Old 11-18-2013, 11:57 PM   #76
vvpete
the best AFR gage is a spark plug
vvpete is offline   Reply With Quote
Old 11-19-2013, 06:07 PM   #77
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
This is the wideband I have. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
It is an AEM 30-4100 Digital Wideband Air/Fuel UEGO Gauge.
I am just using the preset readout. which has a readout of 0-4.25 volts. I also still have my stock bosch o2 sensor in as well.
Here is the little bugger.
In that last picture, it is too the left, same as the pic before. It is angled up 10 degrees, as per the instructions.
I notice two of the pictures are quite large, photobucket should change that soon-ish.
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 11-20-2013, 07:20 PM   #78
volvoboy90
volvoboy90's Avatar
*bump?*
Old 11-20-2013, 08:07 PM   #79
TrickMick
Broad Member
TrickMick's Avatar
Originally Posted by volvoboy90 View Post
*bump?*
put your DVOM on the NARROWBAND and measure the sweep...
put a piece of duct tape over the face of the "A/F Ratio Meter"
( we don't want no steenkin clutter )...*IF* you have a set of
NEW SPARK PLUGS (as in *NEW* not "new to you" ) get them gapped
and ready to roll - whether you install or not depends upon what
results you get from READING THE SWEEP on the O2 sensor that
is feeding the fuel / ignition system....we want this to be a
"two part-er"....one at idle and one under boost...)
read up on performing a *PLUG CHOP* (I'll let YOU work the
google machine... ... )
TTFN
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 11-21-2013, 04:52 PM   #80
volvoboy90
volvoboy90's Avatar
DVOM... You lost me, trick. Sparkplugs were replaced last month... So... yeah. wait... Digital Volt Ohm Meter? or Digital voltmeter?
Old 11-21-2013, 06:14 PM   #81
TrickMick
Broad Member
TrickMick's Avatar
DVOM = Digital Volt Ohm Meter
http://ocw.mit.edu/courses/physics/8...ulitimeter.pdf
http://www.mikroe.com/old/books/keu/11.htm
http://design-technology-in-stem.x10...tsFinding.html
http://www.autoshop101.com/forms/h4.pdf (a good'un)
Old 11-21-2013, 11:21 PM   #82
volvoboy90
volvoboy90's Avatar
A plug chop sounds dangerous to do under boost... or while driving at all... I have a multi-meter from Harbour Freight. It does just Dandy.
Old 11-22-2013, 04:14 PM   #83
vvpete
Most likely too slow a response to pick up the O2 sensor sine wave output. My $30 Sears DVM cannot, but my $130 Radio Shack (Fluke) can, something under 10 ms response should work. Here's where a DVM with a min-max storage helps a lot, too.
Old 11-22-2013, 05:08 PM   #84
TrickMick
Broad Member
TrickMick's Avatar
so what happens when your engine dies whilst driving
(the lights come on the engine stops you push in the clutch
and drift to the side of the road...)
the only diff here is that YOU are gonna cut the engine off...
I do this on Bikes ALL THE TIME and I ain't dead yet...
of course I also do this in DYNO CELLS but you haven't told us
(yet) that you have a dyno (and I would drive to see your dyno if
ya get one...I wanna run my ground piercing radar rig over Wright
Patterson so I can "see" *ALL* of the levels below...hee hee....
Old 11-22-2013, 05:17 PM   #85
volvoboy90
volvoboy90's Avatar
Hehe... no, no dyno... Just a two car garage you can't fit a single car into. That's one thing as well, she is an Auto-Majic. So shift into Neutral, or just turn the key and let her coast? Just so I get my facts straight. We got a cold front moving through tonight, making freezing highs for all next week, so checking the sweep of the Wideband may take some time, and I won't really be able to do much of a plug chop either... Hrmmm....
Old 11-22-2013, 05:52 PM   #86
vvpete
One thing I just noticed after you saying the WB would need warm-up, next time you install one, do it much closer to the ex outlet at the manifold. That way you get more accurate numbers about what you're engine is doing, since the hot ex gases do the warm-up for you, unlike the O2 sensor down the header pipe near/in the cat, which is heated.
You can probably disregard the numbers from the WB unless you've driven it for ~15-20 min, and be stepping on it to get the WG to stay open so the ex gases heat the sensor.
The most accurate placement for the O2 sensor (WB) for engine management (think B21FT and K-Jet) is in the ex manifold itself. A lot of people don't consider this when doing the +90 manifold, the engine management comes from O2 sensor feedback not a fuel map like LH xxx. and on LH the O2 sensor is there for emissions fuel trim and does little for engine management. Does little for WB accurate a/f measurement.
Your WB needs to see that same kind of info as does the K-Jet O2 sensor.
Old 11-22-2013, 07:37 PM   #87
volvoboy90
volvoboy90's Avatar
Aye, I didn't think of it when I had the original Narrow-band put in, and just figured "by the original" would be fine. Unfortunately, too, my commute in the morning is 15-20 minutes. If I ever have to replace that downpipe, I don't know what I'll do, since it was pretty much a one-time shot. It is half original Starla down-pipe, half custom downpipe from a friend. Noticed today, it is taking longer to crank on start-up than usual...
Old 11-23-2013, 08:30 PM   #88
volvoboy90
volvoboy90's Avatar
Here is a quick question. As far as the wire I am using to measure the sweep, will it be the wire that "would" be going to the fuel injection if I had it hooked up that way, or is there a certain wire going to the meter itself I should use? This cold weather is stunting my progress, had some snow come down, and it has been freezing all day. The prolonged cranking has stopped, at least.
Old 11-24-2013, 12:23 AM   #89
kampman
dunning-krugersquirt
e:nm
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
Old 11-24-2013, 02:14 PM   #90
TrickMick
Broad Member
TrickMick's Avatar
by using the *google machine* configured thus:
* turbobricks.com/ and entering your query here* you get what you look for
in this case here is the way I asked the google machine for help :
"turbobricks.com/testing the Oxygen sensor"
http://turbobricks.com/forums/showthread.php?p=1309083
Old 11-24-2013, 02:53 PM   #91
volvoboy90
volvoboy90's Avatar
Fair enough... Will attempt to pull this off next time I have a buddy over to help out. Thanks, Trick.
Old 11-24-2013, 08:24 PM   #92
TrickMick
Broad Member
TrickMick's Avatar
Old 11-24-2013, 09:57 PM   #93
volvoboy90
volvoboy90's Avatar
Yep... If I can get this fuel trim issue gone for good, and be rid of that annoying sound in the rear, I will be golden.
Old 11-24-2013, 10:48 PM   #94
TrickMick
Broad Member
TrickMick's Avatar
work on the testing stuff and quit eating brussels sprouts and beans....
FIXED.....
Old 11-25-2013, 06:41 PM   #95
volvoboy90
volvoboy90's Avatar
That's great... *sigh* thanks, Mick. I needed that...
Old 11-29-2013, 05:37 PM   #96
volvoboy90
volvoboy90's Avatar
So I tested the o2 sensor today... not the wideband, haven't had a chance to pull it from my dash to change the position on it. From what I could tell, it did read sluggishly, taking a second or two to register vac leaks, and running rich. When I did the dynamic testing, it was at both extremes of the fuel map, going as rich as .8 and then to as lean as .1 but never really getting close, or staying near .5.
Old 11-29-2013, 11:09 PM   #97
TrickMick
Broad Member
TrickMick's Avatar
you're OK.....it's the SWEEP that is important (and your measurements prove the sensor to be "reacting CORRECTLY* to the mix in the exhaust gasses)...hmmmm....if the meter reads an S-L-O-W "shift from 0.1 to 0.8 Volts (this is ASSuming I understand your observations)...SPEC is 1Hz "sweep"
I notice you point out the "sluggish response to an artificially created vacuum leak"... it *could be* just a lazy sensor but the numbers you've provided indicate the "system" IS going into closed loop....
here is a decent screed on the subject of "testing the O2 sensor":
http://www.autodiagnosticsandpublish...or-testing.htm
Old 11-30-2013, 05:17 PM   #98
volvoboy90
volvoboy90's Avatar
So you think it's OK? I read a little of that article, haven't had much of a chance. Not really sure where to go from here. I did talk to my friend jc, he said the lack of vacuum in gear could possibly be the cam. After some maths, I found I am still getting ~17mpg.
Old 12-01-2013, 05:26 PM   #99
volvoboy90
volvoboy90's Avatar
Now obviously, my multimeter cannot test several times a second. I mean, it is decently quick, but not that quick. I did tighten down an exhaust leak yesterday, just for the sake of it, really. It was too far downstream to affect the afr's. I really am just stumped. No vacuum canister to leak, no hvac system to be leaking. it is just a closed system with the PCV, boost gauge, FPR, IAC, brake booster, and the whole intercooler piping being any issues for vacuum leaks. Idle still maintains at ~500 RPM. I have clamps or zip-ties on all vacuum piping. I am just really... stumped.
Old 12-01-2013, 05:41 PM   #100
TrickMick
Broad Member
TrickMick's Avatar
17 mpg in a TURBO CAR (that you can "FEEL the EXCITEMENT
shove you back in the seat")...is THAT what's botherin' ya??
DAHUM man....I have a "warmed over B230f" *N/A* that I get 24
to 26 mpg if I play NICE and 20-22 mpg if I go all hooligan on the
two lane blacktop....
I just inherited a 1989 245 (M47...etc) that is gonna have to stand in for
the 1993 "Special Edition 245" that I REALLY wanted to use as the basis
for a sleeper deluxe....(LSx and T5....cranked suspension and meaty boy
tyres)....the "ultimate DRAGON WAGON" (at least for me)....coming to a
high road near you in late 2014....in basic white and no "outward signals"
that it hath a HUGE heart....my final "car project" as I'm starting to get
"cripped up" due to advancing arthur-itis ("Is that damned Greek here again...?? )
carry on old son...carry on.....
