Old 09-12-2016, 11:33 PM   #676
Pro Sneaker Peddler
Stage π
Old 09-13-2016, 04:46 PM   #677
Pro Sneaker Peddler
Felt a little bit of slip after a hard uphill 2-3 shift today. Hoping it's just leaked fluid. Also hoping I can get a tailshaft seal in there soon so I don't have to refill a quart every 300 miles
Also, looks like engine and trans swap won't be happening until April next year due to other projects. Oh well. May as well just keep on hoarding parts between now and then. Still thinking Q7 brakes and Recaro restoration.
Old 09-13-2016, 09:35 PM   #678
cosbySweater
cosbySweater's Avatar
you shouldnt worry about any of those items, just part it out.
Old 09-14-2016, 02:28 PM   #679
BillyMaysHere
BillyMaysHere's Avatar
This is solid advice
I am actually the gentlest and kindest of souls, you know that...I wish peace and happiness to everybody
Was a sandals-and-socks elbow-patch-cardigan-wearing bearded college-professor 10mph-under-the-limit-in-the-fast-lane typical Volvo buyer from 1993 really caring about some sort of limited edition numbering?
BillyMaysHere is offline   Reply With Quote
Old 09-19-2016, 11:55 PM   #680
Lord_Athlon
Just damn
How did I miss this.
Harald, just pull the trigger on it already. Get it over with.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Lord_Athlon is online now   Reply With Quote
Old 09-20-2016, 12:54 AM   #681
Quin
ಠ_ಠ
i already gave him my dibs list, you guys are late to the party.
Old 09-20-2016, 03:58 PM   #682
Lord_Athlon
Just damn
Lets see who gets there first Mr. Hot Rodder
Old 10-10-2016, 08:01 PM   #683
Pro Sneaker Peddler
Brake junction block **** the bed and the driver's side front caliper was frozen, so I got a new distribution block and installed some RX-7 brakes I had sitting around.
Couple things to keep in mind to anyone interested in this swap:
-have a high quality flaring tool (you will need to either get new hard lines, or modify your existing ones to work with inverted fittings--Volvo and Mazda use the same tubing diameter and fitting thread size, the difference is that Volvo uses bubble compression fittings and Mazda uses reverse flares)
-use a good tube bender
-depending on which brake 11.25" disc you use, you may need to use 5mm worth of washers to move the calipers inwards to center them with the rotors
-drilling the lug holes to 5/8" is good enough for a press fit against the hub. Myself, I'd find a 16mm drill bit
Low light pics are tough with potato
Never mind the surface rust. Rotors have zero miles on them.
Tempted to paint the front calipers gold...
Old 10-10-2016, 08:04 PM   #684
Tuff240
240 Ninja
Tuff240's Avatar
Wash yo shlt, damn.
-Patrick
Old 10-11-2016, 12:15 AM   #685
Pro Sneaker Peddler
Inorite?
Old 10-11-2016, 12:22 AM   #686
Colevette
Is there a vast difference in pedal feel with the larger rotor used in the swap? I have a set sitting around too but am undecided about them
Colevette is offline   Reply With Quote
Old 10-11-2016, 12:24 AM   #687
canyoneagle
Striving for mediocrity
canyoneagle's Avatar
Red would make a nice contrast
1979 245 DD Project
canyoneagle is offline   Reply With Quote
Old 10-11-2016, 12:31 AM   #688
Pro Sneaker Peddler
It makes it significantly easier to modulate the brakes. Definitely worth it.
Might be a little *too* much contrast, no?
Old 10-11-2016, 12:36 AM   #689
canyoneagle
Depends. Style 42's demand attention, so contrast with the calipers help pop them IMO.
Gold would be pretty damn cool, too. Don't get me wrong
Old 10-11-2016, 09:48 AM   #690
propav8r
F*ck Edgar
propav8r's Avatar
Paint it brake dust.
easiest way to run 11's is to build a 9 second car and turn it down a little.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 10-11-2016, 01:21 PM   #691
cosbySweater
brakes are still way to small
Old 10-11-2016, 01:25 PM   #692
Pro Sneaker Peddler
There is something else in the works.
Old 10-11-2016, 01:33 PM   #693
t8fanning
8v are still cool, right?
t8fanning's Avatar
Paint it clean silver, so it looks raw.
Can you lock the brakes just fine?
1982 242 Turbo.
Old 10-11-2016, 01:37 PM   #694
Pro Sneaker Peddler
They are easy to lock up
Old 10-11-2016, 01:38 PM   #695
t8fanning
t8fanning's Avatar
So John V's comments about locking up on gravel are unfounded?
Looks like I need to finally install the set I've had sitting around for a while.
Old 10-11-2016, 02:02 PM   #696
Pro Sneaker Peddler
I'm using HPS 5.0 pads. They seem to work much better overall, especially when cold. Highly recommend you get a set if you haven't already!
Old 10-11-2016, 08:54 PM   #697
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
What's new?
Old 10-11-2016, 11:14 PM   #698
Pro Sneaker Peddler
What is?
Old 10-11-2016, 11:53 PM   #699
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Paint the calipers purple.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 10-12-2016, 12:06 AM   #700
Pro Sneaker Peddler
