View Poll Results: which swap would you do inside a "83 volvo 240 turbo?
chevy LT1 11 61.11%
volvo 850 turbo 7 38.89%
Voters: 18. You may not vote on this poll
Old 10-12-2007, 08:41 PM   #1
judson patterson
judson patterson's Avatar
Default LT1 or 850 glt swap into "83 volvo 240 turbo
im sick of fighting with my '83 volvo 240's turbo k-jet...so ive decided to do an engine swap. im not sure what swap to do but i have ideas and id like your opinion on switch one sounds better or give me some ideas.
1). i just got an corvette engine(LT1) complete core with everything except the ecu for $800. transmission for about $500. what problems might i run into besides the engine mounts?
2). i have a friend who just totaled his volvo 850 glt. he said he would sell me the whole car for $500? i heard the 960 transmission bolts right up and i can get one of those for $300?
Got Boost? Not going anywhere fast, grab a turbo!!
judson patterson is offline   Reply With Quote
Old 10-12-2007, 08:46 PM   #2
84 Blue 240
84 Blue 240's Avatar
How about you megasquirt it and leave the engine in there? Is the GLT LPT? If so...it could make for a nice swap. Throw a bigger turbo on there and have at it.
84 Blue 240 is offline   Reply With Quote
Old 10-12-2007, 08:56 PM   #3
judson patterson
ive heard about megasquirt but how much does it run $? im not sure if its the lpt or hpt. i know it has the 15g on it? but can u tell me more about megasquirt?
Old 10-12-2007, 09:00 PM   #4
Mueller
Mueller's Avatar
msefi.com
basicly a user programmable EFI (fuel only, fuel and spark or even spark only)...can be done for $300 to $500 depending on how many new or used parts you use
Old 10-12-2007, 09:04 PM   #5
judson patterson
Originally Posted by Mueller View Post
msefi.com
thanks, if i can do it for $500, it would be nice. ill check the site out now. but wouldnt it be nice to have a corvette engine in a volvo. ive seen it done in a video.
Old 10-12-2007, 09:07 PM   #6
84 Blue 240
I got my setup from Kenny (Linuxman) and while, not installed yet, he did a fantastic job. I want to say I paid 375 bucks for mine. I am getting new injectors as well. You would need a FPR, injectors, the Megasquirt, injector connectors, a wideband (ideally), a coolant temp sensor (your factory one will most likely work), Intake Air Temp sensor (GM part for cheap), MAP sensor, maybe some sort of Crank Position sensor (Not sure about the ignition system on Kjetz cars). I figure if you do it right, you would probably be around 600 bucks and have a dynamite system. Talk to Kenny for specifics....he's the master.
BTW: You sure about the 15g? I thought GLTs only came with TD04-13g series turbos?
Old 10-12-2007, 09:12 PM   #7
judson patterson
BTW: You sure about the 15g? I thought GLTs only came with 13 series turbos?
i put a 15g on his. he use to be a volvo nut until he got a FORD.
Old 10-12-2007, 09:40 PM   #8
84 Blue 240
Ah...whiteblocks are cool, but for the price of the engine swap, MS will be cheaper and allow you unlimited mods in the future.
Old 10-12-2007, 09:45 PM   #9
davashcow
Got V8?
davashcow's Avatar
You got an LT1 sittin' around? Put that in your car. Bolt a T56 to it. Enjoy 27 mpg and the ability to destroy tires and egos.
I've just got a 302. Yours will be bigger than mine.
davashcow is offline   Reply With Quote
Old 10-12-2007, 09:45 PM   #10
judson patterson
i just called a friend. he has a harness for me but it looks and sounds confusing. i want to fully understand it before i commit to it.
Old 10-12-2007, 09:48 PM   #11
judson patterson
what challenges did you come into while swapping urs?
Old 10-12-2007, 09:50 PM   #12
Mueller
Mueller's Avatar
I don't think anyone stateside has completed an 850 or S70 engine swap into a 2xx series car....read here for more info: http://forums.turbobricks.com/showthread.php?t=96618
the Chevy might be easier, it'll still cost you a bunch of money
Old 10-12-2007, 10:14 PM   #13
judson patterson
ive looked into the chevy 350 and i was about to do it UNTILL i thought of the LT1 in it.
