Jimmy E. James
Banned
- Aug 30, 2016
I do, every time and alwaysYeah I know. I bought the crank tool used a long time ago from a local guy. Use it every time I do the t belt.
I was wondering if people properly torqued the crank bolt and then added the additional degrees like you're supposed to. I recall doing that on my 1st or 2nd timing belt and then having the bolt come loose. My guess was an inaccurate torque wrench.
Now I just MAKE SURE the pulley is fully seated so I don't shear the keyway off (that's what happened when my pulley came loose and fell off), then I just tighten the living **** out of the crank bolt. Probably not 'ideal' but works every time.
Use the "aircraft" torque method - you know how it goes: just as soon as you think it's safe to go back in the water - just done it that way since I first started with a Volvo - peace of mind - you CAN break those cranks - seen it done, at the dealership (long ago and far away)
I keep a stiff paper 60 degree protractor I made from a manila folder ages ago taped to the wall in the garage - just tape it to the crank stub when the time comes for it
You got the holding tool - you got the pull handle and pipe - just cut yourself out a protractor - it adds no hassle to the job
