The 19t turbine is a bit on the small side, but it will do the job
JohnV: I know the stock cosworth cams are mild, but that 16v has significantly larger valve area and (wild guess) better flow than a stock 530 with stock valves and just ~10mm lift. There is a reason why t-cams are of zero value, other than perhaps saving you 60cm of rebar if you should need that some day
