Go Back   Turbobricks Forums > General > website & board
Old 11-12-2014, 10:44 AM   #301
84B23F
84B23F's Avatar
14F (-10C)
1993-245 , LH 2.4, with Bosch 0 280 155 746 Injectors....5w-30 synthetic oil
Key switch to on....wait about two seconds to prime fuel rail...key switch to start...normal startup
IIRC, last year, 245 took a few extra cranks to fire up in colder weather.
Old 11-14-2014, 02:58 PM   #302
84B23F
84B23F's Avatar
Originally Posted by klr142 View Post
You forgot to mention the main reason your gas mileage has dropped... It's cold out and the engine takes longer to warm up, so it's in warm up mode longer(aka, uses more fuel).
1993-944 with Regina, which is a Speed Density fuel injection system, and it measures inlet air temperature. I had removed heated exhaust-air-tube since air-box thermostat is not working.
Today, fuel mileage went up some 5-mpg (US) when I hooked air-tube direct to exhaust port for it. I bought an Acurite wireless weather therometer and inserted wireless sensor into air box. Around 32F (0C) at 55 mph, inlet air was running around 100F (38C) on level ground, and upto 111F (44C) in hilly terrain.
Hence, cold inlet air temperature was increasing the fuel burn.
Old 02-14-2018, 08:11 AM   #303
240240
I crush everything!
240240's Avatar
I feel like with New cali gas blend every year I get less mpg.
I know what I have, and you can buy it here
Old 02-14-2018, 08:19 AM   #304
84B23F
84B23F's Avatar
....with New cali gas blend every year I get less mpg.
California Reformulated Gasoline Program
Old 02-14-2018, 12:12 PM   #305
klr142
Turbo, what?
klr142's Avatar
It makes sense that the engine warming up faster will reduce the amount of time that it's in warm-up enrichment, thus providing better gas mileage. How is the power change? Any noticeable difference? Do you/did you install a new thermostat in the airbox so that it stops the hot air intake when the engine is warm? Some of these engines will detonate if they're still getting hot air when warmed up, at least on LH. I don't know if Regina gets around it.
Old 02-15-2018, 01:35 AM   #306
84B23F
84B23F's Avatar
Do you/did you install a new thermostat in the airbox.
Yes, but air-inlet duct is now plumbed next to radiator air flow, near top of fan's radiator duct; I really don't like full exhaust heat.
On really cold days, -8F, traveling around 30 mph, it takes some four miles to bring engine up to normal run temperature.
Mileage varies between 25-30mpg...all depending upon terrain, wind, speed, temperature, etc.
Engine is a rebuilt 1984 B23F inserted into a 1993 944 with Rex-I/Regina. This is a higher compression B23F engine, btw. I'm not a power stomper, but power is better than 1993-245.
Old 02-15-2018, 12:30 PM   #307
klr142
Turbo, what?
klr142's Avatar
Cool. What camshaft do you have in it? Stock or thinner headgasket?
Old 02-15-2018, 12:39 PM   #308
Pro Sneaker Peddler
I managed 18 combined on my last tank
Old 02-15-2018, 02:02 PM   #309
klr142
Turbo, what?
klr142's Avatar
I've been doing 19-21 combined(mostly city) for the past few months(winter).
Old 02-15-2018, 06:00 PM   #310
84B23F
84B23F's Avatar
Stock, but when head was rebuilt, it was taken to a machine shop, and shaved.
Old 02-15-2018, 06:48 PM   #311
klr142
Turbo, what?
klr142's Avatar
Slap a T in it.
Old 02-15-2018, 06:55 PM   #312
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Wife's car logged 20mpg combined with her 244 with a T cam.
-Stephen
#mclovethesenuts
Old 02-15-2018, 07:00 PM   #313
Pro Sneaker Peddler
Wonder how much better my fuel economy be if I had any self-control
Old 02-15-2018, 07:01 PM   #314
KeizerBrickGuy
Sh*t pot stirrer
You wouldn't blow up rear ends every month.
Old 02-15-2018, 08:42 PM   #315
84B23F
84B23F's Avatar
engine warming up faster .... Regina...
Side note - With 0w-40, vehicle sitting overnight, primed fuel rail (ignition on for several seconds) and a cold -10F, engine snaps to life, just like on warmer starts.
LH 2.4 does not ignite until several cranks later...
My 2.8 V6 GM has to roll the crank several times, and then takes about 5 seconds to get up to idle RPM....but its a 300k engine.
Old 02-16-2018, 01:36 AM   #316
klr142
Turbo, what?
klr142's Avatar
Interesting. A couple friends have LH cars that have a weird extended crank thing, too. I don't know if what you're describing is normal but it's hard to say without being there.
Old 02-16-2018, 02:11 PM   #317
84B23F
84B23F's Avatar
...LH cars that have a weird extended crank thing, too.
Correct, LH 2.4 on 1993-245, late production model....summer, winter, same pattern...extended crank
Old 02-16-2018, 10:07 PM   #318
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
My car logs...I'd rather not say
'91 744t...it's fast as phuck
Old 02-19-2018, 09:10 PM   #319
LC4CARL
Aero challenged
LC4CARL's Avatar
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 02-20-2018, 11:42 AM   #320
esmth
dirty swede
esmth's Avatar
I just got 28 MPG on my last round trip to my parent's place. I was driving like a pansy though
1991 244 +T LH2.4 m46 287k miles with B cam advanced 4*, 962 fuel & 148 ezk, T5 white injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies
