Go Back   Turbobricks Forums > General > website & board
Old 08-29-2011, 11:45 AM   #126
Poik
Backwards Turbo
Poik's Avatar
Wish we got the diesel engines here.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 08-29-2011, 10:47 PM   #127
Do I get a prize for 31.5 mpg in a 245 turbo?
Old 08-29-2011, 11:47 PM   #128
ArthurL
Not quite 35 mpg...
the 740 gets between 10 and 11 l/100 km (21-24 mpg us) but it's the wife's shopping car.
The 940T is my commuter, 80+ km per day, about 1/2 highway, remainder urban, 50 lb in the trunk.
I am now getting 8.80 l/100 (26.7 mpg us) avg of last 4 tanks. This will drop to about 10.5 l/100 (22 mpg) in the winter.
I've got an MPGuino trip computer to help. I can easily get 7.5 l/100 (31.3 mpg) on steady 105 kmh cruise. I've done 6.7 l/100 or 35 mpg on occasion. It's amazing watching how stop and go kills mileage.
940T (302,000 km) is not stock - head shaved .032, .028 squish, stock valves unshrouded, ported just to clean up the casting, stock turbo with MBC at 10 psi, TLAO chips, ignition mod at +3*, autobox, IPD sways, caster and camber mods, 195x65 tires at 44psi.
Love driving this car.
94 940T sedan; 90 740NA wagon
ArthurL is offline   Reply With Quote
Old 08-30-2011, 12:08 AM   #129
andysbeta
thrsh
andysbeta's Avatar
Location: Mancos, CO (no longer the Central Valley Smog Bank)
My 764TD gets ZERO mpg. It is very efficient. So efficient it shall be going to the junkyard , and pronto.
It barely mustered 34MPG @ 60mph.
andysbeta is offline   Reply With Quote
Old 08-30-2011, 12:49 AM   #130
Brandon
Brandon's Avatar
I'm the opposite of this right now. The 245 is running super duper rich, I gotta figure out what that problem is, but I suspect the AMM. It just cooked the cat, I cut it out and just welded a pipe in (no emissions here). I've got an LH 2.2 computer and AMM, I might just swap to that soon and see if my problem doesn't go away.
Trying to find a G80 for some 3.73s too so I can drop those highway rpms a little from the 4.10s in there now. I thought about going to 3.54s or 3.31s, but I'm wondering if that will get to the point where I could start hurting gas mileage, especially if I end up living in a hilly area (looking at UC Boulder for grad school), any thoughts?
Originally Posted by golgothan
Here is what you do to seal the deal, text her a picture of your nut sack stretched over a pine cone. I don't know why but girls totally dig it.
Brandon is offline   Reply With Quote
Old 08-30-2011, 12:57 AM   #131
Use your gears.
Put it at 2800 - 3000 rpm to climb and take what the speedo gives you.
Old 08-30-2011, 01:02 AM   #132
Poik
Backwards Turbo
Poik's Avatar
I'm not positive but I think my '83 245 DL has 3.31 gears. I've been consistently getting 32-33mpg cruising at ~65mph. One of my goals for the car is to improve it so that I get 40mpg @ 60mph. That's my target and I'm going to do it!
Old 08-30-2011, 01:03 AM   #133
andysbeta
thrsh
andysbeta's Avatar
32-33 is doing great ..
Old 08-30-2011, 01:10 AM   #134
Poik
Backwards Turbo
Poik's Avatar
Yeah I was actually really impressed after the first couple fill-ups. It's bone stock too, so I think with a few aero mods and a couple other changes I can bump it up a little bit more.
Old 08-30-2011, 01:15 AM   #135
185-75-14's & Coronas FTW.
Old 08-30-2011, 11:52 AM   #136
77volvo245
77volvo245's Avatar
I get 38mpg in my 760 turbodiesel with a m46 with 3.90 rear end :p
STSmachining
Old 08-30-2011, 03:03 PM   #137
84B23F
84B23F's Avatar
BMW's midsize 5-Series "expects to get better than 32 mpg." (four-cylinder)
Mercedes C-Class..."31 mpg on the highway." (four-cylinder)
Old 08-30-2011, 03:09 PM   #138
mtd240
Bored Member
mtd240's Avatar
My '90 245 M47 trans LH3.1 gets 26/29 city/highway stage zeroed. I assume the lean-runnin' 3.1 injection has a bit to do with that, along with the M47 trans. I feel pretty happy with that though - it is on par with the CAFE standards from last year.
It won't be for long since they are bumping CAFE up to 54.5 mpg by 2025...
1990 245DL M47 LH3.1 - 344,000 Miles
1989 244DL AW71 LH2.4 - Sold
1998 V70XC - Sold
mtd240 is offline   Reply With Quote
Old 08-30-2011, 10:30 PM   #139
84B23F
84B23F's Avatar
Originally Posted by mtd240 View Post
...bumping CAFE up to 54.5 mpg by 2025...
1960 era - However, the most astounding demonstration was the record set in the Pure Oil Economy Trials, another NASCAR-supervised event: 51.281 miles per US gallon (4.5868 L/100 km; 61.586 mpg-imp), which AMC sagely noted, "No car owner should expect to approach in everyday driving."[12]
PS: If you want to evaluate your mileage, do like they did back then, drive some 2,000 miles.
