SoDakVolvo
- Sep 22, 2012
- Sioux Falls, SD
I have a 1991 240 that starts fine, idles fine, then won't rev up past 1500rpm. Ive replaced the plugs, cap, rotor, crank position sensor, fuel pump, fuel filter, fuel pump relay, fuel pressure regulator, fuses, intake/tb gaskets, air filter, flame trap. I've also tested known good mass air flow sensor and idle air control vavle and cleaned the intake manifold and tb. What are my other options? Ive seen something about the o2 sensor causing issues, or could it be the coil,powerstage,plug wires something stupid like that? And yes ive used the search function: http://www.volvo-forums.com/t39071-1991-940-gle-won39t-rev-past-1500rpm.htm http://www.turbobricks.com/forums/showthread.php?p=4063139 and nobody had any cures there either. So any help is appreciated before I just give up and junk it haha.