Old 10-12-2007, 10:20 PM   #14
Mueller
Mueller's Avatar
Chevy 350, LT1, same differance, it's going to work and more money than you think it'll be....if serious about the V8, find a "jags that run" book and spend the $30 or so (google it)
Old 10-13-2007, 12:02 AM   #15
1975v8242
Back to Basics
1975v8242's Avatar
I would say put the LT1 in it but dont go with a T-56 unless you are looking for alot of work!!!! I have a 350 with a T-56 and getting the trans to fit the tunnel was a challenge due to the size of the trans. I also had to modify the floor to move the shifter hole back like an inch and a half. It is possible but time consuming. The chevy is really pretty simple to put in but dont buy the JTR motor mount it a cheasy weak POS. Make a motor mount like this
With the stock LT1 and a good 700r4 or a T-5 the car would be fun and get like 20+ MPG as long as you dont drive WFO all the time like me
1975 242, 355 SBC, T-56, Sold
1984 245 Manual 104K miles (the new DD)
1975v8242 is offline   Reply With Quote
Old 10-13-2007, 12:07 AM   #16
740Weapon
Traitor
740Weapon's Avatar
if you actually want a car to drive and hate k-jet: just swap in LH2.2.
its basically an easy swap.
or you could acquire a more modern stand alone EMS.
otherwise: who cares, its probably going to take a year or years to complete the swap. and in the end it may deliver numbers or may always be slow and expensive.
'92 944 Turbo:13.400@99.68. Sold.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
740Weapon is offline   Reply With Quote
Old 10-13-2007, 12:15 AM   #17
1975v8242
Back to Basics
1975v8242's Avatar
My swap took me 2 months NOT YEARS and cost a little over $4000 total with the T-56 and everything. Swaps are not nearly as expensive as everybody will try to tell you. The key is to Bargain shop make lots of Wrecking yard runs and become good friends with Craigslist.
Anybody who takes years or even a year to do an engine swap probably shouldnt have attempted the swap in the first place.
Old 10-13-2007, 12:18 AM   #18
740Weapon
Traitor
740Weapon's Avatar
well go drag race and/or tell me how fast your swap is.
4k is expensive.
edited: my 14.2 quarter mile cost me about $1000 in engine mods and then i made the car even faster.
edit: i helped my friend put an ls-1 in an rx-7. it took a summer and turned out relatively well. took about 6k total. still wasnt worth it in terms of the overall vehicle performance.
Old 10-13-2007, 01:59 AM   #19
1975v8242
Back to Basics
1975v8242's Avatar
4k is expensive.
Fastest pass to date 7.50 @ 89mph on Street tires with welded Spider gears.
Old 10-13-2007, 12:45 PM   #20
740Weapon
Traitor
740Weapon's Avatar
1/8th?
that is pretty fast.
too bad a corvette LT-1 or whiteblock would probably take about that much money to go that fast even without the cost of the swap itself.
Old 10-13-2007, 04:17 PM   #21
judson patterson
im thinking about switching to lh2.2. not sure!! if its going to cost me 4 grand to do it. in my eyes, its not worth it right now.
Old 10-13-2007, 04:23 PM   #22
adrianpike
adrianpike's Avatar
uhhhh this is Turbobricks. $4k is like 95% of the entire board's car **** budget added together for a year.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 10-13-2007, 08:55 PM   #23
1975v8242
Back to Basics
1975v8242's Avatar
1/8th?
Your probably right my car is smog exempt which opened alot of doors for me especuially cost wise.
7.50 is pretty fast but I want to go faster NITROUS is next
Old 10-14-2007, 12:11 AM   #24
marchul
quarter ricer
marchul's Avatar
Sig'ed
Even though its a lot of money... V8's are so cool!!1! That would be the main reason why I would do it. People just dont understand Volvos, but you can impress everyone with a Chevy-powered Volvo, if thats your thing.
'82 242t+ic Miss it...
'05 Mazda6 3.0 MTX Oh yeah...
marchul is offline   Reply With Quote
Old 10-14-2007, 10:08 PM   #25
DecalServiceBrett
Alex Butchka.
rofl
DecalServiceBrett is offline   Reply With Quote
