vwbusman66
Stößelstange über alles
- Oct 12, 2016
- SE MI
So now that I have about 2,000 miles on the 142 since the cam swap, I?d like to tweak some stuff for better drive-ability and power. At the moment, the car ?climbs on? hard at 3000rpm and pulls hard to 6k. I use 93 octane exclusively and timing is set at 11deg btdc. Vacuum retard is still connected, but I plan on plugging the line. Valves are set at .016 and I have stock HIF6?s with the secondary butterflies removed. D cam with aluminum timing set.
Where should I set timing? I?ve seen as much as 17 at idle.
Should I make the points gap slightly smaller/larger to improve high rpm ignition?
Any tricks I?m unaware of?
