Old 01-02-2014, 08:17 AM   #51
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Btw... The pics are dark because my garage is kind of a darkroom.. it is just ****ing dark in there.. cold and dark... :(
:D
Some Updates... Coilover and Twinscroll ongoing...
I hope my math will do the job... made the cutoffs 8cm in lenghth and cutted at an angle of 27°
Old 01-03-2014, 08:43 AM   #52
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Shocks have arrived...
Old 01-06-2014, 10:56 PM   #53
megulon-7
Originally Posted by MadDog_945 View Post
Seat is in...
Problem... If i sit in it the steering wheel would be there where the backside of my kidneys are... Also i can adjust the rearmirrors with my forehead :D
Seems that i need to cut out the brace/tunnel where the factoryseats bolt on to or the harness and airchannels go through
Anybody done that before?
I cut out that seat platform on my 240 when installing racing seats, its bunch of work but needs to be done, you will want the seat way further back, You start to run out of room quick with a helmet on and roll cage tubes eating up space. Aftermarket steering wheel with a hub moves farther back than stock, adding to the problem.
For good handling you will want to sit as far back as you can, if you are really going for it, think about moving the pedals back (an aftermarket floor mount pedal set up is the best).
Also along these lines, your roll cage main hoop should be way back too, not at the B-pilar, or even on the floor but all the way back up on the "shelf" under the old back seat...
megulon-7 is offline   Reply With Quote
Old 01-07-2014, 03:48 AM   #54
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Awesome.. do you have pics of that ?
I found a position with the seat which is really comfortable for me with original pedalbox and the seatplatform in the car now.. so im thinking about just let everything as is and try it.. but you're right.. the mainhoop cannot be installed directly with the B-pillar.. it has to move to that location where the 242 has its B-pillar..
Old 01-08-2014, 04:03 AM   #55
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Some stuff i did the last few days to make this stuff fit.. ;)
Old 01-13-2014, 04:10 AM   #56
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
some progress...
I also had a snapped bolt in the bottom bushing.. don't know what it is called in english... that one where the strut rests on... welded on a nut.. snapped 2mm deeper.. helicoiled the **** out of that ****er But i forgot to take pix...
Old 01-16-2014, 08:08 AM   #57
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Camberplates have arrived
Is it normal that the bearings don't move? Im not able to push them in any direction even not with a lever...
Old 01-16-2014, 08:51 AM   #58
crogthomas
crogthomas's Avatar
Default camber
They're normally stiff, but they should move with a lever. Clamp the plate in a vice and put a bar through the middle.
What camber plates are they?
crogthomas is offline   Reply With Quote
Old 01-16-2014, 09:28 AM   #59
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Universal Mookeeh, have to drill holes by myself... thx, will try that...
Old 01-16-2014, 02:37 PM   #60
evan55
Single-Slammer
What kind of shocks? and how much did those camber plates cost?
evan55 is offline   Reply With Quote
Old 01-17-2014, 04:19 AM   #61
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
deCarbons... for now... will be replaced with 8610s/8611s in the future, 80 bucks... ebay: universal Camberplate Datsun, Civic, Accord, blabla..
Look out for the "mookeeh" logo on them.. all the same... probably also the ones douchenozzle used for his camberplatekits
Btw.. those bearings dont move a **** even when bolted to the shock... ?!!
/edit
As you can see the baseplate could be bigger
Old 01-17-2014, 05:10 AM   #62
2fast242gt
Do you have a cobalt?
Somtimes its worth spending a bit more for quality camber plates with quality bearings.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 01-17-2014, 06:37 AM   #63
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Bababa, you again ;).
Old 01-17-2014, 08:53 AM   #64
towz-T
EL hipo explosive
towz-T's Avatar
whack it with a hammer
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 01-17-2014, 10:32 AM   #65
Urvanej
Great build but do not forget on your B234FT
Can you give some advice about the spring stuff on the strut? Where to get it best for a europian guy? (I do not know how is it called but I mean the thing that hold the spring with adjustable nut.)
Urvanej is offline   Reply With Quote
Old 01-17-2014, 11:33 AM   #66
doucheNozzle
doucheNozzle's Avatar
I already confirmed that they are. You need to cut out the strut tower so those can sit flush and be adjusted.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 01-18-2014, 01:11 PM   #67
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ah ok
Were you able to move the bearing?
Old 01-18-2014, 01:39 PM   #68
doucheNozzle
I didn't check all of the ones I sold but typically they did.
Old 01-18-2014, 01:43 PM   #69
bottlingguy
bottlingguy's Avatar
Nice build!
Here is a link to mine:
http://www.forums.turbobricks.com/sh...d.php?t=242549
It was a lot of fun on the tracks here in California. It just needed a bit more power so you having a 16v +t should be perfect!
bottlingguy is offline   Reply With Quote
Old 01-18-2014, 01:50 PM   #70
bottlingguy
I don't think you need to move the driver seat around that much, we did not have any clearance problems with the seat/driver/rollcage and I am 6 feet and 215 lbs
Old 01-18-2014, 01:51 PM   #71
The Full Banana
not yet good enough
The Full Banana's Avatar
The bearings in mine move just fine.
-Tom 1980 242 T5
Old 01-22-2014, 09:38 PM   #72
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Wrote them a mail.. lets see what they say...
Old 02-03-2014, 04:45 AM   #73
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. it can move
Old 02-08-2014, 10:41 PM   #74
centason
Knipex=welfare queen
centason's Avatar
Did you ever use the 9" coil springs, or stay with the 8"?
Member: TBCCS
"Democracy is the art and science of running the circus from the monkey cage. Democracy is a pathetic belief in the collective wisdom of individual ignorance." -H. L. Mencken
Old 02-13-2014, 05:50 AM   #75
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I never used anything without teh jackstands.. i hope this theoretically **** will function when removing them ;)
My new CageMachine arrived...
