Keith602
- Jan 29, 2013
- Phoenix, Az
Do you have a pic of it in driving mode?
This is the only ride height shot I have and its with the old wheels, and the bottom pic is the only roller I have of it.
This is an awesome ride man! Definitely inspirational to those of us just starting at the beginning. I gotta ask you, what are you using/doing to restore the chrome so nicely!? Thanks!
Love this car, great video
That was pornografic. Thank you.
Every time I see your paint, I'm glad I decided to return my sedan to black. Looking forward to your next wheels, even if I loved the salt flats in black.
Keith, Just curious if you have taken a look at the inner bushings of your upper and lower A frames. Those bushing are torsional and are not meant to rotate as far as they are with your airbags. If you look at the bushings, the inner steel tube has small teeth on both ends which grab the K member and outer washer when tightened. The outer steel tube is pressed into the lower A frame and tightened with the U bolt on the upper A frame. These bushings are designed to have a very small range of motion, just wondering how long yours will last?
Happy New Year
I liked the black, but the polished goes along really well with the amount of chrome?. just enough to make that black POP! Nice job with the overall look, and some meshies would also look great!
And evolve67 was mentioning the torsional effect on the bushings being a possible problem area for longevity, but since it is a lot closer to factory height when high loads are placed on the bushings, i.e. driving, cornering, etc? I think that they will still last quite a while as long as they aren't super stiff poly, but theres really no reason to assume that there is even any torsional forces applied to those bushings, seems like the the only concern is going to be the ball joints being twisted to the very end of their available range. And the way the wheels cock inward when its slammed is just the way the alignment changes due to the height change. I don't really think that you have much to worry about there.
Good work, and I hope to see it in person sometime!
