Old 08-29-2017, 03:19 PM   #76
I'm glad this thread has been so successful! I plan to fix the pix.
Old 09-27-2017, 04:01 PM   #77
Pete.M
Slow Member
Pete.M's Avatar
EZK pin 5 is written up as being for "Supply voltage 30+. Power supply for on-board diagnostic (OBD) system memory and the adaptive function".
What adaptive function is this referring to? I suspect it's not required but I want to make sure.
Pete.M is offline   Reply With Quote
Old 09-27-2017, 10:09 PM   #78
bobxyz
bobxyz's Avatar
EZK pin 5 should go to unswitched +12v. If you're using a LH2.4 harness, it will be connected to the 2 big red wires, and to the system relay, and to ECU pin 4. This is the voltage that keeps the learned/adapted behavior when the ignition switch is turned off. In the ECU, this includes fuel trim adjustment and saved CEL codes. For the EZK, it might just be saved CEL codes -- off hand, I can't think of anything else the EZK would save.
'85 245glt aw71 k-jet -> lh2.4
Old 09-27-2017, 10:13 PM   #79
jamesinc
WD-40 Enthusiast
jamesinc's Avatar
Yeah it's for persisting codes from the EZK. Not connecting it is just asking to make your life difficult when you're troubleshooting running conditions.
1985 240GL, 1989 740 Turbo wagon, 1992 240, 1977 244DL, 1980 244GL, 1996 850R wagon, 1985 360GLT
Founder of the Australian Volvo fourms, http://ozvolvo.org
jamesinc is offline   Reply With Quote
