Old 10-12-2016, 02:22 AM   #1
Otto Mattik
Otto Mattik's Avatar
Default Shock Install Headache
1992 240 wgn AW70, IPD 25/23, IPD Lwrng sprngs, VX, 155 746 yellws
I'm attempting to install new shocks, but drivrs side lowr shck bolt rusted/frozen to spacer sleeve
("Damn Yankee car")
A) Does anyone know off-hand what material the sleeve is made of(steel,alum,etc) ?
B) Will heat separate, or better to just cut and replace ?
C) Part source ? (I'm thinking volvowholesalepartsdirect yes/no? )
Old 10-12-2016, 08:05 AM   #2
57plymouth
57plymouth's Avatar
A} steel
B} cut with a sawzall
c} replace with any steel pipe about the right size laying around the shop. Or look around at Lowes.
Old 10-13-2016, 04:07 AM   #3
Otto Mattik
"replace with any steel pipe about the right size laying around the shop"
Old 10-22-2016, 03:00 PM   #4
Otto Mattik
Does anyone know the correct oem size of the lower shock mount bolt/nut/sleeve ? Where I can get these parts ?
* the bolt head is 17mm, the nut is 18mm, thanks
Old 10-22-2016, 03:03 PM   #5
It's still available new, but I have that hardware in rust free condition, make me an offer...
Old 10-22-2016, 06:32 PM   #6
Otto Mattik
I am looking in my junk parts and then off to hardware store if I can't find it(hoping to fix today).
Redwood, I will keep you mind if I have no luck locating the parts, thanks !
Old 10-23-2016, 08:53 AM   #7
freevolvos
I envy your rust freeness
Old 10-23-2016, 01:02 PM   #8
canyoneagle
Striving for mediocrity
canyoneagle's Avatar
I have a few bolts and sleeves. Free if you pay shipping. Let me know
1979 245 DD Project
canyoneagle is offline   Reply With Quote
Old 10-23-2016, 01:49 PM   #9
Otto Mattik
Thnks gents on offers, trying to figure out exact size & get car back on road today(need for work).
I have the old hacked up bolt/sleeve, off to local franchise mega hardware or home depot....
* done lots of shocks on all sorts of Volvos, but never had a sleeve freeze, weird part is, the sleeve wasn't very rusty. Wondering if it had to do with torquing on when rear bar when mounted and/or some "tweeking" that may have occurred from lowering springs (but otherwise stock torq rods, panhard bar) ??
Also, apprntly PO was around 300+ lbs
Old 10-23-2016, 06:36 PM   #10
benski
Post
Slobber some anti-seize on that new stuff before reassembly; it may save some fun in the future.
