I found out that akebono don't squeal with good rotors.
Which ones? I've used Volvo, Textar and Brembo branded rotors. All with the same results. This is on the P2R though, not 240's.
Jordan
Ugh brake squeal can be the worst. I had the porsche 993 set on my t5r before I switched to Stoptechs. They were great and quiet, I moved them over to Theresa's 850R (the 993s) and no combo of pad or disc would stop them from squealing in the worst way. I could literally hear the car coming 2 blocks away.
Literally fine on one car, squealed on the other. Drove me insane.
Do they run akebono (sp?) pads? Every car I've put them in has squealed like crazy.
Man you are just having all kinds of problems with your rear.
If it doesn't hurt, you're not going fast enough. Stopping fast enough. Whatever. 8)
Any idea whats causing the back to break?
With all new lines, the R brakes without the Mustang MC feels like nice stock brakes in my car. I just finished the push rod extension you need, here's a pic. Both sides are rounded so you have to take that into the measurements, and I rounded off the top by hand/dremel.
Wilwood p/n 300-13885
https://www.summitracing.com/parts/wil-300-13885
We are having shims made for our brackets, see if they make a difference. None of our cars squeal. my buddies car squeals at low force braking. He is going to try them out.
