Old 06-12-2018, 07:46 AM   #1
apollo's 940
Default which intercooler upgrade is better?
940T 1992 stock
upgrading my intercooler (and 13c to 16t)
which is a better intercooler?
this : https://www.eeuroparts.com/Parts/407...cooler-ICM150/
$542
or this: https://shop.klracing.se/sv/artiklar...-ac-60mm-.html
$249 plus shipping from europe(?)
thanks in advance
andrew
apollo's 940 is offline   Reply With Quote
Old 06-12-2018, 08:23 AM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
Chances are they are the same unit just branded differently. The US company is just making a bunch of profit.
Old 06-12-2018, 09:38 AM   #3
EivlEvo
I'd 100% go with the less expensive one.
Old 06-12-2018, 06:28 PM   #4
doucheNozzle
doucheNozzle's Avatar
do88. Has the numbers to back it up. Installed one in my 850. Fit and finish was awesome.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-12-2018, 06:58 PM   #5
apollo's 940
the do88 is known for two good things (that I have read)
1. its a perfect drop in
and
2. its super fat (from the photos, its almost more than double the stock intercooler)
question:
does anyone know if these are the facts for the KLracing brand?
because if they are (perfect drop in and fat as hell) --- ill go for the KLracing because it is less than half the price.
thanks,
andrew
Old 06-12-2018, 07:06 PM   #6
John V, outside agitator
Banned
and
question:
thanks,
andrew
Go direct......to where the intercooler was made..A-L-I.....
Old 06-12-2018, 07:16 PM   #7
white855T
All the intercoolers come from the same place. The retail shops do have to mark them up. Go with the KL racing one as it drops in and less expensive.
Buyer/Seller Feedback
Old 06-12-2018, 08:01 PM   #8
doucheNozzle
That’s great they’re made in the same place. That doesn’t mean the build quality is the same, the dimensions are the same or the core is the same.
Old 06-12-2018, 11:23 PM   #9
tryingbe
Boosting along.
tryingbe's Avatar
They are not the same.
23 row
22 row
85 GLH 367whp
00 Insight mpg > yours.
Old 06-12-2018, 11:29 PM   #10
Cwazywazy
Cwazywazy's Avatar
KL Racing one is shinier, get that.
I don't know what I have
Old 06-13-2018, 12:04 AM   #11
gsellstr
gsellstr's Avatar
Different mounting tabs, the do88 stuff I've seen have all had do88 cast in the end tanks as well, those end tanks between the two pics are slightly different as well, plus the different row count Ian mentioned. Sounds like different units to me.
Either should be fine, both far better than the stock stuff, but personally, I really do like my do88.
Now to go clean up the crapshow above, keep this on track. Both of you, knock it off. We all know you like to piss in each others cheerios, do it in OT, not here.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-13-2018, 04:20 AM   #12
Banned
Silly boys those are just photos..Photos are always suspect....
Go Alibaba , you'll find the things there and some places (already checked, some places do sell single units..Might check Ali-Express...
Old 06-22-2018, 07:34 PM   #13
Boris740
Broad Member
Boris740's Avatar
23 row vs 22 row - Take the heavier one.
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
Old 06-27-2018, 12:27 PM   #14
Turbobeans
The Kl racingnone is cheaper even with shipping
Turbobeans is offline   Reply With Quote
Old 06-27-2018, 12:28 PM   #15
Turbobeans
I have Kl racing and it’s direct drop in
Old 06-27-2018, 02:42 PM   #16
cosbySweater
cosbySweater's Avatar
Like Gary stated the do88 looks to have cast end tanks.
Old 06-27-2018, 04:42 PM   #17
Fa182
Stage 1
Fa182's Avatar
What's your experience when you've changed it? Did you notice a large improvement? I'm still undecided whether to buy one or not.
Old 06-27-2018, 07:04 PM   #18
doucheNozzle
He asked best, not cheapest
Old 06-27-2018, 08:06 PM   #19
Cwazywazy
Cwazywazy's Avatar
I can only speak for the KL Racing cooler in a 240, but it was a pretty painless install (Made a new upper bracket with flat steel and the old rubber piece) and I gained a pound of boost on the gauge. I'm happy with it. You could get the same results for less with an eBay cooler but install will be a lot harder.
Old 06-28-2018, 01:36 AM   #20
sekokupu
I also have KL-racing intercooler and it is almost bolt in part. Needs small modifications for good fitment.
That upper "bracket" is just idiotic.
sekokupu is offline   Reply With Quote
Old 06-28-2018, 06:34 AM   #21
DET17
Reformed SAABaholic
The do88.se version is also essentially a drop in for the 7/9 series. Very minor sheet metal clearancing (dremel) if you are anal like I am.... and wanted it centered. The stack is TIGHT when you fit it between the radiator and your condenser, but it fights like it was designed for that space.........
