TT, damn thing is completely silent, fully effective though. I'm with Kenny, definitely prefer the TT over the G80, though the G80 did work reasonably well half the time.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-08-2018, 07:13 PM   #10
sbabbs
sbabbs's Avatar
1031 740 axles are wee bit longer and not as thick as 1041 axles. SAme size where they go into the diff, but then get thicker from there to the other end then 1031's. But they always break for me right at the spot where they go into the diff.
Old 06-08-2018, 09:10 PM   #11
gsellstr
gsellstr's Avatar
Power level you break them at Simon? Just curious...
Old 06-08-2018, 09:36 PM   #12
Texas240
Prius Owner
Texas240's Avatar
Im at 320 tq wheel from my lm7 with my stock 1041 locker and its smooth as ox ass.
93 245 LS Engine Swap Project
Old 06-09-2018, 01:26 AM   #13
gsellstr
gsellstr's Avatar
I am around 290rwtq on the 230FT, same thing with the TT.
Old 06-09-2018, 02:27 PM   #14
sbabbs
sbabbs's Avatar
It's a welded diff breaks the axles just driving around and drag racing with slicks can break them but welded breaks them easier. I've broken them with G80 and slicks and drag strip and then drove home with one broke one and one wheel drive.
I broke em with 235hp/275tq and 12.61 ET.
Old 07-01-2018, 10:43 AM   #15
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
man, i dissassembled the whole thing and now im hasseling with the reassembling..
i will put every shim back to where it belongs but i believe i need to shim it out again and im in a hurry cause my other car did not pass mot.. uh..
btw.. getting the big pinion off is a pita! it exploded on us and my buddy got hit by the race wall broken off on the thumb.. ^^
Old 07-30-2018, 07:27 AM   #16
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
some upgrades.. i reassembled everything and also biased to the preload of the bearings of 2,5-3,5Nm when turning by hand.
It moves so weird its like glued.. maybe from the new bearings? Dont know.. it is not that possible to check for the desired play in the teeth.. yeah.. i will have a looksy at it this evening.. ^^
Somebody got that problem too?
Old 08-02-2018, 02:36 AM   #17
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Axle is in again, cause i need to got my Daily Bitch MOTed.. yeah.. still not satisfied how this rebuild came out... The ponion turns with some resistance at some points.. due to it is not always the same spot on the pinion i assume it is on the ring gears bill.. dont know.. i will drive this only 2 kms to my garage and back, when i have time again.. Also my toothflank play is not correct, after i torqued the diff to specs... i tried to stretch the housing a bit, but nothing happened :(
Need to redo the whole thing i believe.. man.. with shimming and stuff..