In the 1960 Mobilgas Economy Run, a Custom two-door sedan returned 28.35 miles per US gallon (8.297 L/100 km; 34.05 mpg-imp) over a route of more than 2,000 miles (3,200 km), finishing first in the compact class. Further proof of the American's exceptional fuel economy came when an overdrive-equipped car driven coast to coast under NASCAR's watchful eyes averaged 38.9 miles per US gallon (6.05 L/100 km; 46.7 mpg-imp).
Old 08-30-2011, 10:44 PM   #140
84B23F
84B23F's Avatar
The Mobil Economy Run is used to explain the claims made for United States Patent # 3937202 - an "Economy driving aid"[6]:
"... The experience obtained by skilled drivers in the Mobil Economy run indicates that for best fuel economy, a car should be operated at nearly constant speed in the range of 30 to 50 mph. Rapid accelerations or decelerations and operation at (or near) full throttle should be avoided. To practice for economy runs, skilled drivers used special instrumentation to determine the operating conditions for best fuel economy. This instrumentation usually included a vacuum gauge to indicate intake manifold vacuum, a special odometer to measure distance traveled to hundredths of a mile, and a burette to measure gasoline usage. However, instrumentation of this type is extremely complex for the normal driver and is additionally quite expensive. ..."
"... It is an objective of this invention to provide a signal to the operator of a variable speed, variable power internal combustion engine when the engine is being accelerated or decelerated too fast, in addition to a signal when the engine is being operated at too high or too low a power output. ..."
Old 09-30-2011, 04:59 AM   #141
towz-T
EL hipo explosive
towz-T's Avatar
ok; found out that my real life KM are 98.742% of what my car says (so if my car says i drove 1000km i drove 987,42km)
I'm taking pictures of the fuelling pump and how many km's I've driven and it's looking good for that badge :D
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 09-30-2011, 05:00 AM   #142
towz-T
EL hipo explosive
towz-T's Avatar
Old 09-30-2011, 11:42 AM   #143
BoostIt
BoostIt's Avatar
My brother got a flat 50mpg in our stock '92 245 with an m47 shifting at 2 grand and never going over 55mph, throwing it in neutral on every decline and hill and coasting when possible.
'83 244tic - Ipd bars, Ipd adj. panhard, Noltec v1 camber plates, front coilovers with 300# springs and Koni Yellows, rear cut wagon springs and Koni Yellows
'65 122 S - B20 bored .010 over, D cam, E head, M41 J-type, IPD poly all around, Bilstein HD's, tons of other goodies...
'91 245SE - Sold
'82 244tic - Sold
Originally Posted by Stephen View Post
At full compression, there's enough room for a credit card to slide in.
BoostIt is offline   Reply With Quote
Old 09-30-2011, 10:40 PM   #144
holtzboy
Honda CRV DD WTF
holtzboy's Avatar
I believe the injectors turn off if you coast down declines while still in gear but if your in neutral it goes in idle mode. At least that's what my narrowband AF gauge told me before.
1. 86 244DL- 1st car & owned for 16 years, 25mm sways, back to stock springs w/ KYB shocks, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 87 244DL - Sister-in-law's DD
3. 93 244DL - Step daughters DD
4. 84 242DL - Next project car
My feedback thread
holtzboy is offline   Reply With Quote
Old 10-01-2011, 12:28 AM   #145
Jeh
Wants a V12
Jeh's Avatar
I have never managed more than 27 in my 240 in mostly freeway driving during my commute to work. This was in a 86 240 that was almost totally stock in cool weather (no a/c) and I drove it easy. Typically it was about 26 and after the +T it has been 23 mpg week in and week out.
Jeh is offline   Reply With Quote
Old 10-01-2011, 12:39 AM   #146
andysbeta
thrsh
andysbeta's Avatar
28 mpg out of the 1988 745 w/ m47.
31 mpg out of the 1980 242 with the m46 and LH1.0 fitted , 3.91 final drive. good stuff, for sure.
Old 10-03-2011, 02:52 AM   #147
towz-T
EL hipo explosive
towz-T's Avatar
it's better to put it in a higher gear and let it roll down the hill than idling it
Old 10-03-2011, 04:17 AM   #148
towz-T
EL hipo explosive
towz-T's Avatar
did i double post the post above or below?
Old 10-03-2011, 04:17 AM   #149
towz-T
EL hipo explosive
towz-T's Avatar
by the way, it's looking really good for the 35+mgp club (or the <6,75l/100km club)
First i was like
but then i did this
and then i was like
so i drove (913*98.742%) 901.5 KM on 57.99Litres of diesel.
Meaning i do 6.436L /100km.
OR i drove 560.172 miles and needed 15.3193 gallons to fill it up
wich means i did 36.566 mpg.
But i had a lot of HEAVY traffic and calls from the FD (mich means i drive 1.5miles on an avarage of 9 to 7 mpg)
Old 10-03-2011, 12:32 PM   #150
SquareD
An Anomaly
SquareD's Avatar
Not in the 35mpg club, but I've got my 940 running really well lately. My last few fill-ups are showing ~27mpg on my commute which is about 90% highway miles. NA's got the taller rear end so at 70mpg I'm at almost 3k rpm. A different rear end might put me at 30mpg on the highway. Still, I think 27mpg out of a slab-sided stock 940 with a ancient engine design isn't bad. 245's seem to be the poop when it comes to mileage though, on highway trips my old 88 used to get around 30mpg without even trying.
