Old 04-25-2016, 04:00 PM   #51
madeRus
madeRus's Avatar
guys! how to move my topic - projects & restorations?
madeRus is offline   Reply With Quote
Old 04-25-2016, 04:17 PM   #52
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Originally Posted by Fretka View Post
By the way, so you don't have to weld the bell, we (abc-clutch) offer adapter kits to bolt on BMW boxes on Volvo engines. Next time hit me up (:
Is this the one you speak of? - http://www.abc-clutch.com/portfolio/...ox-adapter-kit
What would be the price for that? (one isn't listed and the E-Store link is blank)
A moderator has to move it for you. A common way to do it is to report the first post and state that you want it moved there, or hopefully staff that is browsing can do it for you without abuse of that feature.
Old 04-25-2016, 04:23 PM   #53
madeRus
madeRus's Avatar
I called them many times over the price , but there is no one answers the phone !
Thank you! and it is possible to write a moderator ?
Old 04-26-2016, 01:40 AM   #54
LC4CARL
Aero challenged
LC4CARL's Avatar
Is it spring there yet? I'm at the 45th parallel, how far north are you?
Life begins at 10PSI.
Old 04-26-2016, 03:37 AM   #55
madeRus
madeRus's Avatar
it was February ! )
The coordinates of the historic center of - 59 ° 57 ' s. w . 30 ° 19 ' in . d
St. Petersburg city is the northernmost of the world's cities with a population of over a million people . City of St. Petersburg is located in the northwest of Russia , within the Neva Lowland , on the adjacent to the mouth of the river Neva shore of Neva Bay and the Gulf of Finland on the numerous islands of the Neva delta. The area of ​​the city - 1439 km² .
Old 04-26-2016, 03:43 AM   #56
nordmaschine
forced instruction
nordmaschine's Avatar
Jesus, I'm on 44 North (17 East) and it's sunny here, 6°C, at the moment.
Had ice storm yesterday and 30°C-ish the day before. Talk about world climate going south, right?
Jetronic is romantic.
Whiteblocks
Old 04-26-2016, 04:48 AM   #57
madeRus
madeRus's Avatar
at the moment we have eight Celsius .
has already begun to turn green grass on lawns )
Old 04-26-2016, 12:25 PM   #58
nordmaschine
forced instruction
Yeah, 16°C now, had to cut grass around srcap cars...
Now, how's your car coming along?
Old 04-26-2016, 12:28 PM   #59
madeRus
madeRus's Avatar
All rises smoothly and the bonnet is closed ) and a coaxial transmission with rear-wheel drive
the engine is old for trying !
Old 04-26-2016, 06:32 PM   #60
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Seems like a lot of dremel action this weekend ;)
Old 04-26-2016, 09:19 PM   #61
LC4CARL
Aero challenged
LC4CARL's Avatar
Looks nice!
So, I'm new to Volvo. My '87 has a B230? Where did the twin cam motor come from? That looks very sexy.
Old 04-26-2016, 09:53 PM   #62
John V, outside agitator
Looks nice!
Yeah.. The intra-webz lore has it the early B230 has what TBers call "the 9mm rods"* which are flat scary weenie....and it has a crank with 55mm main bearings which is supposedly terrible and worst of all it has the dreaded "Center thrust bearing" which is guaranteed to ass-splode and kill everybody in 50m radius..
Now if anybody just happened to actually look around they might see plenty of modern engines with main bearings in the 55-57mm range...
And if they noticed that the thrust bearings (these things)
(but not flanged bearings like that, instead like-a dis
loose)
were only 180 degrees per side kinda like you see in the photo RATHER than like this**
which are what old B20, B21, B23, and later B230 have---that is to say a full 360 degrees
then they might begin to wonder if the alleged thrust problems were related to the sting 180 degree design or the lack of 360 degrees---rather than the placement at center or rear..
Shirley, I could not comment myself...
As for where the 16v came from or on, some later maybe just 88-89 model 7 whatever...
* this is in shocking contrast to the just flat absurdly beefy---and outrageously heavy---"M" rods in the early motors and the "only slightly less appallingly wimpy so called 13mm rods" which came at some impossible to say when time in late 89 maybe..
** astute reader may notice the little tang thing stickin out..They may further notice that if there were a little relief ground into the block or main cap that a second set of thrust bearings could be slid home and make a early crank into a 360 degree thrust.. It sure looks super easy..But evidently its impossible to do since none of the Volvo hero shops that have come and gone has ever done it....Then again no Volvo shop figured out how to easily add under-piston squirters in a easy and fool proof way either...So it must be impossible.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 04-27-2016, 03:48 AM   #63
madeRus
madeRus's Avatar
Looks nice!
the head unit from the motor b234 valve 16
Old 04-27-2016, 03:53 AM   #64
madeRus
madeRus's Avatar
loose)
my bad english ) )
translator shows me some strange text) )
that short you want to say ?
Old 04-27-2016, 04:05 AM   #65
madeRus
madeRus's Avatar
Thanks for the transfer of topics in the showroom section
Old 05-04-2016, 11:42 AM   #66
madeRus
madeRus's Avatar
Now I need to decide on the clutch !
you need a soft grip and that it held 900 Newton meters and 700 horsepower
Old 05-05-2016, 07:51 PM   #67
Pasis
Привет Дима, не плохо получается) я тут тоже занялся своим чемоданом не много)))
Pasis is offline   Reply With Quote
Old 05-05-2016, 11:43 PM   #68
LC4CARL
Aero challenged
LC4CARL's Avatar
What! 700 HP?!
Old 05-10-2016, 11:25 AM   #69
madeRus
madeRus's Avatar
привет) красава
ты случаем не знаешь, что имел ввиду человек выше? где полукольца на фото (а то я ничего не понял)
Old 05-10-2016, 11:25 AM   #70
madeRus
madeRus's Avatar
What! 700 HP?!
Old 05-18-2016, 10:21 AM   #71
towz-T
EL hipo explosive
towz-T's Avatar
just mailed them.
prices where
€2250 for the twin kit
€2480 for the triple +postage
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 05-18-2016, 12:06 PM   #72
madeRus
madeRus's Avatar
Originally Posted by towz-T View Post
just mailed them.
prices where
Old 05-18-2016, 12:13 PM   #73
madeRus
madeRus's Avatar
I want to book a seat Bimarсo ! they , unlike its competitors (SPARCo sabelt and Recaro ) are not expensive and have a homologation
the price of 125-340 $ per seat (depending on the sport )
It remains to understand the size !
and bringing them to us in Russian from Poland
http://bimarco.eu/
Old 05-19-2016, 08:28 AM   #74
towz-T
EL hipo explosive
towz-T's Avatar
ooh, never heard of them. THX!
tak a look at the omp homologated seats (these are FIA 8855-1999)
the cheapest ones come in at about €200
Old 05-19-2016, 09:44 AM   #75
RAlexC
RAlexC's Avatar
Wow! This is looking great! you've got an awesome build on your hands
RAlexC is offline   Reply With Quote
