Tuff240
240 Ninja
- Jun 27, 2002
- Central California
I asked if CASTER was adjustable. Well, that's what I was supposed to type if I typed camber instead... I know what both are, I just didn't know if there was some sort of way of adjusting the caster on the car that I don't know about yet. Guess not...tuff240 said:If you know what it is, then why did you ask if it was adjustable?
klr142 said:You already pulled them???? Glad to hear it isn't bent... Lol, he better have given you that manual and guages for free... I think let him charge me too much for the correct tach... $20! There was also a fog light switch which I nabbed, some Virgo lug nuts that I put in the glovebox of the car that you pulled the sways off of, and then there was some other stuff there as well. Including some ok-ish black headrest inserts, but one of the tabs broke off I think when I pulled it off the seat, the calipers and maybe the rotors as well off of the 164, and a 16v engine... Looked like a very mildly touched yard indeed! The guy definitely wanted money for things though. I don't know how much I want to pull that tranny, and damnit, I forgot to check what year the car was! I was going to check that, but forgot. I want to know if it's LH2.4 or not. I wonder if the pedal assembly is in decent condition anymore, probably not... I called Ross and told him about the 164, it has some stuff that he'd like for his car...
tuff240 said:That started in 87 iirc, along with the m47.
tuff240 said:It gives you an extra cubby hole if nothing else. I think you need the actual belt also though.
klr142 said:What I should do, is make a graph of our two runs on top of each that has the same scaling... One with the trq values, and another one with the hp values. I don't have much time though, so I don't know if I'll get around to it. It'd be cool though.
Yeah, Fred put together a spreadsheet with some information on most of the available OHV Redblock cams. Here ya go Paul: http://forums.turbobricks.com/showthread.php?t=48858&highlight=cam+tableB20Paul said:Hi guys, have you got any specs on the V15 cam?
