Old 04-16-2018, 10:27 PM   #1
muppetman342
Having too much fun
muppetman342's Avatar
Question Anyone run the full Kaplhenke 240 brace with ABS?
Maybe Ben can chime in on this himself too, says the ABS MC reservoir won't fit. Does a non-ABS reservoir fit right onto an ABS MC? Says on the site that the brace would have to be modified to fit, what would have to be modified on the brace to make it fit?
muppetman342 is offline   Reply With Quote
Old 04-17-2018, 05:17 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Bump to hopefully get BNE's attention.
Old 04-17-2018, 07:10 PM   #3
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Go in the bathroom and turn off the lights. Say BNE three times in the mirror and he will appear.
Hello My Glorious!
Old 04-17-2018, 08:39 PM   #4
volvoboy67
volvoboy67's Avatar
I talked with Ben about this very issue just a couple of weeks ago on the phone. He said there is one short tube that must be clearanced to give space for the ABS-type fluid reservoir. My thinking was that I'd order the brace once he's got them back in stock (they may be now), notch the tube as required, and weld in a closure plate before painting/ coating the bar. I believe it would be a very simple modification, and Ben's comments on it seem to confirm that. Hope this helps.
DD: 2004 GMC Yukon XL, lowered 4" Front, 6" Rear, staggered 20s, custom paint work, built engine and trans, just under 500HP.
Project DD: 1965 122s coupe, very lowered, bare shell resto with full custom paint, modded B18, M41 OD trans, staggered wheel and tire combo, lots of Dynamat.
Feedback here: http://forums.turbobricks.com/showthread.php?t=208560
volvoboy67 is online now   Reply With Quote
Old 04-17-2018, 08:41 PM   #5
DrZiplok
DrZiplok's Avatar
Anyone tried this with the SN95 mustang master?
DrZiplok is offline   Reply With Quote
Old 04-17-2018, 08:46 PM   #6
muppetman342
Having too much fun
Hnnggghh I just feel strange about buying a $330, nicely made piece to cut a piece out and weld my own garbage on.
Also curious about this, don't want to block future upgrade paths.
Old 04-17-2018, 09:05 PM   #7
MDVLN
MDVLN's Avatar
Old 04-17-2018, 09:54 PM   #8
Brian (twofast242gt) runs the full brace with the SN95 Master. He runs remote reservoirs. You can find pics on his build thread.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-17-2018, 10:11 PM   #9
DrZiplok
DrZiplok's Avatar
Thanks; had to fight with PB for a bit, but got it eventually.
Looks about like what I imagined; have been trying to find a remote adapter for the SN95 master with no joy. Sadly the thread's closed and I guess he's moved on?
Old 04-17-2018, 10:55 PM   #10
MDVLN
MDVLN's Avatar
Thanks.
Old 04-18-2018, 01:05 AM   #11
DrZiplok
DrZiplok's Avatar
The universe is a funny place, it seems. The 240 non-ABS reservoir fits into the SN95 master almost like it was designed to go there. Can't warrant that it doesn't leak, yet, but it looks and feels pretty snug.
Old 04-18-2018, 09:39 AM   #12
Old 04-18-2018, 09:40 AM   #13
I am tempted to make a special version of the full brace to accommodate bulky master cyl reservoirs... Sucks adding additional parts to inventory though.
Old 04-18-2018, 09:45 AM   #14
Mr. Blewregaurd
Mr. Blewregaurd's Avatar
Went through this over the weekend. It does leak due to the fact that the 240 res. goes too deep into the mustang seals. I spaced the res. up with 2 4x11mm o rings and its perfect! Fits under bens brace, but just barley.
"It's only temporary if it doesn't work."- Red Green
'85 244 N/A Auto-x money pit
'68 220 Arts and crafts project
'04 Ranger DD/Mobile home
Mr. Blewregaurd is offline   Reply With Quote
Old 04-18-2018, 09:51 AM   #15
Thats great knowledge. Thanks Fam
via GIPHY
Old 04-18-2018, 10:04 AM   #16
Mr. Blewregaurd
Just here to help sell more braces!
Old 04-18-2018, 10:13 AM   #17
Mr. Blewregaurd
Proof
Old 04-18-2018, 10:31 AM   #18
MDVLN
MDVLN's Avatar
ok bet
Old 04-18-2018, 11:25 AM   #19
The regular reservoir also fits the ABS master cyl. The big question is the level sensor, I looked at potentially fitting the 850 cap to it because it is built in but i think it needs to be modified to work.
Old 04-18-2018, 12:17 PM   #20
DrZiplok
DrZiplok's Avatar
Proof
I pulled the seals from the SN95 master and had a good look. The Mustang reservoir spigots are actually longer and thicker so they seal on the shank.
But I was thinking along the same lines - an O-ring or two should be all it takes. Thanks for testing for us!
Old 04-18-2018, 12:25 PM   #21
muppetman342
Having too much fun
I had heard the spacing was different between the two reservoirs, but couldn't find anything definitive.
Old 04-18-2018, 12:54 PM   #22
These BMW caps with sensor fit the Volvo reservoir.
https://www.ebay.com/itm/BMW-320i-31...5alU7s&vxp=mtr
Old 04-18-2018, 12:58 PM   #23
Bong bong, nice!
hmmm, i should remeasure and see. I thought it was the same but its been a while.
Old 04-18-2018, 01:15 PM   #24
muppetman342
Having too much fun
That would be greatly appreciated
Old 04-18-2018, 04:44 PM   #25
Mr. Blewregaurd
Its off by a little, but having it seal on the flare part of the res. allows for a little fudge
