Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Anybody done this? Seem like a pretty easy solution to be able to go over the rear instead of under. This is for an LS swap so I thought it might be easier to set the fuel system up that way as well. Just wanted some opinions. Thanks
Just to make sure, are you doing a dual exhaust all the way or joining pipes before the rear axle?
If dual, going over the axle on the left side is not doable because of the panhard bar. With single pipe 3.5" is pretty much the biggest that can be fitted with minor work that doesn't require touching the tank.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
