I've just switched to a 90mm MAF housing for my 850R in order to accommodate greater than stock airflow with the 20T.
In heavy stop/start traffic on a busy day the engine cuts out - this is my theory as to why:
- The MAF, enlarged in order to accommodate the much higher than stock airflow is not great at low air flow any longer
- This is ok when temperatures are low to medium - when the car is in motion, basically
- In 10 miles of typical London traffic jam on a hot day the under bonnet temperatures climb significantly
- The hot, low speed air isn't within the MAF's ability to read
- It's the MAF sending "no air flow" to the ECU, which then cuts fuel, that is causing this problem
Sound plausible?
If so, what's the most effective way to manage very low speed/hot day/under bonnet temps?
Cut a big hole in the bonnet? Fit a massive fan?
Sound plausible?
