View Poll Results: Which stupid turbo?
15G swap to angled 0 0%
19T angled 6 26.09%
19T conical 0 0%
HE341 9 39.13%
Keep conical because it's better, but push car into lake because idc and it seems fun? 8 34.78%
Voters: 23. You may not vote on this poll
Old 06-09-2018, 02:31 PM   #1
EivlEvo
Default 15G Conical. What Next? 19T Angled? HE341? Push Car Into Lake?
I should probably make a project thread that could be about half of me building this car in pointlessly conservative stages and half about how it has some petty inconvenient problem I need fixed but whatever.
1993 245 squirters +T
Currently on IPD cam and a 15G at ~15psi. Has T5 trans. Has big IC. Has 577cc's with 3" AMM and TLAO but I'm laying the groundwork for standalone.
I have 2 other turbos.
1. A 19T with angled flange
2. A Holset HE341
The goal is for a quick feeling daily. The 19T seems to make the most sense, but mixed reviews. The Holset would make the car "fast" vs. quick but also mixed reviews lol.
I MAY try and weld up a good universal downpipe this weekend (if this migraine subsides) so I can basically just swap the upper curved section when I swap turbos and housings. It seems pointless to put the 19T into the 15G conical housing yes?
Old 06-09-2018, 03:26 PM   #2
soclosenotnear
I wouldn't mind seeing a project thread on your 240.
My vote is the 19t with either straight or angled housing for your goals. I say straight housing because it'll be easier to make your downpipe work. I don't think a "universal" downpipe will work on an angled flange well, fwiw.
Last edited by soclosenotnear; 06-09-2018 at 07:20 PM.. Reason: Meant angled. Conical housing sucks.
Old 06-09-2018, 03:38 PM   #3
EivlEvo
The idea of the universal DP basically just puts a v-band on the DOWN part of the downpipe. That means I can detach it there and use a modified upper section for my current conical, a future angled or the Holset (which I'd bet I'd run off the NA manifold with a J pipe)...
Also thanks. I have all the pics... just gotta do it.
Old 06-09-2018, 03:38 PM   #4
tryingbe
Boosting along.
tryingbe's Avatar
Auto or manual?
85 GLH 367whp
00 Insight mpg > yours.
Old 06-09-2018, 04:11 PM   #5
EivlEvo
It's an auto swapped to a T5. So... manual.
Old 06-09-2018, 04:25 PM   #6
cosbySweater
cosbySweater's Avatar
Do the 19t. It will do exactly what you want
Old 06-09-2018, 05:36 PM   #7
Tfrasca
Tfrasca's Avatar
The 19t is pretty sweet for a quick daily.
Tfrasca is online now   Reply With Quote
Old 06-12-2018, 12:48 PM   #8
EivlEvo
Hahaha.
Everyone says go 19T but the poll says go Holset.
I had heard tales of 19Ts being rod benders on redblocks because the boost hits so low and hard.
Old 06-12-2018, 12:49 PM   #9
thelostartof
unbalanced chemical
thelostartof's Avatar
Only on whiteblocks not redblocks
And the white block reason is because of boost controller and or the lack there of a proper setup.
Old 06-12-2018, 02:23 PM   #10
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
19T is my vote. I am already thinking about a 19T for my car, you know to keep up with the Joneses.
1980 242 Turbo
2004 V70R
Old 06-12-2018, 02:29 PM   #11
EivlEvo
J_Jones has a 2JZ in his car now though lolol
And I think the other jones person on here is putting a 531 head onto NA in an effort to win JohnV's heart?
And we're over here playing around with little turbos.
Old 06-12-2018, 02:31 PM   #12
EivlEvo
I'm gonna start with this 19T if my snap ring pliers show up. Also... angled is better than conical yes? I feel like it's the bigger angled flange which is default bigger.
I'm gonna try and water cool this turbo for max complexity... and add an oil cooler as well. My 15G is coked out worse than a 90's stockbroker.
Old 06-12-2018, 02:34 PM   #13
Tfrasca
Tfrasca's Avatar
I'll have one for you in a month or so...
Old 06-12-2018, 02:34 PM   #14
Uncleknucklez
bruspeed
Well, I'm not going that far...yet
Angled is mucho better, water cooling is easy enough with factory parts, should be NBD.
Old 06-12-2018, 03:02 PM   #15
gsellstr
gsellstr's Avatar
Definitely 19t over the holset for a daily. BTDT on the Holset, needs some work to get it to spool in town. My experience, you'd get halfway into an intersection, almost get hit from side traffic if there was any, then it would finally light off and throw you sideways. Something a little smaller like the 19t or my Garrett lights off from the get-go, gets you moving thru traffic before it fully lights off.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-12-2018, 03:29 PM   #16
Uncleknucklez
bruspeed
We will chat about this.
Old 06-14-2018, 12:50 AM   #17
JKnuck6
JKnuck6's Avatar
So those of you have that have a 19T on your car... question. I have a 19t on my 245, but had to put a conical flange on it to bolt up the 4 bolts to the exhaust manifold. Are people just running it with 3 bolts?
06 V70R (ipd goodies)
84 245+t (19t)
91 244+t ("63 trim" ebay, 1000cc, microsquirt)
91 940 Turbo (sold)
94 850 Turbo Wagon (sold)
JKnuck6 is offline   Reply With Quote
Old 06-14-2018, 12:58 AM   #18
tryingbe
Boosting along.
tryingbe's Avatar
I prefer mid to high end power vs low end torque, so I voted Holset.
Old 06-14-2018, 06:20 AM   #19
oldschoolvolvo
oldschoolvolvo's Avatar
Others have also had issues using the angled flange turbine housing on the 19T...solution is either swapping turbine housings or getting out the grinder.
http://forums.tbforums.com/showthread.php?t=342705
-Mike
1998 V70 T5
|Feedback|
Old 06-14-2018, 11:51 AM   #20
JKnuck6
JKnuck6's Avatar
awesome man. thank you!
Old 06-14-2018, 12:12 PM   #21
thelostartof
unbalanced chemical
We will see when I swap on the 19t I have here on the bench to see the gains over my 15g. But I still love the stupidness of my holset. Nevermind the top end power is world's better than anything a 19t will do.
Old 06-14-2018, 03:37 PM   #22
EivlEvo
Mike... you and I are basically constantly building the same cars it seems
Have you been on the dyno with your 15G setup? Is the setup/dyno stuff posted anywhere?
I'm half considering trying to get onto the dyno on the 15G prior to going 19T but... I just sprung for a buncha crap.
Old 06-14-2018, 03:51 PM   #23
thelostartof
unbalanced chemical
I want to Dyno my current setup and then go 19t and redyno but it is to damn hot here to even bother.
Old 06-14-2018, 04:53 PM   #24
EivlEvo
Haha same. It dropped into the 60's in the AM earlier this week and I was like OH DAMN... my car so faaaaassssst
Back to triple digits and AC though
Old 06-14-2018, 05:47 PM   #25
Sjeng
Just switched from 15G to 18T. 18T is as fast at 0.8 bar as the 15G at 1 bar.
It runs very nice now, good response and you do not feel the torque dropping off like with the 15G.
Sjeng is online now   Reply With Quote
