Old 06-12-2018, 09:47 PM   #1
apollo's 940
Default 16T problem screwing to stock exhaust manifold
1992 940T stock
13c taken out, 16T angled flange coming in
3" dp coming in
stock exhaust 90 + manifold (to be ported(?)) will remain
ON STOCK: the 13c is bolted to the manifold on four studs attached to manifold --- these four studs enter 13c hotside, then are tightened by four nuts on the 13c hotside. simple and accessible
PROBLEM :
the 16T hotside can only accept three studs from the manifold (actually only two but the third threaded hole of the 16T will be bored bigger to accept the third stud.
the problem is the fourth stud of the manifold. there is no way for this fourth stud to be accepted by the 16T hotside and tightened by a nut
the 16T hotside has no through and through hole that the manifold fourth stud can enter
the 16T hotside therefore, itself must hold the stud BUT there is no space to apply the nut behind the manifold
make sense?
QUESTION
forget the fourth stud
can this 16T upgrade survive with ONLY three studs and nuts?
thanks in advance
andrew
apollo's 940 is offline   Reply With Quote
Old 06-12-2018, 10:05 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
Not sure I fully understand what your problem is. Pics will help.
The standard method of bolting up a FWD turbo...
-The 2x studs need to be removed from the 16T turbine housing.
-Then the threaded holes need to be drilled out so that the turbine housing will slide on the 4x studs on the manifold and attach with the same 4x nuts as the 13C.
Edit...looks like others have also had the same issue w/ the angle flange and a 90+ manifold.
https://forums.tbforums.com/showthread.php?t=154055
-Mike
1998 V70 T5
|Feedback|
Old 06-12-2018, 11:30 PM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
Find another angled outlet turbine housing as there are two styles and one of them can allow you to barely get a nut on the back after a little grinding. You can also remove the stud from the 90+ and drill out the hole and put a nut on the 90+ side.
Old 06-12-2018, 11:32 PM   #4
thelostartof
unbalanced chemical
This is why we like to use the straight outlet housing.
Old 06-13-2018, 04:13 PM   #5
Pete.M
Slow Member
Pete.M's Avatar
I went down the route of carefully grinding the manifold to fit a nut. Not great but it works.
Pete.M is offline   Reply With Quote
Old 06-13-2018, 05:17 PM   #6
EivlEvo
Any chance to get pics up in the thread? I'm gonna be going down this with my 19T I suspect (angled housing as well)
Old 06-13-2018, 05:27 PM   #7
thelostartof
unbalanced chemical
Get a straight outlet housing. Problem solved.
Old 06-13-2018, 08:00 PM   #8
EivlEvo
Right I mean if we use that logic we should all just buy new Ford mustangs.
Alternatively someone could toss a pic or two up if they have them, and everyone can go about their day ruining these cars.
Old 06-13-2018, 09:55 PM   #9
oldschoolvolvo
Ref: http://forums.tbforums.com/showpost....9&postcount=32
This user kept the stud on the angled turbine housing and ground away some of the exhaust manifold in order to fit a nut on the manifold side.
Old 06-13-2018, 10:03 PM   #10
EivlEvo
Cool. Makes sense.
Old 06-14-2018, 12:35 PM   #11
JKnuck6
JKnuck6's Avatar
excellent post. Thank you sir! 3" angled flange can finally be put to use.. and I barely had to use my brain at all!
06 V70R (ipd goodies)
84 245+t (19t)
91 244+t ("63 trim" ebay, 1000cc, microsquirt)
91 940 Turbo (sold)
94 850 Turbo Wagon (sold)
JKnuck6 is offline   Reply With Quote
